New MartyCube Build, help needed - AVS Forum | Home Theater Discussions And Reviews
Old 09-04-2015, 07:13 PM - Thread Starter
Liked: 0
Short and sweet. If anyone could send me down the right path, i would greatly appreciate it. I want a new sub for my downstairs tv room. 17x19x8' is the size of my room. I want to stick with a marty cube build but what to go with? 15 ultimax or something else with iNuke 3000dsp? DA SP1000? Just need something that will sound great in my room and not wanting more (realistically). Hell, for the last 2 years, Ive thought my JBL Sub12 sounded good. Budget for components is around 500
Short and simple, what do i do with the marty cube box?? go!
Thanks in advance
cw84 is offline
Old 09-04-2015, 07:22 PM
eng-399's Avatar
Quoted: 1286 Post(s)
Liked: 1731
For a budget sub buy a Stereo Integrity HT-18 D-4 with a Inuke 3000 DSP amp. I would suggest a better sub but you do have a 500$ budget. If you buy a 15" sub it will be hard to fill the room and also with a single 18" sub. You really need to increase your buget some more and get 2 18's in there. Do a search for the Marty box you won't go wrong. There's also flat packs that you can buy to for the sub.
eng-399 is online now
Old 09-04-2015, 10:05 PM
LTD02's Avatar
Quoted: 2341 Post(s)
Liked: 2577
I don't know if the d4 is the best idea in a smallish ported cab. 460ho may be a better choice. p.e. has coupons this weekend.
Listen. It's All Good.
LTD02 is offline
Old 09-05-2015, 06:46 AM
Quoted: 89 Post(s)
Since the specs changed on the SI HT 18, have you done modeling to see how it compares to the HO in the Marty cube now?
Thanks, Dr. H
Dr. H is offline
Old 09-05-2015, 09:45 AM
LTD02's Avatar
Liked: 2577
that's with about 1,000 watts into each.
red rss460ho martycube
green 18htd4 martycube
blue 18htd4 4 c.f. sealed
that's how it shakes out with these numbers. it's not like it won't work or anything, just isn't really optimized imho.
i'm not sure if they are 100%, but that's what i've got at the moment. if there is another update, i'll change the chart. here is the measurement.
posted here:
HT 18 D4 TS Parameters
and those are reasonably consistent with what matt (mtg90) posted:
Anyone have an accurate SI 18" 4ohm VC winISD file ?
ID:	925914   Click image for larger version
LTD02 is offline
Old 09-05-2015, 12:39 PM
eng-399's Avatar
Liked: 1731
The 460 does look better I keep forgetting the specs have changed in the ht-18. I wonder why SI. Changed the specs on it and what changed on the sub from before?
Old 09-05-2015, 06:07 PM
Augerhandle's Avatar
Quoted: 747 Post(s)
Liked: 649
Cool
I don't think the specs were changed, but they were finally measured by third parties. SI continues to only list the specs for the D2 version. http://stereointegrity.com/product/h...specifications
Name:	Capture HT18 parameters.JPG
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
