Simple question - AVS | Home Theater Discussions And Reviews
DIY Speakers and Subs > Simple question
nwf477's Avatar nwf477 07:12 AM Today
Since I have read you have to turn the 3000DSP on manually or by having a smart strip I was wondering if you could use the switched outlet on the back of the AVR? If this would work turning it on and off would be quite simple.
kgveteran's Avatar kgveteran 07:34 AM Today
It would be nice to use that switched outlet on the coil part of a heavy duty relay capable of supplying enough current to the amp and not put all that demand on the receivers 110v outlet....
There are some real safe DIY relay threads if you do a forum search, good luck.
Up
Mobile  Desktop
