DO SI 18 full marty? - AVS | Home Theater Discussions And Reviews
post #1 of 9 Old 02-24-2015, 08:54 PM - Thread Starter
sooly1's Avatar
Liked: 27
Ok, I have a full Marty, however, there is always more. What would a DO Si 18 look like with similar power vs 2 full Marty subs? I have space for another Marty, but DO sounds cool.
The Goal is to use an inuke 3000dsp to power 2 Si 18s d4s and get the most out of them. Space not a concern. The room is mine and the wife lets me play in my playground. Btw, full marty dual opposed..... what would the name be?
sooly1 is offline
post #2 of 9 Unread 02-24-2015, 09:20 PM
LTD02's Avatar
Quoted: 817 Post(s)
Liked: 1335
something roughly like this. dual opposed does little to nothing for frequency response. it is two sealed drivers.
this model was for 1 driver. 2 would give +6db across the board.
if you have the space and don't mind losing most of the frequencies below tuning, it is hard to beat ported.
Listen. It's All Good.
LTD02 is offline
post #3 of 9 Unread 02-24-2015, 09:46 PM
wormraper's Avatar
Quoted: 181 Post(s)
Liked: 80
Blue is Dual opposed full marty. the green is dual ported martys. rule of thumb is each dual opposed cab would be ABOUT equal in output to ONE regular marty above tuning.
wormraper is online now
post #4 of 9 Unread 02-24-2015, 10:57 PM
Face2's Avatar
Quoted: 116 Post(s)
Liked: 79
DO sounds cool, but doesn't do as much as 2 separate subs can for room nodes.
Mike
Face2 is offline
post #5 of 9 Unread 02-24-2015, 11:01 PM
chalugadp's Avatar
Quoted: 1540 Post(s)
Liked: 1315
Only way I choose sealed is limited size (under 4cuft cab)
Or I had dedicated theater and used 6 to 8 sealed subs.
chalugadp is offline
post #6 of 9 Unread Yesterday, 10:43 AM
Girmic's Avatar
Quoted: 12 Post(s)
Liked: 34
I think OP means two drivers in one full Marty (opposed). Not sure how that would work but sounds interesting.
Girmic is offline
post #7 of 9 Unread Yesterday, 02:07 PM
K9woofer's Avatar
Liked: 0
What about building 2 cubes, then you can stack them OR move them in different locations.
K9woofer is offline
post #8 of 9 Unread Yesterday, 05:51 PM
Samps's Avatar
Quoted: 242 Post(s)
Liked: 91
I agree with Girmic, I think he meant putting two 18s in a single marty. They could be opposed I think. There should just be enough room to put them on the sides. But that won't be as efficient as two separate Marty's. It might be equal to two separate cubes though.
Samps is offline
post #9 of 9 Unread Today, 05:51 AM
rhodesj's Avatar
Quoted: 143 Post(s)
Liked: 84
Two drivers in a Full Marty will perform more like a pair of Martycubes than a Full Marty.
rhodesj is online now
