bridged crown xls? - AVS | Home Theater Discussions And Reviews
post #1 of 5 Old 12-20-2014, 09:12 AM - Thread Starter
Tstan7777's Avatar
Quoted: 63 Post(s)
bridged crown xls?
I'm interested in building a diy sub soon. Hoepfully. I already have a crown xls 1500 and plan on using it to power it. Anyway, could I use a 4 ohm driver with it? I see it does list 1550w at 4 ohm bridged, but will it struggle with that load? In bridged mode, 8 ohm is 1050w and 4 ohm is 1550w I believe.
Tstan7777 is offline
post #2 of 5 Old 12-20-2014, 09:47 AM
notnyt's Avatar
Quoted: 781 Post(s)
Liked: 815
Should run fine in bridged at 4 ohms. It'll run at 2 ohms per channel non bridged.
notnyt is online now
post #3 of 5 Old 12-20-2014, 10:17 AM
95bat's Avatar
Quoted: 22 Post(s)
I'm running one right now in 4 ohms, hasn't had a single problem. It has been a great amp for me.
95bat is online now
post #4 of 5 Old 12-20-2014, 01:22 PM
rlhaudio's Avatar
Quoted: 134 Post(s)
Liked: 46
I'm using 2 individual crown xls 1500. Each powering a separate 15" Ultimax sub. No problems
Denon 4311CI, Panasonic 8000 w/ 130" AT Screen
DIY QSC SC-2150 Clone L,C,R
DIY Fusion Tempest
DIY Ultimax 15 "Sub's
Dayton MK4 & B&W ASW 855 15" subs
*coming soon 2 SI 18 ported subs and 4 Volt's*
rlhaudio is offline
post #5 of 5 Old 12-20-2014, 04:28 PM - Thread Starter
Tstan7777's Avatar
Quoted: 63 Post(s)
Good to hear!! Now I just have to decide what to do. I'm leaning towards sealed si 18. Total cost would be about $400. If ported I like the lab 15,but that pushes it closer to $500 and a little more effort on the build. Either one would squash the 10" hsu I currently use. I don't think output will be a problem with sealed in my 2300 cu ft room.
