Subs Barely hit unless I d/c one?? - AVS Forum
post #1 of 7 Unread Today, 01:15 PM - Thread Starter
damastah's Avatar
Hello guys,
I currently have my Alpine PDX 1.1000 powered by a 775watt @24 amp 12volt computer PSU. The amp has 25amp fuses in the back.
I have a single coax line coming from my home receiver, it's a pioneer elite. Has 2 spots for a sub. But I only used one cable into a Y-splitter for the input jacks in the amp.
The Subs are hooked up by a 12AWG speaker wire into the speaker plug that came with the amp. Speaker plug goes into the amp, don't think the direction that it goes in matters because I've tried both ways.
But while I was trying to switch the plugs around, I realized that if only 1 sub was plugged in and the other wasn't, it was getting power. It was hitting pretty good, but when they are both in, both subs barely hit.
I'm not sure why this is. I tried google search but I couldn't find anything. I try to come on the forum and ask as a last resort. Can you please help me?
damastah is online now
post #2 of 7 Unread Today, 01:39 PM
Quoted: 64 Post(s)
Sounds like your subs are wired out of phase. Make sure your positives and negatives are connected correctly.
jake515 is online now
post #3 of 7 Unread Today, 01:40 PM
Jay1's Avatar
Quoted: 25 Post(s)
Liked: 111
I'm no electronics expert but I'm pretty sure a computer PSU is not an audio amplifier, but I could be wrong
Jay1 is online now
post #4 of 7 Unread Today, 01:44 PM
TheGiantPeach's Avatar
Quoted: 67 Post(s)
Liked: 84
Originally Posted by damastah View Post
Hello guys,
24 amps at 12 volts gives you 288 watts. Since amps are pretty ineffecient, you're likely only throwing 200 watts to your subs. You need more.
TheGiantPeach is online now
post #5 of 7 Unread Today, 02:12 PM
More is Better's Avatar
Quoted: 36 Post(s)
Liked: 24
+1
Switch the 2 wires on the back of one sub.
More is Better is offline
post #6 of 7 Unread Today, 02:15 PM
bombertodd's Avatar
Quoted: 26 Post(s)
Liked: 24
I think this is your problem. Assuming the PSU is 775 watts total means that the 12v rail will have much less power (288 watts as GiantPeach mentioned), since some of the amps will be saved for the 5v rail and such. Most power supply's will have the listed amperage on the side for the 12v rail.
Klipsch RF-82II
Denon 2113ci
bombertodd is online now
post #7 of 7 Unread Today, 02:53 PM - Thread Starter
damastah's Avatar
Okay. I fixed it haha!
It was out of phase! Thanks guys!
During my google searches I read that this could be the reason, that's why I flipped around the speaker plugs in the first place, but I didn't think about switching the wires that go into the sub. I did see that a negative was going into a positive into the speaker plug. Haha, thanks so much guys!
