Gen II Crown XLS Drivecore - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
post #391 of 408 Old 02-01-2017, 03:20 PM
Quoted: 17 Post(s)
Liked: 5
Your system looks great. And at least you can listen to it. Mine isn't done yet! The furniture is IKEA Besta that I hacked. I floated shelves, made backgrounds to my TV years before they thought of it. I also custom routed out some of their doors to make speaker grills. In the photos you can see my old TV that I need to replace. Also a missing door... which will go on once the middle atlantic rack is hot. Also added an APC power backup so I can stop the Dirextv resets when the power flickers! If your patient you can get some awesome deals. Like that rack... paid $125 for it.
Sent from my SM-N920T using Tapatalk
mmrogge is online now
post #392 of 408 Old 02-01-2017, 03:20 PM
Quoted: 17 Post(s)
Liked: 5
Where's your xmc-1
post #393 of 408 Old 02-01-2017, 03:57 PM
malmstump's Avatar
Quoted: 90 Post(s)
Liked: 320
Originally Posted by mmrogge View Post
Where's your xmc-1
i don't have an xmc 1 ,running an onkyo 818 and it works great as my preout voltage is sufficent even at 1.4 v setting , ya love your speakers and how they can be behind the screen
fronts klipsch klf-30
center klipsch klf c-7
wides klipsch klf-20 s
surrounds klipsch klf-30 s
onkyo txnr-818
3 crown xls 1502 1 xls 2502, HSU vtf-15 mk 2
malmstump is online now
post #394 of 408 Old 02-01-2017, 03:59 PM
Quoted: 17 Post(s)
Liked: 5
I'm good with seeing the speakers out... but wanted to build the ikea piece so had a figure a way to enclose them
malmstump likes this.
post #395 of 408 Old 02-02-2017, 08:11 AM
malmstump's Avatar
Quoted: 90 Post(s)
Liked: 320
what do you think about bridging your center speaker ?did you notice any more power? can you crank it up loud still ? how does it compare to running it in normal vs bridging ? i m very curious
onkyo txnr-818
post #396 of 408 Old 02-02-2017, 11:27 AM
Quoted: 17 Post(s)
Liked: 5
I haven't powered on my syatem yet. Still running wire and missing xlr to connect the amps. I will bridge the center but only because of have no use for the extra channel. I have soooooo much overhead power there's no logical advantage to bridge or not to bridge the center. At least from what I understand. Had 2 big setbacks this week... so definately waiting now on the money to move forward. Had a damn pipe break in the bathroom wall and my laptop hard drive crashed. Just can't win!
post #397 of 408 Old 02-02-2017, 02:50 PM
malmstump's Avatar
Quoted: 90 Post(s)
Liked: 320
sorry about your hard drive crashing and pipe mmrogge ,always happen in threes bro .
i can't wait untill you power on your system and review how it sounds dude ,will be killer .
i to have a channel unused for my center and wanna experiment with bridging
onkyo txnr-818
post #398 of 408 Old 02-14-2017, 02:12 AM
Dmitry Pavlov's Avatar
Hey guys,
I recently purchased a crown XLS 2002 and I can hear a slight hiss from the inside of the amp (supposedly a PSU hiss). It's >15kHz, so not too bothersome, yet in a dead silent room I can even hear it from two meters away from the unit. Does your crown hiss internally too? Is there anything I can do to make it truly silent (except for wrapping it in a blanket)? Most users complain about tweeter hiss when using those amps but I don't have that problem (using XLR connection).
Funny thing, I switched from a class AB amp with rumbling PSU to a class D amp with hissing PSU. It's a catch 22 situation.
Dmitry Pavlov is offline
post #399 of 408 Old 02-16-2017, 11:25 PM
malmstump's Avatar
Quoted: 90 Post(s)
Liked: 320
Originally Posted by Dmitry Pavlov View Post
Hey guys,
hi Dmitry,can switch to rca and see if you have the hiss still? did you ty to do a factory reset ? i would start there then come back and let us know ,all the best
onkyo txnr-818
post #400 of 408 Old 02-16-2017, 11:55 PM
well the noise is coming from the unit itself, not from the speakers and I would describe it as electrical.
post #401 of 408 Old 02-17-2017, 06:25 AM
Quoted: 17 Post(s)
Liked: 5
Try lowering the volume on the front of the amp to 75% and see if it goes away
post #402 of 408 Old 02-17-2017, 09:44 AM
VisionxOrb's Avatar
Quoted: 121 Post(s)
Liked: 84
2 separate amps, 2 separate power supply designs. Both make noise. Maybe there is sever electrical noise on the line cause the PS to make noise. Could try a filter/power conditioner.
2000 watts of power and climbing
-Fred
VisionxOrb is offline
post #403 of 408 Old 02-21-2017, 06:21 PM
Nibrok's Avatar
Hi guys, can anyone recommend which amps to go with for my Klipsch setup? I was thinking of maybe just going with 4 of the 1002's, bridging them at 700w/8Ω for my LCR and the other one to handle each of my surrounds. Will this work OK with my receiver? I figured I'd let the receiver run my Atmos ceiling speakers.
Thanks in advance!
AVR: Marantz 6011
L/R: RP-280's (600w peak)
C: RC-64 II (800w peak)
Surrounds: R-5800-W II (200w peak)
Nibrok is offline
post #404 of 408 Old 02-21-2017, 07:29 PM
Quoted: 17 Post(s)
Liked: 5
Don't confuse RMS vs Peak power.
RC-64II - Power Handling 200W RMS / 800W Peak
Klipsch are very efficient speakers. In my opinion you should setup the amps like mine. Look back in the thread to see. There simply would be no benefit to bridging the amps for the LCR. But consider the 1500 series amps if your using them unbridged
post #405 of 408 Old 02-22-2017, 01:49 AM
biliam1982's Avatar
Quoted: 412 Post(s)
Liked: 199
Thanks in advance!
AVR: Marantz 6011
How many surrounds do you have and how many ATMOS speakers are you planning? How far is your seating from the main listening position?
Your receiver has 9 amps rated at 110 watts per channel and those Klipsch have very high sensitivity. I don't think you even need the Crowns and could use the money elsewhere.
Why are you thinking about buying them? Do you feel/hear your receiver being strained trying to push your speakers to reference level? Do you even listen to volumes that loud?
biliam1982 is online now
post #406 of 408 Unread 03-28-2017, 06:07 PM
Liked: 0
Hi
I have m&k s150 system and a marantz 8801 processor. I Want to upgrad my AMP Audiolab 8000x7 to Crown xls series.
But some tells me NOT to it and go for it. But is there someone here has head this setup?
And what Will you recommed of AMP ?
Vilstrup is offline
post #407 of 408 Unread Today, 07:35 AM
aravindhan's Avatar
I use just 1502 to power my front left and right with onkyo 818, but yesterday, i tried the XLR output of my oppo to 1502 and it was quite brilliant. With onkyo pre-outs, i had to putt 1502 at 100% gain, but with XLR, my oppo was at 50% volume level. The depth and sound stage was quite astounding.
I haven't tried the high gain setting and, but will try and see if it can match the XLR input performance.
I would suggest you switch to high gain settings to see if you can improve your sound stage.
aravindhan is online now
post #408 of 408 Unread Today, 12:42 PM
BassThatHz's Avatar
Quoted: 2127 Post(s)
Liked: 1713
Originally Posted by NWCgrad View Post
Originally Posted by vitod View Post
Hmm...these Crowns will have high prices, soooo....why would I get them if an Inuke 6000 is way cheaper. Convince me.
Behringer:
1.37kW into 8 Ohms, 2.05kW into 4 Ohms for full-range or mid-top duty
1.16kW into 8 Ohms, 1.80kW into 4 Ohms for Bass duty
If price is driving variable then Behringer is always the go to brand. However I dont like their lack of power factor correction, requirement for a fan modification and the THD numbers in higher frequencies for driving mains. I dont need 2 kW for driving 96 dB efficient speakers in my basement general purpose/HT room. Cost is still pretty small compared to standard brands.
Only a few amps have PFC. The iTechs, powersoft k/x, gruppen plm.
The fp's don't, speakerpower don't, behringer don't, entry crown's don't, most qsc's don't, cv's don't.
BassThatHz is online now
