Duratex - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By madhuxs
  • 2 Post By Face2
post #1 of 24 Old 06-04-2015, 08:37 PM - Thread Starter
jason171717's Avatar
Quoted: 115 Post(s)
Liked: 49
Duratex
How long after applying the second coat do i have to wait to reinstall the woofers and tweeter etc?
jason171717 is offline
post #2 of 24 Old 06-04-2015, 08:45 PM
michaelddd's Avatar
Quoted: 321 Post(s)
Liked: 207
Depends on the temp and humidity of the room the cab is in. Duratex dries dry to the touch in a few hours, but it's not fully CURED until about the 7-day mark. The "full cure time" is significantly reduced if you can put the cabs outside in the sun on a 80+ degree day or if you can make "a hot booth" with plastic sheets and electric heaters.
That's the long and proper answer. The short answer is this: If you don't care if you smudge/damage the duratex hidden by the mounting surfaces of the drivers, wait 48 hours and install them.
michaelddd is offline
post #3 of 24 Old 06-04-2015, 08:50 PM - Thread Starter
Quoted: 115 Post(s)
Liked: 49
Im canadian do you have that number in celsius haha! How reduced can that time be if in the sun on a hot day like tomorrow?
post #4 of 24 Old 06-04-2015, 09:09 PM
Fattykidd's Avatar
Quoted: 494 Post(s)
Liked: 403
26ish degrees dude.. is it really humid where your at? Might want to give them a little longer if it's real muggy..
Fattykidd is offline
post #5 of 24 Old 06-04-2015, 09:20 PM
michaelddd's Avatar
Quoted: 321 Post(s)
Liked: 207
I have read somewhere, probably on Acryltec's website what the optimum curing conditions are for Duratex. What I know for sure is that the stuff likes heat. I've used the stuff for the past 8 years or so and have lots of experience with it. At least the rolled-on kind. Never used the spray stuff yet.
After a few hours it feels dry to the touch and you can roll on another coat. But if you try to pickup the cab the Duratex will come off on your hands. It doesn't so much "dry" as it does "cure."
The BEST advice is to just let it dry for at least 7 days, assuming you're the average DIYer and are Duratexing cabs in your garage/back patio/kitchen when the wife's not home. But hey, see my original post. After a couple of days it won't be rock-hard, but it'll be hard enough that you can mount drivers and move the cabs...gently.
post #6 of 24 Old 06-04-2015, 10:44 PM
Quoted: 111 Post(s)
Liked: 31
I put a heater in my work space and got it up to about 90 degrees. Could apply the 2nd coat after about 40 minutes.
I did let the duratex harden up for a few days before I stated moving the cabinets around.
jake515 is online now
post #7 of 24 Old 06-05-2015, 06:06 AM
Stereodude's Avatar
Quoted: 3093 Post(s)
Liked: 2239
I put two 1000+W space heaters along with a house fan (for stirring the air) in the smallest room in my house, a bathroom, got the temperature up to 120F and made my own curing oven when dealing with Duratex on Sonotubes. It still took several hours to cure the Duratex.
ps: sonotube absorbs moisture from waterbased finishes and expands noticeably which makes getting a smooth, nice finish difficult because you get tearing at the seams after it contracts.
Stereodude is offline
post #8 of 24 Old 06-05-2015, 06:07 AM
Bill Fitzmaurice's Avatar
Liked: 4663
DuraTex needs high heat to cure properly. The easiest way for the DIYer to cure it is to put the cab in the sun for a couple of days. If you don't chances are the drivers will stick in place if you ever need to pull them.
Bill Fitzmaurice is online now
post #9 of 24 Old 06-05-2015, 07:44 AM
likelinus's Avatar
Quoted: 120 Post(s)
Liked: 51
Nice cut and paste job. Fyi - wrong thread.
likelinus is offline
post #10 of 24 Old 06-05-2015, 08:18 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
It was not a cut and paste it was original !
Lol I was just in the wrong reply box
Mfusick is offline
post #11 of 24 Old 06-05-2015, 08:24 AM
likelinus's Avatar
Quoted: 120 Post(s)
Liked: 51
Lol I know, I was playing. I didn't mean The content wasn't original, but you posted the same reply in The correct thread. I doubt you typed that out twice
post #12 of 24 Old 06-05-2015, 08:28 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
I copied it from here and pasted to the correct place, and meant to delete here after but forgot. I'm on vacation and kids stole my attention, but they sleeping now.
Mfusick is offline
post #13 of 24 Old 06-05-2015, 10:18 AM - Thread Starter
Quoted: 115 Post(s)
Liked: 49
No thankfully it was a dry heat, only started raining today.
post #14 of 24 Old 06-05-2015, 10:19 AM - Thread Starter
Quoted: 115 Post(s)
Liked: 49
Yea in the sun yesterday and today i was able to move em gently without issue
post #15 of 24 Old 06-05-2015, 10:22 AM - Thread Starter
Quoted: 115 Post(s)
Liked: 49
Yea, i had them under the sun roof with the hole deck cordoned off with plastic not sure how hot it got but it hardened very quickly.
Thanks BFM
post #16 of 24 Old 06-05-2015, 10:24 AM - Thread Starter
Quoted: 115 Post(s)
Liked: 49
I was wondering what you were talking about
post #17 of 24 Old 06-15-2015, 02:18 PM
Quoted: 243 Post(s)
I would like to paint my sub cab with a metallic furniture paint by Rustoleum. If I am not happy with the results I plan to paint duratex over it. Does duratex stick on previously painted surfaces?
Speakers: Boston Acoustics VS260, VS325C; JBL Studio 590
Subwoofers (sealed): Dayton UM18, 2x Infinity 1260 dual opposed + iNuke6000DSP
AVR: Yamaha RX-A2000
madhuxs is offline
post #18 of 24 Old 06-15-2015, 02:55 PM - Thread Starter
Quoted: 115 Post(s)
Liked: 49
I am not sure about it, I have some rustoleum somewhere and if i can find it i will try duratexing over it to see what happens. I take it this cab is MDF?
So far i have only done two speakers in duratex, one pair of 5 cuft and one pair of 2.5 cuft. Neither of which had ever had paint on them before so i sanded, dry wall spackled then painted (after brushing the dust off).
post #19 of 24 Old 06-15-2015, 05:04 PM
Quoted: 243 Post(s)
Yep, it's MDF. I have some duratex but I haven't unpacked it. If the furniture paint looks good I plan to return the duratex.
jason171717 likes this.
madhuxs is offline
post #20 of 24 Old 06-15-2015, 07:58 PM - Thread Starter
Quoted: 115 Post(s)
Liked: 49
Be sure to post the results i have considered that kind of paint before but never have seen it done, and look good
post #21 of 24 Old 06-16-2015, 07:21 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
There was a thread of duratex alternatives and a lot of guys have used that deck restore paint.
Mfusick is offline
post #22 of 24 Old 06-16-2015, 07:28 AM
Face2's Avatar
Quoted: 334 Post(s)
Liked: 202
It appears that deck restore paint gets better reviews for speaker use than actual deck use, lol.
With that said, I'm still very happy with Duratex.
Stereodude and jason171717 like this.
Face2 is offline
post #23 of 24 Old 06-16-2015, 09:47 AM
Quoted: 243 Post(s)
I'll try the rustoleum only if someone can confirm that it will adhere to enamel painted surfaces...
madhuxs is offline
post #24 of 24 Old 06-21-2015, 06:13 PM - Thread Starter
Quoted: 115 Post(s)
Liked: 49
I have to agree with that one!
