Buttkicker, INuke 3000DSP, Speakon Newb - AVS | Home Theater Discussions And Reviews
post #1 of 4 Old Yesterday, 08:48 PM - Thread Starter
brilong's Avatar
I currently have two Buttkicker Advance BK4-4 units I'm trying to get running. I tried powering them on the L/R channels (4-ohm load each) off an old Yamaha RX-V630 and wasn't impressed (I had to alter my main receiver LFE output to +6 dB and crank it). My fallback plan is to get the famed INUKE 3000DSP.
I ran 4-conductor 12ga wire (50-ft currently, plan to reduce to ~35 ft) and planned to run each speaker on its own channel, but with the INUKE, I believe I would run them in series on Channel A. How do you recommend I wire up the single SpeakOn connector using my existing cable?
I could wire-nut two conductors of my cable at the amp side creating a serial link (doubling the length of cable) or I could use just 2 conductors of the existing cable and use a different cable between the two Buttkickers. Would running a 2-ohm or 8-ohm load be recommended in this instance? Would it be better to run these Buttkickers in parallel?
What about if I add two additional Buttkickers in the future (with a different cable)? I'd like the additional Buttkickers to have a different volume than the first two (in case my wife wants it turned off for example). I plan to use Channel B for this.
My current notion is to use +1, -1 from Channel A on two conductors of my 4C cable to + on BK #1 and - on BK #2 ; then run a new jumper wire between the two BK's giving the INUKE an 8-ohm load.
Thanks for your recommendations.
Definitive Technology ProMonitor 80 x 4, ProCenter 100, ProSub 80
BenQ W1070 Projector
Yamaha RX-V775WA
Ultimate Home Theater Fusion Escape seating
Buttkicker Advance
brilong is online now
post #2 of 4 Old Yesterday, 09:45 PM
More is Better's Avatar
Quoted: 196 Post(s)
Liked: 124
+1 and -1 on the speakon...yes
I would run the speakon cable to the center of the buttkickers then splice 2 lengths of speaker wire like 2 arms of a Y or T onto it going to each buttkicker. 1 long run from the amp, 2 short arms to the shakers.
Put both in parallel on one channel for 1000ish watts at 2ohms, all 3 of the +'s and all the -'s together, then use the power limiter in the dsp to dial the power down some.
Use the 2nd channel later for 2 more. DSP will let you do each pair/channel individually.
More is Better is offline
post #3 of 4 Old Today, 04:49 AM - Thread Starter
brilong's Avatar
If that's the case, I can keep a single run of 4-conductor wire in place and wire it into the Speakon +1, -1, +2 and -2 for future use. I re-checked the cable length / ohms chart and it appears I'm good to ~30-ft with 12ga wire. I estimate my final distance around 35 ft.
Right now my 50 ft of 12ga is sitting on the floor; I've not run it in the wall or hidden it behind the baseboard just yet as this is a retrofit job.
Yamaha RX-V775WA
Buttkicker Advance
post #4 of 4 Unread Today, 07:56 AM
Quoted: 196 Post(s)
Liked: 124
Sounds like a plan, 12ga is fine for your purpose.
