Why aren't there more 1260w 1262w builds? - AVS | Home Theater Discussions And Reviews
 12Likes
post #1 of 41 Old 03-06-2015, 03:14 PM - Thread Starter
goonstopher's Avatar
Quoted: 110 Post(s)
Looks like 4 of these in 9-10 cu with a 15hz tune can do 112db at 16hz, 115 at 20hz and up to 122db at 80hz with just 1300w.
Am I missing something or should there be a TON of these being built???
I am thinking something using 2 dual opposed vented could be reaaally nice.
Maybe put a few of those around the room... One behind the MLP
goonstopher is offline
post #2 of 41 Old 03-06-2015, 03:20 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 1526 Post(s)
Liked: 1417
Nope. You're not missing anything. There are just other popular drivers people tend to go with.
You should start a trend, Goon.
Go for it!
My Dual 18" LLT subs 120dB down to 10hz
Plan9Reloaded Co-host
Listen to the Plan9Reloaded Gaming and Technology Podcast (may contain NSFW language)
https://soundcloud.com/plan9reloaded/sets/podcast - direct pod link
http://plan9reloaded.com/site/ - main website
Scott Simonian is online now
post #3 of 41 Old 03-06-2015, 03:20 PM
Quoted: 46 Post(s)
Liked: 36
I'm working on it!
Going to build a 4 cubic foot (115 liter) internal box with an 18" passive radiator tuned to 19Hz next month. If that goes well, pondering building two more but transmission lines and the PR version will be near field. The next two will be made as speaker stands for the front stage.
Some nut is building a pair of subs with 16 of the Infinities in a sealed box (16 in each box!) I'd say the issue, although an inexpensive driver is the wood, duratex, feet, connectors etc. add to the price so always looking for a bit extra in that range. I'm still reading over the details of the 1260 to get it all lined up correctly.
My wife won't put up with 9 cubic foot beasts--bummer, I'd love to do a push-pull slot load with a pair of Infinities.
18Hurts is offline
post #4 of 41 Old 03-06-2015, 03:41 PM
rhodesj's Avatar
Quoted: 194 Post(s)
Liked: 119
I'm not sure that 3-4 of them has much of an advantage over an HT18 for general HT usage. I've got two in sealed boxes in my bedroom, and they're quite nice. I plan to make a pair of front loaded horns sometime this year.
Great bang for your buck with the Infinity 12s. There's also a JBL GTO1514 which is nice, performs about like two of the 12s.
rhodesj is online now
post #5 of 41 Old 03-06-2015, 03:42 PM
Mfusick's Avatar
Quoted: 326 Post(s)
Liked: 1394
125db from two in a tapped horn for $120 in drivers
Mfusick is online now
post #6 of 41 Old 03-06-2015, 05:40 PM
LTD02's Avatar
Quoted: 934 Post(s)
Liked: 1400
Originally Posted by 18Hurts View Post
I'm working on it!
not sure how much the slot is contributing to the effect you are looking for. push pull reduces 2nd distortion pretty well though.
the m&k were push pull with a fairly decent waf.
Listen. It's All Good.
LTD02 is offline
post #7 of 41 Old 03-06-2015, 05:44 PM
LTD02's Avatar
Quoted: 934 Post(s)
Liked: 1400
at 16mm excursion? at what frequency?
LTD02 is offline
post #8 of 41 Old 03-06-2015, 05:56 PM
smcmillan2's Avatar
Quoted: 224 Post(s)
Liked: 123
Don't know that I'd go with the term "nut", there's some good reasoning behind the build (albeit more extreme than many would take on):
16 x 12" Sealed sub cabinet
5 1260s in a 32Hx32Wx24D box like LTD02 mocked up in the above thread with only 750W kicks out some big SPL, according to the modeling I've done. Wish I had a spot to place something like that...
smcmillan2 is offline
post #9 of 41 Old 03-06-2015, 06:07 PM
Mfusick's Avatar
Quoted: 326 Post(s)
Liked: 1394
18hz or so... I can't take credit for the design though. Lilmike helping me. Rubber hits the road when it measures as good or better as simulated though.
He did a pair of Alpine type R full throttle and 1 meter groundplane was over 130db, Infinity not going to quite do that but shave off 6db or so and they are still amazing for $120 in drivers. Poor boy DTS10. Title of this thread reminds me of that, I too feel the same. The forum should be flooded with something like this, but no one knows really how to design it quite right. Double driver tapped horns is a territory perhaps only Ivan and Tom have really ventured into. It's where I want to go... I like to push things if I can. I'm more interested in projects like that.
But OP is right, the infinity 1260 is great for just about anything given it's low price. It works ported and sealed really nice too. I have made both a ported and a sealed 1260 build and both surpassed my expectations. It's no LMS but it's surprisingly good for only $60. It will stomp hard any $500 commercial subwoofer I know of.
"Too much is almost enough. Anything in life worth doing is worth overdoing. Moderation is for cowards."
post #10 of 41 Old 03-06-2015, 06:35 PM
LTD02's Avatar
Quoted: 934 Post(s)
Liked: 1400
yeah...its almost comical that such a budget driver seems to perform so well.
LTD02 is offline
post #11 of 41 Old 03-06-2015, 06:40 PM
Mfusick's Avatar
Quoted: 326 Post(s)
Liked: 1394
It certainly makes you smile. One of those ported at 20hz in a simple 24" cube (aka marty style) is literally the ultimate bang for your buck. It's everything someone that is normal would ever want or need. $100 to make it, including the driver. That is comical.
post #12 of 41 Old 03-06-2015, 07:06 PM
LTD02's Avatar
Quoted: 934 Post(s)
Liked: 1400
with respect to the horn in development...here's a thought:
the infinity drivers are SO cheap that the cost of the wood to build a horn may be more than buying additional drivers.
LTD02 is offline
post #13 of 41 Old 03-06-2015, 08:02 PM
likelinus's Avatar
Quoted: 74 Post(s)
Liked: 37
I'm so temped to buy one of these for my new Infiniti. It's matches the paint (wife pointed that out, lol) and I keep hearing good things. I'm thinking about a 1cuft Sealed enclosure with a 500 watt mono amp. Should be enough power for it?
likelinus is online now
post #14 of 41 Old 03-06-2015, 10:06 PM
More is Better's Avatar
Quoted: 207 Post(s)
Liked: 126
Because I bought them all.
LTD02, rhodesj, corradizo and 1 others like this.
More is Better is offline
post #15 of 41 Old 03-07-2015, 06:58 AM
Quoted: 46 Post(s)
Liked: 36
I have a pair of 9 cubic foot internal air space dual 15" ported to 28Hz subwoofers in the garage. Then add in the slot size, port size etc. and those subs are very large! Very clean, controlled bass as the push-pull loading seems to work well. My suffering wife made the comment how those beasts are staying in the garage and not allowed in the house so...
The max she puts up with is around 4 cubic feet so that knocks out dual 1262 push-pull slot loads. The slot is great for the garage, it protects the woofers from feet, flying parts etc. and has a unique look.
The max amount of 4 cubic foot subs is 3 in the living room--the PR sub vibrates strongly since it has only one PR so gives the butt kicker effect on the wood floors. It will go near field with a new pair of subs to be made as speaker stands.
One day I can do the more is better 16 sub box version after I wire in some more breakers--and just make a new wall out of them so my wife won't notice.
It will be awhile, there is a global shortage on those drivers for awhile...
LTD02 and More is Better like this.
18Hurts is offline
post #16 of 41 Old 03-07-2015, 07:23 AM
Mfusick's Avatar
Quoted: 326 Post(s)
Liked: 1394
To a certain point, but if you are doing duals, the cost of wood gets divided and becomes a not so important issue.
125db from $120 in drivers is pretty good. If your driver cost is $1 to 1db... that seems about the golden ratio.
The cost of 4 or 5 sheets of wood certainly matters, but it's rarely over $200 to make a cabinet, and can be a lot cheaper if you find a deal or use something like OSB. You don't need BB to make a horn.
So lets just round up and say it's $350 for drivers, in cabinet, with speaker terminals/glue/screws. That's an amazing deal.
A marty is $175 woofer + say $60-$100 or so... (really two sheets if you want to do it right) so $275. Great deal too.
Those are the two best deals going. The infinity in a ported is a deal as well, or two of them.
What does two infinity in a single 2x4 foot enclosure at 20hz measure? I'd assume it's pretty good too. I hear totally what you are saying, when these drivers are that cheap you kind of need to double them up so it's two drivers per wood purchase to keep the value maximized.
post #17 of 41 Old 03-07-2015, 07:47 AM
LTD02's Avatar
Quoted: 934 Post(s)
Liked: 1400
an infinity wrapped inside an infiniti, sounds like some sort of advanced math concept. :-)
in a car, you get huge cabin gain, but I think the driver is only "rated" for 300 rms. check on that and try not to clip the amp too much and it should still produce quite a bit of spl.
for an extra $60 or so, I'd probably go with the alpine swr12 and have less concerns about blowing it up.
LTD02 is offline
post #18 of 41 Old 03-07-2015, 07:58 AM
LTD02's Avatar
Quoted: 934 Post(s)
Liked: 1400
limiting to 16mm excursion and 500 watts per driver (two cabs, four drivers total):
LTD02 is offline
post #19 of 41 Old 03-07-2015, 10:11 AM
likelinus's Avatar
Quoted: 74 Post(s)
Liked: 37
I haven't purchased anything as of this moment, but I was going to hit up Amazon and look around at amps and subs sometime this weekend. For some reason I thought the infinity subs were rated for 600watts rms, but I must be mistaken because I was also looking at an Alpine and JL option as well. I have a left over PPI amp that puts out 360 at 4ohm, so that may be an option. Need to do more research though.
Thanks for the swr12 suggestion, will certainly look into it. I think the one I looked at was a Type R? Cant remember lol
post #20 of 41 Old 03-07-2015, 10:18 AM
kiwijunglist's Avatar
Quoted: 44 Post(s)
I got a jbl gto 1514 on the advice of others in the forum. But I've been doing some more modeling for dual opposed sealed and in some ways i like the infinity better bc it is happier with less volume and i could use a smaller sonotube. Also the cone of the jbl is quite ugly compared to the infinity.
With nz prices i can buy 5 or 6x 1260w for the price of 1x daytom um18.
HTPC (MediaPortal) / Pioneer SC LX87 / Wharfedale Jade 7 Fronts, 5 Rears, 2c Center / DIY Sub
kiwijunglist is online now
post #21 of 41 Old 03-07-2015, 10:58 AM
Quoted: 207 Post(s)
Liked: 126
Call sonicelectronics and order over the phone to get a better price than the inet price for the 1260W's. I got them for $53.95 shipped and saved $8 per sub $256 total. I didn't call anyone else tho, there might be better deals if you call around.
post #22 of 41 Old 03-07-2015, 02:34 PM
Doctor Morbius's Avatar
Quoted: 121 Post(s)
Liked: 89
Would a single 1260w or 1262w outperform a Dayton DVC310-88 12" in a sealed cabinet of approximately 1.5 internal cubic feet? This would be for musical accuracy only. No home theater.
https://www.parts-express.com/dayton...oofer--295-185
Doctor Morbius is offline
post #23 of 41 Old 03-07-2015, 03:03 PM
Samps's Avatar
Quoted: 283 Post(s)
Liked: 106
I have the dayton rss315hf-4 12" and it sounds very good. The specs state it has triple shorting rings to reduce distortion which I know very little about. But it is one of the cleaner sounding small subs I've heard. It models perfectly flat in 4ft3 at 20hz.
Doctor Morbius likes this.
Samps is online now
post #24 of 41 Old 03-07-2015, 03:26 PM
Jay1's Avatar
Quoted: 191 Post(s)
Liked: 193
The DVC is a higher (build)quality unit with a bit more throw and power handling. I'm not seeing any reason why it would subjectively sound better though. Something from the RSS or UM line would probably be a better bet as they each have advanced motor designs.
Jay1 is offline
post #25 of 41 Old 03-07-2015, 05:10 PM
Quoted: 121 Post(s)
Liked: 89
Thanks guys!
post #26 of 41 Old 03-08-2015, 10:33 AM
Liked: 1
Would like to reuse two old mdf boxes for two 1260. Just a quick project for my father. The boxes are about 104 liters. They already have a slot port that is 40x7cm. It`s only 25cm long now, but can easily be extended. Could anyone help with what length it should be for 20hz tune..?
Edit: I`ve tried to wrap my head around winisd several times, but somehow I just don`t "get it". In that regard, yes I am a dodo head.
gogothedodo is offline
post #27 of 41 Old 03-08-2015, 12:00 PM
Richard Cohen's Avatar
Quoted: 12 Post(s)
Here is my diy dual opposed sealed 1262w with a Yung 300-6 amp. Cabinet external is 17 by 24 by 24.
Home Theater is GREAT
Richard Cohen is offline
post #28 of 41 Old 03-08-2015, 12:16 PM
smcmillan2's Avatar
Quoted: 224 Post(s)
Liked: 123
My modeling shows a port 203cm long to reach a 20Hz tune in that box, and a first port resonance of 84.4Hz. Doesn't seem like a good combination.
If you can get the port down to 4cm tall, then it would take a 114cm long port to tune to 20Hz, first port resonance of ~151Hz.
post #29 of 41 Old 03-08-2015, 12:32 PM
LTD02's Avatar
Quoted: 934 Post(s)
Liked: 1400
in a 104 liter cab, 20hz is too low. better would be about a 23-24hz tuning or so. what you have not is about 32hz.
doubling the port length will drop the tuning to around 24hz. that is about the best compromise with that enclosure.
LTD02 is offline
post #30 of 41 Old 03-08-2015, 02:56 PM
Liked: 1
Oh well.. Back to the drawing board. Thank you for your time gentlemen.
