Replacing Drivers Please Help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old Yesterday, 01:49 PM - Thread Starter
Liked: 0
Hello all,
I have an ancient enclosure that I want to re-use and replace the drivers in as the original ones are completely destroyed. It's a ported enclosure with a volume of about 1 cubic ft and has spaces for a 3" tweeter and an 8" woofer. I will be replacing the crossover with whatever I need.
What Driver suggestions do you have? How much should I look at spending if I want middle of the road performance?
Any help is greatly appreciated!
Sterlingr is offline
post #2 of 3 Old Yesterday, 07:17 PM
Samps's Avatar
Quoted: 410 Post(s)
Liked: 192
Why do you want to reuse this "ancient" cab? Save yourself a ton of trouble and build a proven kit. The flat packs are cheap and easy to assemble. If you're worried about a good finish use duratex.
If you really want to try something new. Please search around and do some research to get an idea of what you're getting into. It's not impossible but it will be a long road.
Samps is online now
post #3 of 3 Old Today, 11:44 AM
awblackmon's Avatar
Quoted: 28 Post(s)
Liked: 36
A call to Parts express can help you with drivers for you cabinet. They have a staff which I have heard is very helpful with suggesting DIY projects and replacement speakers. Good luck.
Mitsubishi 3800 projector onto 103 inch DIY AT screen.
Marantz 8802A 7.3.4. Sound ably handled with legacy Minimus 77 and Minimus 7 speakers
DIY IB sub system. Two pairs of Dayton 15 inch and one pair of JBL 12 inch.
Power amps used are Harman Kardon Signature 2.1 Kenwood KM-X1 Kenwood KM 106 Hafler DH200
awblackmon is online now
