Dual AE TD18H+ elliptical bass cab's - AVS Forum | Home Theater Discussions And Reviews
 55Likes
post #1 of 61 Old 12-12-2015, 10:05 PM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Hi AVS
This project has been on the drawing board for awhile now ,helping mates out with there projects and them helping me out in the end after having a discectomy an another one after tearing the disc again .
The cabs are going to be a quasi MTM arrangement with a PSE-144 elliptical point ource horn in the middle .
My friend Paul Spencer designed the PSE-144 and he took my google SketchUp drawings and converted them to CAD .
I had Paul get the front/sub baffles & brace section CNC'ed due to not being able to lift heavy sheets of ply & mdf after the last op .A couple mates help me out when theres lifting to be done .
Here's the drawings & test mule PSE my pair are gloss black .
Cheers
Name:	MTM explo 3.jpg
ID:	1117066   Click image for larger version
Name:	MTM explo 2.jpg
ID:	1117074   Click image for larger version
DIY , Ikea Style
Oval56 is offline
post #2 of 61 Old 12-12-2015, 10:08 PM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Paul's CAD drawings
ID:	1117098   Click image for larger version
ID:	1117106   Click image for larger version
ID:	1117114   Click image for larger version
LTD02 and popalock like this.
DIY , Ikea Style
Oval56 is offline
post #3 of 61 Old 12-12-2015, 10:13 PM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
CNC bits , the baffles are 1680x520 overall height will be 1800mm
ID:	1117130   Click image for larger version
ID:	1117138   Click image for larger version
ID:	1117146   Click image for larger version
ID:	1117154   Click image for larger version
LTD02 and gogothedodo like this.
DIY , Ikea Style
Oval56 is offline
post #4 of 61 Old 12-12-2015, 10:15 PM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Pauls 3D CAD drawing & black PSE-144 , yes it looks like a giant breast pump
ID:	1117170   Click image for larger version
LTD02 likes this.
DIY , Ikea Style
Oval56 is offline
post #5 of 61 Old 12-12-2015, 10:20 PM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Gluing
Gluing the front baffle & baffle extension , my mate gluing one side while I glue the other ,speeds up the process .
I found it easier to stack and glue the sections first then drive the dowels through . I done this with a past project .
Trial fit first ,then glue
ID:	1117186   Click image for larger version
ID:	1117194   Click image for larger version
ID:	1117202   Click image for larger version
ID:	1117210   Click image for larger version
ID:	1117226   Click image for larger version
LTD02 likes this.
DIY , Ikea Style
Oval56 is offline
post #6 of 61 Old 12-12-2015, 11:25 PM
Ketnis's Avatar
Quoted: 173 Post(s)
Liked: 88
Very nice, and I bet will look great. Do you have a finish in mind?
edit: Oops, I see you said gloss black at the top.
Ketnis is offline
post #7 of 61 Old 12-13-2015, 12:05 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Cheers mate
The horn is gloss black ,I chose that because I could use it as a base colour or film wrap it .
I haven't decided on a colour for the cab's ?. Thinking of a copper finish for the baffles to match my amps then paint the cab's & amp case's in matching colours .
I'll make a test baffle to see how the copper works out ,I have a few ideas.
The unfinished amp case's
Cheers
Name:	IMG_6391 - Copy.JPG
ID:	1117370   Click image for larger version
LTD02 and squiers007 like this.
DIY , Ikea Style
Oval56 is offline
post #8 of 61 Old 05-26-2016, 03:56 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Hi All
Having a break with the house reno's thought it was time to do some work on the cabs . Starting to put the skeleton together . My mate holding the front baffle against the cab frame.The horizonale braces aren't space properly yet .
Cheers
Mal
ID:	1460626   Click image for larger version
LTD02 and kaiforce like this.
DIY , Ikea Style
Oval56 is offline
post #9 of 61 Old 05-26-2016, 06:26 AM
chrapladm's Avatar
Quoted: 854 Post(s)
Liked: 294
Oval where are you located?
chrapladm is online now
post #10 of 61 Old 05-26-2016, 08:24 AM
lukeamdman's Avatar
Quoted: 1141 Post(s)
Liked: 1297
lukeamdman is offline
post #11 of 61 Old 05-27-2016, 03:27 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Originally Posted by lukeamdman View Post
Nice project!
Cheers mate . I read about your speaker project on AE's site
Werribee in Vic
lukeamdman likes this.
DIY , Ikea Style
Oval56 is offline
post #12 of 61 Old 05-27-2016, 05:35 AM
chrapladm's Avatar
Quoted: 854 Post(s)
Liked: 294
Originally Posted by Oval56 View Post
Werribee in Vic
Darnit, was hoping you were closer.
post #13 of 61 Old 05-27-2016, 05:51 AM
Quoted: 466 Post(s)
Liked: 47
What compression driver will you be using? Will it be a 2", or 1.5", or 1.4" or just a 1"? I would think that using duel AE TD18's would make a hell of a lot of mid bass!
Tip24/96 is offline
post #14 of 61 Old 05-27-2016, 06:52 AM
chrapladm's Avatar
Quoted: 854 Post(s)
Liked: 294
His horn has a 1" CD and 4" mids. Like the Synergy horn. So it is quite dynamic in the mids, so the 18's will be a nice setup.
Oval56 likes this.
post #15 of 61 Old 05-28-2016, 05:31 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
The cabinet frames are done . The next job attach the front baffles but they need to be removable .So I can wrap the frames with bendy ply .
Cheers
Mal
LTD02 and Jaurhead like this.
DIY , Ikea Style
Oval56 is offline
post #16 of 61 Old 05-29-2016, 02:52 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Baffle jig
Hi
Today we made a jig out of the 2 spare braces so we could router a radius into the ends of the baffles so they would mate up to the horizontal braces ,2nd ones in from the top & bottom .
ID:	1466153   Click image for larger version
DIY , Ikea Style
Oval56 is offline
post #17 of 61 Old 05-29-2016, 02:55 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Cheers
ID:	1466169   Click image for larger version
ID:	1466177   Click image for larger version
DIY , Ikea Style
Oval56 is offline
post #18 of 61 Old 05-29-2016, 11:14 PM
A9X-308's Avatar
Quoted: 1416 Post(s)
Liked: 1052
You could have had a nice simple rectangular cuboid speaker box, but, no, Mal has to go and ramp the complexity factor up several notches. It's not like you don't have a history of doing this.
Oval56 and Upfront like this.
A9X-308 is offline
post #19 of 61 Old 05-29-2016, 11:26 PM
Jaurhead's Avatar
Quoted: 123 Post(s)
Liked: 72
Nope, these are definitely mini-silos for small WMD's.
Oval56 likes this.
Mr. Pibb > Dr. Pepper > Everything Else
My Fun Room!
Jaurhead is offline
post #20 of 61 Old 05-30-2016, 02:27 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Hi Brett
Like these cuboid's
DIY , Ikea Style
Oval56 is offline
post #21 of 61 Old 05-30-2016, 02:33 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Or Stargate transport rings
DIY , Ikea Style
Oval56 is offline
post #22 of 61 Old 05-30-2016, 02:46 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Hello
Today Roger and I cut the notches in the braces to trial fit the front baffles . We also went and checked out the bendy ply for the side wall's . 5mm thick nice faces on both side ordered 12 sheets which will be delivered tomorrow .
With a light clamp they pull up nice.
Cheers
ID:	1467449   Click image for larger version
ID:	1467457   Click image for larger version
EarlK likes this.
DIY , Ikea Style
Oval56 is offline
post #23 of 61 Old 05-30-2016, 03:08 AM
Quoted: 466 Post(s)
Liked: 47
Where did you find this horn for sale? Do you mind me asking the purchase price? Does it come standard with the 1" cd in the back and the 4" mids? If so, what 1" compression driver and what 4" mids are you using in this?
Tip24/96 is offline
post #24 of 61 Old 05-30-2016, 04:35 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Hi Tip24
I don't know if I can put a direct link of my mates website ,but if you google Red Spade Audio .Paul's details are there and you can get in contact with him .
Cheers
DIY , Ikea Style
Oval56 is offline
post #25 of 61 Old 05-30-2016, 05:02 AM
WereWolf84's Avatar
Quoted: 238 Post(s)
Liked: 88
Hello
Cheers
Looks sexy & curvy Wow you used 5 layers of front baffle?
WereWolf84 is online now
post #26 of 61 Old 05-30-2016, 05:13 AM
chrapladm's Avatar
Quoted: 854 Post(s)
Liked: 294
http://www.redspade.com.au/audio/PSE...int-source.php
That will tell you more about the horn.
Did you get the 18's on a GB or just ordered them yourself?
post #27 of 61 Old 05-30-2016, 05:39 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
The sub front baffle is pictured framed so its only 18mm thick but once finished it will be 54mm thick .
Got through the Aussie group by , when the dollar was a dollar
chrapladm likes this.
DIY , Ikea Style
Oval56 is offline
post #28 of 61 Old 05-31-2016, 02:53 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
12 sheets of 5mm bendy ply , 4 layers per cab . 1 & 1/2 sheets per layer .
DIY , Ikea Style
Oval56 is offline
post #29 of 61 Old 06-03-2016, 12:45 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
Hi
Today we put the first layer on a cab . We used Megapoxy 69 which has great vertical hold an a good work time . 45min work time @ 25 degrees Celsius/ 77 degrees Fahrenheit .
Cheers
ID:	1475289   Click image for larger version
DIY , Ikea Style
Oval56 is offline
post #30 of 61 Old 06-04-2016, 02:25 AM - Thread Starter
Oval56's Avatar
Quoted: 17 Post(s)
Liked: 60
2nd one has its first layer on ,will give them 48 hours before un clamping due to the cold weather .
Heres what the epoxy looks like when mixed . I used a scrapper to apply it to the edges .Its drys clear .
ID:	1477089   Click image for larger version
ID:	1477097   Click image for larger version
ID:	1477105   Click image for larger version
ID:	1477113   Click image for larger version
DIY , Ikea Style
Oval56 is offline
