Interesting DIY rotary subwoofer project - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 57Likes
post #61 of 295 Old 04-22-2015, 11:55 AM
Augerhandle's Avatar
Quoted: 847 Post(s)
Liked: 774
Originally Posted by Bushi View Post
...just wanted to congratulate whoever thought to use the RC rotor system. It seems so obvious now (and pretty cheap)....
There were several aborted attempts documented in the forums three or four years ago, and I read somewhere that Thigpen's first prototype used RC rotor parts...
EDIT: Here's one from seven years ago. (pics near bottom of page)
http://www.hawthorneaudio.com/forums...1454&start=615
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #62 of 295 Old 04-22-2015, 12:02 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
"Flatpacks" - probably not
but
I'm looking at understanding the "shopping list"
and, the good news for a DIY fan
some assembly required
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #63 of 295 Old 04-22-2015, 01:39 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Originally Posted by Stereodude View Post
I'd presume there's at least one patent on the rotary sub that would prevent that from happening.
This is interesting to me. Say there was a patent... would it cover selling the parts to make the item, or the item in general being sold as a entire piece.
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #64 of 295 Old 04-22-2015, 02:13 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
^ good question IDK
however the OP and his guide are thorough and engaging , to say the least
this would not be the first time (with this crowd) for several A-HA! moments of creative and thoughtful "divide and conquer reverse engineering" along with a bunch of "what if's?"
so maybe a budget for D: all of the above - $1K (?), just from the hip,
what does it take to get 3phase power in a standard household?
what if you live in an apartment or condo? (DOOMED!)
electric motors from Grainger, start at about $250-300+
any comment wrt the previously proposed DBX sub synthesizer input possibilities, it needs a signal wrt designed capacity/output and how it gets integrated with the remaining subs,
why build this thing if only depending on "maybe"?
Because this how DIY evolves . . .
what kind of amp can give the power to boost that ULF up to our hearing threshold?
are there other devices I just don't know about (?)
(probably)
a minidsp 2x4 (balanced)(?) seems a direct route . . will it get to 5-8 HZ? -usually around $125-ish
post #65 of 295 Old 04-22-2015, 09:25 PM
popalock's Avatar
Quoted: 1242 Post(s)
Liked: 1736
Speaking of... How much are we looking at for the total cost of this project @chris hudlin?
popalock is offline
post #66 of 295 Old 04-22-2015, 10:07 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
+1
I'm still on the hook for my second UXL from the current gb, that's about $400
and then to figure out how to integrate the 3 subs i'll have . . .
we need that ulf signal generator . . .
post #67 of 295 Old 04-23-2015, 02:04 AM
Originally Posted by asarose247 View Post
sooooooooooooo . . .
glacially rushing right along
here is one choice (?)
<li class="productName">GP Motor, 3-Ph, TEFC, 1 HP, 3480 rpm, 56GP Motor,3-Ph,TEFC,1 HP,3480 rpm,56<li class="product-info">Item # 35JF92<li class="product-info">Mfr. Model # 00136ES3E56-Snow we know the motor isn't expected to run more than about 1800 rpm, that to me seems to a function of the VFD (NOT an electrician here)
is there a concern wrt heat build up if run at lower speed, hence the TEFC spec
is 1 hp adequate
then moving onto the sacrificial speaker
previously there are no specs, found by me, for the xplod,
is there a "preferred" Xmax , i.e. is 12-15mm good?
is more better
realizing that the excursion is translated into vane deflection/changes and that is dependent on the rate of change due to the geometry of the RC thingy
just trying to simplify this whole thing to clarify (understood by me) each components own "needs", function
and knowingly/hopefully optimize the build/results synergistically
looking for "dero zeffects"
yes, 1hp is adiquate and yes, the speed is controlled by the VFD
12-15mm is great. you dont want to overdrive the unit with too much xmax cause it will pull the rods from the rotor. and also, it only requires 300w of power (driver) to for it to work because it is so light, but i used a 1300w sub. you could use a stronger amplifier to reduce disortion, but its be pointless at <16Hz.
^ good question IDK
(probably)
you dont need a 3 phase input to your home, but if thats what you want to do it is very simple but will cost you a little.
the VFD i use to control my motor is single phase input and artificial 3phase output.
$600-$900 for you, £250-£350 for me in the UK
ambesolman and popalock like this.
chris hudlin is offline
post #68 of 295 Old 04-23-2015, 03:39 AM
popalock's Avatar
Liked: 1736
$600 = £400
$900 = £600
£250 = $375
£350 = $525
^Which is it? I only bring it up because that is quite a difference. Are there some other factors I'm missing that would effect the cost of the project?
popalock is offline
post #69 of 295 Old 04-23-2015, 11:43 AM
Either. It tells you on the guide how much it cost me. So base your figures around that. It was 300 quid for me
post #70 of 295 Old 04-23-2015, 12:27 PM
noah katz's Avatar
Quoted: 1021 Post(s)
Liked: 351
I would think motor speed should be almost entirely related to sound volume and have little effect on harmonic distortion.
If the motor slows down when loaded by the blade pitch changing, I'd think that would translate directly to distortion.
Dunno whether it's enough to matter; I'd imagine not.
If it does, putting a flywheel on the motor would help.
...is there a concern wrt heat build up if run at lower speed, hence the TEFC spec
is 1 hp adequate...
coupla things
I believe 1/2 speed gives 1/4 airflow
1/2 speed also gives 1/2 power at same torque
I'd search for a 1750 rpm motor on ebay, craigslist, or scrapyard
*very* expensive; just get one of this http://dealerselectric.com/FM50-101-C.asp or this http://dealerselectric.com/JNEV-101-H1.asp
which also gives you the option to experiment with different speeds
IIRC Thigpen said a couple hundred watts is adequate
the power amp is only used to modulate the blade pitch; the actual power is coming from the motor
analagous to the power required for power steering vs. that to move the car
mtnboydl likes this.
Noah
noah katz is online now
post #71 of 295 Old 04-23-2015, 02:16 PM
Quoted: 847 Post(s)
Liked: 774
physics geek reply...
the moving mass isnt the issue, it is the resistance form the air dependent on the angle of the blade. when the blades are moving, they move relatively quick and the volume of air is enough to slow it down a few rpm, damaging the feeling/hearing experience. if the motor is strong, it will stay at that set rpm. m,y 3phase half horsepower motor drops 0.2-4 of a hz when in use. (the VFD has a live display showing me what the speed [hz] is set to and what is doing)...
Running the motor at a higher speed and gearing it down via a belt drive would help a lot in regards to speed fluctuation under load.
post #72 of 295 Old 04-23-2015, 04:57 PM
Billy Boden's Avatar
Quoted: 351 Post(s)
Liked: 249
You can also add a flywheel to increase the rotating mass. More mass attached to the motor shaft will act to keep the RPM consistent under varying load.
Billy Boden is offline
post #73 of 295 Old 04-23-2015, 06:19 PM
Quoted: 847 Post(s)
Liked: 774
...putting a flywheel on the motor would help...
Originally Posted by Billy Boden View Post
You can also add a flywheel...
Yes
post #74 of 295 Old 04-23-2015, 06:31 PM - Thread Starter
mtnboydl's Avatar
Quoted: 59 Post(s)
I am thrilled reading all of these discussion points! It will be amazing to see some of these start to pop up as a finished product!
Would there be any benefit to a stiffer fan blade material that could be welded to the swashplate? Eliminate a source of failure/vibration/rattling?
mtnboydl is offline
post #75 of 295 Old 04-23-2015, 07:27 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
so
perhaps a machined/fitted flywheel would make for consistent rpm and change response, the inertia,
as opposed to the extra configuration wrt to pulleys
or a flywheel will make the pulley setup power curve more consistent and smoother < this (?)
post #76 of 295 Old 04-23-2015, 08:23 PM
Quoted: 847 Post(s)
Liked: 774
so
Direct drive is simpler, less things to break/malfunction. One can probably skip the flywheel as well, and just go with a beefy motor. I would check into what Thigpen used. Might even be that his fan hub acts as a flywheel.
post #77 of 295 Old 04-23-2015, 09:27 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
makes sense, beefier probably more cost and time effective compared to the extra engineering wrt alignment of pulleys, machined and balanced flywheel,
definitely ambitious DIY wrt to the OP's approach, doesn't need the "overthink"
post #78 of 295 Old 04-24-2015, 05:02 AM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
The only concern I have is whether the system is a linear translation of woofer displacement to rotor angle.
Just thinking out loud here... Do we know that linear translation of driver displacement to rotor pitch is what we want? We could calculate an ideal of course, but it's not obvious to me that a linear translation is what's needed. I'd think some aerodynamic efficiencies will come into play.
Regardless of the what the ideal rotor pitch response is, it surely won't end up being what's wanted in room. Just like any other subwoofer system, equalization will be needed to tailor the response. So it seems to me that as long as there's a continuous function relating driver displacement to rotor pitch, we need not aim for linear.
Last edited by pitviper33; 04-24-2015 at 05:04 AM. Reason: edit: I typed this response a day ago. I came back to my computer this morning to see that I hadn't clicked "reply".
pitviper33 is online now
post #79 of 295 Old 04-24-2015, 11:34 AM
rhodesj's Avatar
Quoted: 940 Post(s)
Liked: 529
You could readily verify that by measuring the device at different SPL levels and seeing if the result is sufficiently linear. You could possibly even correct it via dynamic EQ. Could be rather simple to deal with.
rhodesj is offline
post #80 of 295 Old 04-24-2015, 12:15 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
a tone generator and a way to measure SPL
square wave or sine
and then a graph
cuts the FUD
post #81 of 295 Old 04-24-2015, 12:17 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
http://www.audiocheck.net/audiofrequ...ator_index.php
post #82 of 295 Old 04-24-2015, 12:19 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
Inquiring minds want to know!
post #83 of 295 Old 04-24-2015, 12:53 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
thanks to noah katz for the dealerselectric link (doing my homework)
looks like a motor and VFD for around or under $250
blades assembly <50 ish
amp should have NO HPF internally designed (thinking re: a PE BASH 300)
blades material as posted, steel etc makes that 500-600 bracket seem "reasonable"
not dauntingly economically unfeasible considering all else that many here have spent, including me . . .
but i'd like to hear more about the (un)-necessity (?) of the inclusion of the DBX bass synth/minidsp units (or alternatives)
where is my 7-8 + HZ signal coming from?
what if I put 4 crowsons and an amp under my floor, can I get something resembling 3.0-3.5 Richter Scale?
post #84 of 295 Old 04-24-2015, 01:03 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
enlarge Level 3 Motion System:
Four Shadow-8 Actuators with a D-501 Amplifier
Premier system designed for multiple individual chairs or a row of 3 or 4 seats with shared armrests. Powered by the D-501 Amplifier.
Price: $ 2,498.00
Frequency response: 5 to 160Hz
just sayin'
post #85 of 295 Old 04-24-2015, 01:27 PM
noah katz's Avatar
Liked: 351
... machined and balanced flywheel...
just get a used large diameter pulley off ebay; if from a reputable mfgr it will prebalanced; look for holes (blind, not through) in the rim
That's a good question to ask; source material with anything that low is very rare.
Perhaps the better reason for a fan sub is to cover the range up to 20 Hz, which gives a huge reduction in the size and power requirements of the conventional subs used to cover up to 80 Hz (or wherever).
Oh wait, you need a huge volume for the fan sub...
Noah
post #86 of 295 Old 04-24-2015, 01:52 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
So
a majority of bassheads here have the 15 hz +/awesome SPL rangs well in hand,
but
if a new enthusiast were starting out building a HT from scratch in a dedicated room . . .
a pair of these would be a good start
after looking at cost/benefit ratio, without some method to get a usable signal to retrofit /integrate with existing subs
why?
for $3K+ I can get 2 of the new mini room correction gizmo's,, maybe an Outlaw 7 channel amp , re-do my whole 7.3.4 ATMOS set up and bliss out
but
the rabbit hole beckons . . .
so what about the bass synth/minidsp combo
the real engineers here know WAY more than me (surface skimmer)
please speak up
post #87 of 295 Old 04-24-2015, 03:30 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
THKTFC HGCQMZ QX MEDMYQC. QIMF'HH QMHH FXR KITQ
ALWAYS LISTEN TO EXPERTS THEY LL TELL YOU WHAT
WTZ'Q AM OXZM TZO KIF. QIMZ OX GQ.
CAN T BE DONE AND WHY THEN DO IT
- YXAMYQ IMGZHMGZ
Always listen to experts, they'll tell you what can't be done and why.
Then go do it.
Robert Heinlein
ROBERT HEINLEIN
post #88 of 295 Old 04-24-2015, 04:57 PM - Thread Starter
mtnboydl's Avatar
Quoted: 59 Post(s)
Anyone with patent experience in all of these posts? I came across US patent #8,804,986 with some relevant linked historical patents.
Would any of this prevent someone from assemblind all necessary parts into a single order package?
mtnboydl is offline
post #89 of 295 Old 04-24-2015, 05:10 PM - Thread Starter
mtnboydl's Avatar
Quoted: 59 Post(s)
Thigpen has a handful of audio patents, but none in relation to airfoil generated transduction
mtnboydl is offline
post #90 of 295 Old 04-24-2015, 06:05 PM
asarose247's Avatar
Quoted: 804 Post(s)
Liked: 606
can we get ANY data, charts, graphs, anything? from . . . anybody? . . .anywhere?
how about the builder, he can't be sitting around waiting for someone to create for this thing
something this awesome could not have been built once right the first time, without testing and a few "oop-sies"
where did they get the testing material from, what criteria, and where ,yadda, yadda ,yadda
and then someone saying "what if?" probably a bunch
building from the reverse engineering shown is real (I had a damn dream about this thing, woke me right up at 2 am this morning)
I can visual this, plenty of minor parts, steel plate, the power,
making it relevant/useful/integrated is getting to be another challenge . . .
