EP2500 lower output than EP1500? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-06-2015, 02:39 PM - Thread Starter
ClintonH's Avatar
Quoted: 101 Post(s)
Liked: 49
So I got a used EP2500 off ebay today.
Set it up in place of my EP1500 which has been bridged to my 15" LMS-4000 for the last 7 years. Figured the EP2500 would sound louder and have more head room. When hooked up it sounded quiter and clipped far easier than the 1500, had to back it down to 15 to keep the light out.
I have all the Dip switches exactly the same as one another, same feed from a MIC2200 and same movie passage to test them out. The begining of Edge of Tomorrow.
EP1500 SLP meter 1 foot way 119 db Same setup with the EP2500 116 db both bridged.
Any suggestions on what I would start to look at or is it possible for a amp to put out less power due to age/use? Not sure if I should call this a defective amp or am I looking at this the wrong way?
ClintonH is offline
post #2 of 16 Old 11-06-2015, 04:44 PM
N8DOGG's Avatar
Quoted: 1111 Post(s)
Liked: 1211
The dip switches are messed up on the 2500. Post how you have them setup.
N8DOGG is offline
post #3 of 16 Old 11-06-2015, 04:52 PM
More is Better's Avatar
Quoted: 620 Post(s)
Liked: 344
I have one ep4000 that drives subs to about half the excursion of my other ones. Sounds fine and works fine for mains, or I just don't miss the extra power. If I didn't have multiples to compare, I never would have known.
More is Better is offline
post #4 of 16 Old 11-06-2015, 05:20 PM - Thread Starter
ClintonH's Avatar
Quoted: 101 Post(s)
Liked: 49
Here is how they are set, seems to be what I found which is the exact way my EP1500 is set.
1- R
2- L
3- R
4- L
5- L
6- R
7- R
8- R
9- L
10- L
ClintonH is offline
post #5 of 16 Old 11-06-2015, 05:22 PM - Thread Starter
ClintonH's Avatar
Quoted: 101 Post(s)
Liked: 49
Well that doesn't sound great. lol
Reason I bought this was to up the power from my current amp not lower. Good thing it was cheap.
ClintonH is offline
post #6 of 16 Old 11-06-2015, 07:48 PM
Shan87's Avatar
Quoted: 16 Post(s)
Liked: 27
Gain knob setting on both channels? I think you have to have channel 2 all the way down in bridge mode. You probably do but figured I'd ask anyway.
Shan87 is offline
post #7 of 16 Old 11-06-2015, 09:01 PM - Thread Starter
ClintonH's Avatar
Quoted: 101 Post(s)
Liked: 49
Yeah sorry gain knob down to 0 on channel 2 and 15 on channel 1, it clips at about 16 ish.
ClintonH is offline
post #8 of 16 Old 11-07-2015, 12:17 AM
Quoted: 620 Post(s)
Liked: 344
1- R
2- L
3- R
4- L
5- L
6- R
7- R
8- R
9- L
10- L
Off the top of my head 1 2 3 should be the same as 10 9 8.
I'm gonna go look at mine.
Try this:
Turn the amp off.
Unplug the input 2 xlr or 1/4".
Push all the dip switches to the left. I know that is wrong.
Push all the dip switches to the right, one at a time, and make sure they all click.
Power it up and try it.
post #9 of 16 Old 11-07-2015, 08:13 AM
N8DOGG's Avatar
Liked: 1211
Is there any way to test it in stereo? I've had both the 1500 and 8 x 2500/4000. It had way more power than the 1500.
N8DOGG is offline
post #10 of 16 Old 11-07-2015, 08:40 AM - Thread Starter
ClintonH's Avatar
Quoted: 101 Post(s)
Liked: 49
Try this:
Turn the amp off.
I can try this out Tomorrow, gone to my Mom's 80th Birthday today. It's a all day event. lol
As in do I have more than one sub, no not at the moment I only have one built. I can test it with 2 by the end of this week, I have 2 more subs waiting for boxes to be built.
Is there something that stero mode will tell that bridged doesn't? And are the dip switches in the correct order for bridged then?
ClintonH is offline
post #11 of 16 Old 11-07-2015, 11:09 AM
BassThatHz's Avatar
Quoted: 2345 Post(s)
Liked: 2108
Try this and see if it works better.
1- L
2- L
3- L
4- R
5- R
6- R
7- R
8- L
9- L
10- L
If you have a multimeter you can measure the voltage when it isn't connected to a subwoofer and playing a 60hz sinewave.
You can put the amp back into stereo mode and test each channel, my guess is that one of the channels isn't working as good as the other.
Behringer is known for horrid QC and Ebay is shady at the best of times.
Ideally you should have bought new so that you'd have a warranty.
I have a rule of thumb with purchases:
If it is above $2000 always buy new (because it is too expensive to go wrong.)
If it is below $500 always buy new (because it is too cheap to be true or there is something wrong with it!)
Even so, I've still been burnt.
I've bought 12 AV products off ebay ranging from $100 to $5000 over the years, and I've been burned 5 of those times, all 5 needed repairs of some sort to make them work as intended and that was not disclosed. It's like playing Russian Roulette.
For example: I bought a $2200 Fluke meter for $1100 off Ebay, used it 20 times over a few months and it failed. The product was over 11 years old and the seller said lied about the age and condition. It now needs to be repaired, which will cost $1200, the total cost of a new with 5 year warranty.
It is crap like that that makes me never want to use Ebay ever again, but some things can only be found on Ebay as they are discontinued and/or the new comparable models are FAR TOO expensive. Emotiva UMC-200, Rotel 9 or 10 series, most B&W speakers, and Crown MacroTech, the list goes on...
Also, the defective models get re-listed, round and round we go, musical chairs...
BassThatHz is offline
post #12 of 16 Old 11-07-2015, 11:17 AM - Thread Starter
ClintonH's Avatar
Quoted: 101 Post(s)
Liked: 49
1- L
2- L
3- L
4- R
5- R
6- R
7- R
8- L
9- L
10- L
Thanks will try these tomorrow afternoon, I was going to hook up the multimeter yesterday but I left it out at the shop so I will pick it up today. I only have my digital here, analog stays at the shop for code sweeping on cars prior to OBD2.
For the $100 I spent it's not a huge issue really I mean it still puts out almost the same as the EP1500 so it's still useable just not what I wanted. lol If it is indeed not correct I will just go buy a new NU3000 and sell both the EP amps.
ClintonH is offline
post #13 of 16 Old 11-07-2015, 12:56 PM
N8DOGG's Avatar
Liked: 1211
As in do I have more than one sub, no nonat the moment I only have one built. I can test it with 2 by the end of this week, I have 2 more subs waiting for boxes to be built.
Ya just put it in stereo and try each channel on you sub, if there is a difference in spl, likely a bad channel.
N8DOGG is offline
post #14 of 16 Old 11-09-2015, 01:10 PM - Thread Starter
ClintonH's Avatar
Quoted: 101 Post(s)
Liked: 49
1- L
2- L
3- L
4- R
5- R
6- R
7- R
8- L
9- L
10- L
Ok I tried these setting and yes it puts out far more at the 60 Hz tone. With a movie in it works fine as well and puts out very oud but I lost all the bottom end, I think below 30hz has gone. The test scene I was using barley puts any audio out at the lower end where the EP1500 was driving the sub hard. I am guessing this setting uses the high pass filter then? And what does that tell us on this amp?
ClintonH is offline
post #15 of 16 Old 11-09-2015, 04:53 PM
Quoted: 620 Post(s)
Liked: 344
Did you try my suggestion?
post #16 of 16 Old 11-09-2015, 11:42 PM - Thread Starter
ClintonH's Avatar
Quoted: 101 Post(s)
Liked: 49
Ah yes sorry meant to put that in, it was exactly the same as the test I did with the switches in the order I originally had. It works just clips as low freq with anything past 15 or so on the gain.
ClintonH is offline
