Help with Inuke3000dsp needed - AVS Forum | Home Theater Discussions And Reviews
Old 12-24-2014, 02:48 PM - Thread Starter
Rx8Doc's Avatar
I know its Christmas eve, but can someone give me their settings from the inuke remote screens I do not think I have them right. Info: Marty cube with 18" D4 (wonderfully constructed by the master himself) thanks Donny. Room size 15x20 x8. I have it set for bridged. I get lost when i get to the four screens in the remote sw program.
More info: Receiver is a Yamaha speakers set to small xover set to 80.
I will try to get pics of my current settings. I just want to see if I need to tweak it just a tad. Or buy a second unit.
Merry Christmas to all and forget about that silent night stuff I want a amp that goes to 11
Rx8Doc is offline
Old 12-24-2014, 03:25 PM
chalugadp's Avatar
Quoted: 1672 Post(s)
Liked: 1505
Why not just use front panel controls. I find it fast and easy. What settings do you want to change ?
chalugadp is offline
Old 12-24-2014, 04:06 PM
Samps's Avatar
Quoted: 789 Post(s)
Liked: 416
I don't think you can use the D4 in bridged mode unless you run it in series at 8 ohms which is a waste of that amps potential. You could wire in parallel and use one channel of inuke at 2 ohms. And then switch inuke off of bridged.
Samps is offline
Old 12-24-2014, 04:21 PM - Thread Starter
Rx8Doc's Avatar
Not using the front panel for two reasons. 1 it is on the ground right now and hard for this old man to bend over to read. 2. I keep pushing the buttons and getting lost (yes I am the one from the 80s with the blinking clock on his vcr).
The sub sounds great but I just want to be sure I am totally dialed in.
Rx8Doc is offline
Old 12-24-2014, 04:48 PM
chalugadp's Avatar
Liked: 1505
Need some measurements to know. If you don't have spl meter then your cell phone is ok for rough estimate. Download test tones from audiocheck.
Old 12-24-2014, 05:06 PM
rhodesj's Avatar
Quoted: 852 Post(s)
Liked: 471
If he's only got one sub right now, it doesn't really matter, probably an easier load on the amp at 8 ohms bridged as well. Easy to change when he adds a second one.
rhodesj is offline
