Cloverfield blew my sub - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 54Likes
post #61 of 80 Old 08-16-2015, 09:08 AM
Fatshaft's Avatar
Quoted: 591 Post(s)
Liked: 909
Fatshaft
Is either
1) deaf and or insane
2) doesn't have reference calibrated correctly
+15dB would be approaching 120dB spl levels on the mainspeakers! In that movie, with all the continous screaming and monster noises it would be way way way behind comfortable for most anyone. Unless you are only talking about just running the bass 15dB hot, which might be fun for a short clip, but would still be nothing short of a beating for that particular full movie. Whoa indeed.
I'll break it down so you can understand more clearly
Fatshaft is either
Deaf?
Far from it...at 51 I can still hear 14Khz fine
I can hear my neighbor with "Tourette syndrome" very clearly with his and my windows closed
My ears are very sensitive and they can take a lot of abuse
Insane?
CLEARLY YES! I say that cause ALL my friends think I am.
I have no problems with that!
WOW...Really?
Yes I do have a reference calibrated correctly...I invite you to come and see it for yourself
The above graph was taken at -18MVL... Could go MUCH higher but my mic clips.
My system was calibrated using the "AudioTestDVDv2" DVD that's available here at AVS
I've learned a lot from AVS and have a pretty good idea what I'm doing.
Yes it is extremely loud but I can and I don't...only on very rare occasions
@Archaea , I don't get the purpose of your post AND I did not watch that movie @ +15DB over reference...it was a joke!
As a matter of fact, I've never seen that movie and am NOT interested in it.
FYI, I can play a movie @ 15DB over reference if I wanted to because my referenced system is capable of doing it.
ID:	889826   Click image for larger version
ID:	889906   Click image for larger version
My Build Thread
Equipment Speakers:
3x 1099's for LCR duty
4x Fusion 8's for surround duty
8x subs: 4x FTW21's and 4x SI18's
Fatshaft is offline
post #62 of 80 Old 08-16-2015, 09:19 AM
Stereodude's Avatar
Quoted: 3454 Post(s)
Liked: 2523
I'd say it's highly unlikely that you can play back a bass heavy "action" movie at 15dB over reference without getting major clipping from your receiver / pre-pro.
As an example, a Denon 4520CI will clip the LFE output at 0db (reference) on the master volume with the subwoofer trim at 0dB with a 0dBFS signal in the LFE channel (around 4.7Vrms). The Pioneer Elite and Onkyo units I've measured have had a few more dB of output capability getting to up ~8Vrms before clipping, but +15dB from reference... I don't see how.
Stereodude is online now
post #63 of 80 Old 08-16-2015, 09:22 AM
johnson636's Avatar
Quoted: 408 Post(s)
Liked: 155
Originally Posted by Stereodude View Post
Welcome to Clipping City, population Gary147852.
Clipping indeed. I don't use neirfield subs, do the require more power or does it depend on the room?
johnson636 is online now
post #64 of 80 Old 08-16-2015, 09:25 AM - Thread Starter
Gary147852's Avatar
Quoted: 228 Post(s)
Liked: 45
From what I experienced, you do have to push the sub much harder. But that tactile feedback though.
Vizio M501d-A2R(Calibrated), LG BD-330, Pioneer VSX-524-K, Custom DIY LCR Mains, DIY Sub ( Kicker 10c124, 2.25 ft3, 19 hz tune, powered by xm-sd46x(using only rear channel in bridge mode, 150watts), powered by 400w atx power supply.) Work in progress.
Gary147852 is offline
post #65 of 80 Old 08-17-2015, 02:53 AM
Macroblocker's Avatar
Quoted: 110 Post(s)
Liked: 40
Originally Posted by Gary147852 View Post
Time to order my 1260w!!!!!!!!!!!!
Sent using Tapatalk since the mobile version is still 👎
OMG i thought it was just me!!!! Cloverfield blew my Sub too!!! was under warranty so no issues , while the settings seem fine for most movies i should have dialed it down a notch for Cloverfield
azz7686 likes this.
Macroblocker is online now
post #66 of 80 Old 08-17-2015, 05:28 AM
johnson636's Avatar
Quoted: 408 Post(s)
Liked: 155
What sub do you have? Amp? How loud were you playing the movie when your sub blew? What did you have your sub trim set to? When I first watch cloverfield, I had a cheap sony sub I think, so I ordered Cloverfield last night and I will watch it again with my current setup. Now my current setup isn't as Badazz as the heavy hitters that have posted in this thread, (such as @Stereodude @Fatshaft @Archaea ) but it will do for now
post #67 of 80 Old 08-17-2015, 05:42 AM
Stereodude's Avatar
Liked: 2523
I'm certainly no heavy hitter. More of an adequate hitter for the SPL levels I listen at (below reference).
post #68 of 80 Old 08-17-2015, 05:46 AM
Bassment's Avatar
Quoted: 946 Post(s)
Liked: 379
Wait, you haven't seen Cloverfield fatshaft, and you don't want to watch it? How is it not your type of movie, it's just a huge bassfest lol.
Bassment is offline
post #69 of 80 Old 08-17-2015, 11:54 AM
Quoted: 110 Post(s)
Liked: 40
well this was back in 08 when Cloverfield came out on blu ray and back then i had a eD sub, anyone here remember them ? (Elemental designs) it was the A300 they made with the 12" woofer , my next sub will be a HSU
post #70 of 80 Old 08-17-2015, 12:58 PM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
You haven't had a sub in seven years?
BllDo is offline
post #71 of 80 Old 08-17-2015, 01:09 PM
Quoted: 110 Post(s)
Liked: 40
i said it was under warranty so they replaced the woofer free , i continue to use that sub today
post #72 of 80 Old 08-17-2015, 02:06 PM
lalojamesliz's Avatar
Quoted: 24 Post(s)
So the monster from Cloverfield showed up at your house and physically destroyed your sub, or did you mean something else?
nice
lalojamesliz is offline
post #73 of 80 Old 08-17-2015, 02:07 PM
johnson636's Avatar
Quoted: 408 Post(s)
Liked: 155
well this was back in 08 when throwingrfield came out on blu ray and back then i had a eD sub, anyone here remember them ? (Elemental designs) it was the A300 they made with the 12" woofer , my next sub will be a HSU
You should be able to DIY a sub that crushes the HSU. Just throwing that out there. Depending on which HSU sub you're eyeing, the diy sub will cost close to, or be the cheaper option.
post #74 of 80 Old 08-17-2015, 02:09 PM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
You've been using the same sub for seven years?
BllDo is offline
post #75 of 80 Old 08-17-2015, 02:12 PM
Quoted: 110 Post(s)
Liked: 40
Sad but true ! Soon to change though lol
post #76 of 80 Old 08-17-2015, 02:14 PM
stitch1's Avatar
Quoted: 323 Post(s)
Liked: 265
There's nothing wrong with that. I've been using mine at least that long. I am in the process of upgrading to SI 18's. But I have had my SVS 12 since 2007. Still going strong.
stitch1 is offline
post #77 of 80 Old 08-17-2015, 02:20 PM
bass addict's Avatar
Quoted: 441 Post(s)
Liked: 507
Originally Posted by wldkrd1 View Post
OR....he's manually typing out his signature on his phone at the end of every post...TWICE.
I find that much less annoying than quoting each post separately as opposed to multi quoting. Just sayin.
Achievement Unlocked
Psychotic Episode Averted
bass addict is offline
post #78 of 80 Old 08-17-2015, 05:07 PM - Thread Starter
Gary147852's Avatar
Quoted: 228 Post(s)
Liked: 45
She's back alive and kicking.
Sent from my HTC Desire 626s using Tapatalk
post #79 of 80 Old 08-17-2015, 05:11 PM
stitch1's Avatar
Quoted: 323 Post(s)
Liked: 265
Video is private.
stitch1 is offline
post #80 of 80 Old 08-17-2015, 05:13 PM - Thread Starter
Gary147852's Avatar
Quoted: 228 Post(s)
Liked: 45
Originally Posted by stitch1 View Post
Video is private.
Fixed.
