The V.B.S.S. DIY subwoofer design thread - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 179Likes
post #31 of 413 Old 12-06-2015, 07:57 PM
LTD02's Avatar
Quoted: 2373 Post(s)
Liked: 2622
Originally Posted by mtg90 View Post
It was a bit harder to see the voice coil on the PA460 without any venting under the spider, though I found it is possible to look through the spider with a bright flashlight.
Looking at it more the top plate could be 7.5mm rather then 0.3 inches, which makes more sense for metric dimensions. Though we are literally splitting hairs at that point (<0.005").
The coil height looks to be roughly 19mm which gives an overhang of 5.75mm if using the 7.5mm gap height. Though I am sure there is some margin of error in my measurements because I can't get a super clear view looking through the spider. It could easily be 19.5mm which give 6mm of coil overhang.
thanks again matt and really great work on building out a sub around this driver to demonstrate what it can do (including the dsp design). i expect that it will be a *very* popular one.
chrapladm likes this.
Listen. It's All Good.
LTD02 is offline
post #32 of 413 Old 12-07-2015, 03:33 AM
Quoted: 478 Post(s)
Liked: 52
LTD02, how does this driver and enclosure combo (combined with DSP) perform compared to the 15" Dayton DVC that runs roughly $100?
Tip24/96 is offline
post #33 of 413 Old 12-14-2015, 09:04 AM
iconrl's Avatar
Quoted: 67 Post(s)
Liked: 31
How many of these would it take to match a single lilwrecker with the alpine driver?
I'm close to building a lilwrecker, but it sure would be nice to have smaller multiple subs and spread them out a little. Also, the build would be easier too.
I already have an inuke 3000dsp, so that's what I'll be using either way.
Thanks in advance
iconrl is offline
post #34 of 413 Old 12-16-2015, 08:51 AM
eng-399's Avatar
Quoted: 1466 Post(s)
Liked: 2242
Wondering since there is a 12" and 15" speaker listed right under the value buster 18" sub can these work to? How would they perform. Would these be a great value along with the flex-12.... How would the flex-12 compare to the Dayton PA310-8 12" woofer or the 15. The price of the 12" 65.50. Having 2 of those for midbass would be a deal! What do you guys think
eng-399 is online now
post #35 of 413 Old 12-16-2015, 08:49 PM
Bburnett's Avatar
Quoted: 42 Post(s)
Originally Posted by eng-399 View Post
Wondering since there is a 12" and 15" speaker listed right under the value buster 18" sub can these work to? How would they perform. Would these be a great value along with the flex-12.... How would the flex-12 compare to the Dayton PA310-8 12" woofer or the 15. The price of the 12" 65.50. Having 2 of those for midbass would be deal! What do you guys think
I would love to see a mid-bass design based on the PA380.
Bburnett is offline
post #36 of 413 Old 12-17-2015, 03:07 AM
LTD02's Avatar
Liked: 2622
1 x pa460 in 6.5 c.f. tuned to 22hz (red)
2 x pa380 in 6.5 c.f. tuned to 22hz (black)
500 watts total.
response is almost...identical. max output would depend on knowing a little more about the pa380. if usable excursion follows the 1mm xmax disadvantage, then output should be about 2db more in the excursion limited zone and a little more outside of that (perhaps 4-5db in the upper bass).
edit: looks like the t/s specs changed again. lol. these guys. it would be nice if they could keep the same specs when using the same model number. this gets very confusing.
edit 2: with the current pa380 specs (green line), this is how it shapes up. same comparo. 2 drivers 6.5 c.f. tuned 22hz 500w. pretty much the same performance despite the t/s changes.
ID:	1125370   Click image for larger version
LTD02 is offline
post #37 of 413 Old 12-17-2015, 05:01 AM
chadamir's Avatar
Quoted: 177 Post(s)
Liked: 59
500 watts total.
Winisd only seems to give +3 for a second driver rather than +6, in my experience
chadamir is offline
post #38 of 413 Old 12-17-2015, 05:20 AM
LTD02's Avatar
Liked: 2622
winisd will show +3db when doubling drivers and cab volume as the system sensitivity is doubled by doing that.
however, when using a second driver, power can be doubled as well, providing the second 3db for a total of 6db when doubling drivers/cabs/power.
rggomez and eng-399 like this.
LTD02 is offline
post #39 of 413 Old 12-17-2015, 10:32 AM
doc5150's Avatar
Quoted: 43 Post(s)
Liked: 34
I like the idea, maybe tuned higher in a smaller cabinet to use as a stand for mains.
doc5150 is offline
post #40 of 413 Old 12-18-2015, 01:01 PM
ugoofbluem's Avatar
Liked: 0
Any idea how two of the V.B.B.S.s would do as part of a built in cabinet? Obviously the cabinet would be built around the subs.
ugoofbluem is offline
post #41 of 413 Old 12-18-2015, 01:50 PM
cuzed2's Avatar
Quoted: 197 Post(s)
Liked: 253
ugoofbluem,
I like they way you think. I'm pursuing a similar idea, for a brief discussion, see post #157 of this link:
Flex-12 and V.B.S.S 18'' sub GTG Meet
Hoping to start building this during the Holidays
Name:	VBSS A Layout.JPG
eng-399 likes this.
Cuzed2
CuznEddy Cinema
cuzed2 is offline
post #42 of 413 Old 12-18-2015, 03:18 PM
mlah384's Avatar
Quoted: 410 Post(s)
Liked: 178
ugoofbluem,
That design looks like the enclosure would move and rock around, or will it be attached to something?
mlah384 is offline
post #43 of 413 Old 12-18-2015, 09:57 PM - Thread Starter
mtg90's Avatar
Quoted: 438 Post(s)
Liked: 849
Lower moving mass on the woofers (2-3 times less then the more common 18" sub drivers) means less energy gets transferred into the cabinet and therefore less rocking.
I should have grabbed some of those PA380's from the PE tent sale this year, I think they had some marked down to $10 or maybe $8 each. I don't think the suspension was as compliant as the PA460. I have some of the 310's and they are very stiff and the suspension does not let them move much past their rated xmax and it's already quite noisy at that point. Should be fine used as a mid bass driver though.
mtg90 is offline
post #44 of 413 Old 12-19-2015, 02:50 AM
Quoted: 478 Post(s)
Liked: 52
What are you doing with the 310's?
Tip24/96 is offline
post #45 of 413 Old 12-19-2015, 08:15 AM
Bburnett's Avatar
Quoted: 42 Post(s)
What would a single PA380 look like?
Bburnett is offline
post #46 of 413 Old 12-19-2015, 10:07 AM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
He wants to put two in an MTM with a Volt or Concentric rolled in at about 300 Hz.
Oh wait. That's what I want him to do. ;-)
moosifee is online now
post #47 of 413 Old 12-20-2015, 02:55 AM
Quoted: 478 Post(s)
Liked: 52
Well that would certainly be a good use for them! I have little knowledge wrt coax speakers, but I have read that there are some really nice ones out there, and they do have some advantages wrt to time alignment, amoung other things.
Tip24/96 is offline
post #48 of 413 Old 12-20-2015, 11:11 AM
jlwilsonjr's Avatar
Wish someone would offer to build flat packs for these for us that don't have the room or skills to build!
dandiele likes this.
jlwilsonjr is offline
post #49 of 413 Old 12-20-2015, 02:50 PM
ugoofbluem's Avatar
Liked: 0
ugoofbluem,
Looks good! I have the space to do two separate enclosures, that's the route I'm leaning now! I have a lot of room to fill!
post #50 of 413 Old 12-20-2015, 03:19 PM
LTD02's Avatar
Liked: 2622
a few posts back in the thread is a post showing 2 x pa380 vs 1 x pa460 in the same size cab and same tuning. those two systems model almost identically, so you could get the same frequency response with a 1 x pa380 in a cab exactly half as large and using 1/2 the ports (of course, you would get less output as well).
LTD02 is offline
post #51 of 413 Old 12-20-2015, 06:30 PM
corradizo's Avatar
Quoted: 1076 Post(s)
Liked: 742
You'd have to make sure the depth of the cabinet stayed the same to keep the port the right distance from the back of the cabinet though right?
LTD02 likes this.
corradizo is online now
post #52 of 413 Old 12-20-2015, 07:03 PM
Bburnett's Avatar
Quoted: 42 Post(s)
Thank you.
I asked Parts Express for a recommendation, for mid-bass use - I suggested the use as being 60Hz to 400 Hz.
I was surprised when they suggested 1.7 ft^3, with one 4" port 4" long, the box being tuned to 55Hz.
Bburnett is offline
post #53 of 413 Old 12-21-2015, 01:48 AM
LTD02's Avatar
Liked: 2622
yes, good point.
LTD02 is offline
post #54 of 413 Old 12-21-2015, 01:52 AM
LTD02's Avatar
Liked: 2622
Thank you.
well, that is kind of what you asked them for when you specified 60hz. a 55hz tuning in that size cab will provide a about a 1db bump in response in the 65-130hz region.
LTD02 is offline
post #55 of 413 Old 12-21-2015, 04:13 AM
Quoted: 478 Post(s)
Liked: 52
It looks like the best bang for your buck is the PA380. LTD02, can you tell us how the PA380 would perform versus the Infinity 1260 in vented enclosures? They are both priced similarly.
Tip24/96 is offline
post #56 of 413 Old 12-21-2015, 08:00 PM
Bburnett's Avatar
Quoted: 42 Post(s)
I guess my comment was prompted by my surprise you can actually use a 15" driver in an enclosure that small.
Bburnett is offline
post #57 of 413 Old 12-22-2015, 07:00 AM
LTD02's Avatar
Liked: 2622
the lowend appears to be a little higher on the infinity and the upper end would be a little higher on the pa380.
LTD02 is offline
post #58 of 413 Old 12-22-2015, 07:02 AM
LTD02's Avatar
Liked: 2622
the driver has a strong motor relative to its moving mass and cone area, which is why it works.
LTD02 is offline
post #59 of 413 Old 12-22-2015, 07:04 AM
Bburnett's Avatar
Quoted: 42 Post(s)
Thanks - I'll try the 1.7ft^3 and see how it sounds.
Bburnett is offline
post #60 of 413 Old 12-22-2015, 07:08 AM
eng-399's Avatar
Liked: 2242
1.7 cubic ft with the 4" port 4" inches long. Please post once your done. Wondering how this setup will sound.
