So Mr. Tux should have all that the components by X-Mas to start doing his thing and creating a x-over.
Plan is open to passive or active x-over or a mix of both and Ryan will choose what he thinks is best.
Long term project and no rush to get this done.
The key words that I have told Ryan to describe what I am looking for are:
Power
Clarity
Attack
Airy
Components for each of the front 3:
2 x JBL 2226h
1 x 2446h 2" compression driver with Be diaphragm
1 x Iwata 300
***may add an AMT or a Beyma 150d or the new 200 if we can't get the high's sounding where I want them to.
I think we are shooting for somewhere between 40-45hz on the low end.
Front 3 will get 1000watts per side from my Powersoft 4 channel amp.
Each 2226 will have it's own cabinet and be ported. They will be stacked on top of each other.
Each driver is recessed in the baffle by 1/4 - 1/2" and will have a large roundover on the front edge of the opening.
Each side of the port will be flared or have a roundover.
Subs will be 2 - FTW 21's powered by their own Ashly KLR3200 bridged to 3200watts.
[there will be bracing inside not shown in the image. 1.5" thick front baffle and 3/4" walls elsewhere most likely baltic birch then painted high gloss white]
Ryan will be taking measurements of everything and posting them here if I'm not wrong.
Maybe the differences between the stock diaphragm and the Be in the 2446 also.
I also want to thank jbrown for helping us get the iwata's over here and Erich for putting up with my badgering. Also Scott Simonian for pushing me to spend money and Mr. Carl Huff for his help about the Be diaphragms and where to get them.
Power
Clarity
Attack
Airy
2 x JBL 2226h
1 x Iwata 300
