Sealed projects: 1 LMS-Ultra 5400 18 and 2 LMS-R 15’s - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #31 of 39 Old 04-07-2015, 01:23 PM
cubalis2's Avatar
Quoted: 29 Post(s)
Liked: 52
Originally Posted by GeorgeHolland View Post
I finally powered up the LMS-R 15's and immediately noticed loud rattling and unnatural noises coming from one of them. The other may be fine but I will have to test it by itself because it was difficult to hear much over the obviously defective sub-woofer.
RMA time.
That's a bummer for sure. If it comes down to it and PE runs out of stock you can fix them with a gel based cyanoacrylate (crazy glue). Apparently it was a glue/paint issue attaching the spiders to the basket.
Best of luck with the RMA, and your boxes look fantastic (and deserve working LMS drivers )
cubalis2 is offline
post #32 of 39 Old 04-07-2015, 04:23 PM - Thread Starter
GeorgeHolland's Avatar
Quoted: 45 Post(s)
Liked: 46
PE issued an RMA and the defective sub was picked up by UPS today. Looks like a couple more weeks of waiting to find out how three LMS's work in my room.
GeorgeHolland is offline
post #33 of 39 Old 04-18-2015, 03:19 PM - Thread Starter
Quoted: 45 Post(s)
Liked: 46
RMA LMS-R 15" received, installed, Audyssey ran and all seems well so far.
Boomassiv and gogothedodo like this.
post #34 of 39 Old 04-18-2015, 05:50 PM
michaelddd's Avatar
Quoted: 326 Post(s)
Liked: 209
Sorry to hear about the defective driver. But at least PE seems to be doing right by you. That's good to hear. Also wanted to add that you have mad finishing skills. Something I'm currently working on getting better at myself. However much black dye you added to the BAC walnut stain was an exactly perfect amount. Those enclosures (too pretty to call them "boxes") are drop-dead gorgeous.
michaelddd is offline
post #35 of 39 Old 04-18-2015, 05:51 PM
Quoted: 70 Post(s)
Liked: 7
How are the lms-r 15s? I have 2 lmsu 5400 18s and want 2 more but since i cant find some figured try the lms-r 15s.
MagnumMafia05 is offline
post #36 of 39 Old 04-18-2015, 06:18 PM
gixerking's Avatar
Quoted: 201 Post(s)
Liked: 232
Not to bud in, but I have a pair and think they are great. Of course I haven't heard the ultras so can't compare. There are other options for 18s for the money, but I am not dissatisfied in any way with the lms-r.
On topic, I dig the looks of the cabs. Good work!
gixerking is offline
post #37 of 39 Old 04-18-2015, 07:52 PM
Shan87's Avatar
Quoted: 16 Post(s)
Liked: 27
Wow, those look great man.
GeorgeHolland likes this.
Shan87 is offline
post #38 of 39 Old 04-19-2015, 07:05 AM - Thread Starter
Quoted: 45 Post(s)
Liked: 46
Thanks for the kind words. PE service was very good. The stain was ebony and I would probably never be ever to match the dye mix again but wood takes stain differently so probably not an issue if I build another some day.
post #39 of 39 Old 04-19-2015, 07:14 AM - Thread Starter
Quoted: 45 Post(s)
Liked: 46
I've only watched one movie so far and it sounded great but beyond my skills to distinguish between what the single LMS Ultra 5400 18" was putting out vs the pair of LMS-R 15's. I would have built a second LMS-U 5400 as well but think I picked up the last one so decided to try two LMS-R's. In my room the 18" was plenty and now with the two 15's I'll need to add more gasket tape to the door to keep it from rattling.
