FTW-21 ported build - AVS Forum | Home Theater Discussions And Reviews
 213Likes
post #1 of 387 Old 12-14-2015, 08:08 AM - Thread Starter
jlpowell84's Avatar
Quoted: 1941 Post(s)
Liked: 915
FTW-21 ported build
Well the time is here to let the dust fly! Well into the suction hose But I have procrastinated long enough and it's time to start acting! I can hear the "Amen's" already lol. This was only my third whole 2 day weekend since mid August as work and other obligations went crazy then in laws for Thanksgiving. I'm sure I will miss some points but I will do my best. The plan is to have these two ported subs up front behind the screen on either side of the JBL 4722 center channel and obviously the L&R 4722's on outside of the FTW cabs. It will essentially be a solid horizontal baffle all across behind a planned 12ft acoustically transparent screen. Of course a couple inches in between all enclosure wall whether it be speakers or subs.
First off I have to give credit where credit is due. Jon (LTD02) has designed these cabs. I know several AVS-ers who have had Jon's help and certainly he is great on the forums. So MUCH THANKS to Jon for working with me on this and enduring my onslaught of questions
Specs
-18 cubic feet before driver and bracing
-15.7hz port tune
-24"x24"x76" final cab dimensions. Foot print is same as most do with sealed cabs at 24"
-Each of the two cabs will each their own channel from a Crest Pro Lite 7.5.
-Finish, not sure yet if I want to do Duratex or just paint black. They will be hidden so...
-Mini DSP to EQ
-Nuetrik NLM4PR connectors
Cut list will follow the mini marty style but obviously taller
Name:	FTW-21 final plans!.png
ID:	1119930   Click image for larger version
Name:	FTW-21 mini marty style cut plans.png
ID:	1119938   Click image for larger version
Name:	Main theatr pic!.png
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #2 of 387 Old 12-14-2015, 08:51 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
Final Pics...
ID:	1270865   Click image for larger version
ID:	1270873   Click image for larger version
ID:	1270881   Click image for larger version
ID:	1270889   Click image for larger version
Scott Simonian and fuzz092888 like this.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #3 of 387 Old 12-14-2015, 10:30 AM
brian6751's Avatar
Quoted: 1172 Post(s)
Liked: 1143
These are going to be sweet!!
I would do windows where the dotted lines are and then strips connecting them then maybe a half window against the top
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is online now
post #4 of 387 Old 12-14-2015, 02:41 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
key point: that's john with an "h". :-)
jlpowell84 likes this.
Listen. It's All Good.
LTD02 is offline
post #5 of 387 Old 12-14-2015, 03:00 PM
d_c
d_c's Avatar
Quoted: 900 Post(s)
Liked: 1045
FTW-21 ported build
Nice design once again, Hjon!
Maybe some window bracing like a tic-tac-toe board every 10" up the box with four 10" vertical braces between each window connecting them which would brace it top to bottom.
I made some cross bracing for this box below since I was wanting to use up scrap (probably went overboard with the amount). It would have been easier to cut windows out of a full panel:
LTD02 likes this.
d_c is online now
post #6 of 387 Old 12-14-2015, 04:36 PM
NWCgrad's Avatar
Quoted: 1272 Post(s)
Liked: 1311
Can't wait to see measurements once you get the room completed. I like the "small" footprint with volume coming from height.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is offline
post #7 of 387 Old 12-14-2015, 06:04 PM
mrogowski's Avatar
Quoted: 152 Post(s)
Liked: 288
Nice build.
And here I thought it was Jawn the whole time...
jlpowell84 and k1n3t1k like this.
Sent from my 80-286 DOS 3.2/Windows 3.0 machine using Terminal
mrogowski is offline
post #8 of 387 Old 12-14-2015, 07:56 PM
eng-399's Avatar
Quoted: 1742 Post(s)
Liked: 2995
FTW-21 ported build
Wow subscribed this is going to be sweet set up. I agree with above with the bracing. Just make sure you use plenty of pl adhesive on all the braces so nothing is lose.
Also with you having your slot ports facing out under the screen is a great idea I have mine facing outwards with fabric panels around the screen and the screen still shakes during heavy bass clips.
eng-399 is online now
post #9 of 387 Old 12-15-2015, 06:28 AM
LTD02's Avatar
Liked: 2888
i may have forgotten to mention that with a tall cab like that you can get internal standing modes/resonances. it wouldn't be a bad idea to stuff a bunch of polyfill pillows in around the center of the cab (the cheap walmart pillows). bracing can by just about anything. dowels/2x2 stock/mdf scrap, etc. the weak part of the panel is in the center. the edges and corners are naturally strong as they are. just make sure that the cabs are as solid as rocks and airtight around the seams. :-)
LTD02 is offline
post #10 of 387 Old 12-15-2015, 06:33 AM
LTD02's Avatar
Liked: 2888
mr. hurd did one of the best investigations of the effect of using pillows to kill internal standing waves in tall cabs:
Vented boxes and absorption
LTD02 is offline
post #11 of 387 Old 12-15-2015, 10:29 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
Attachment 1120962
Okay I like the window style bracing at each red dotted line then vertical strips. For making the window pieces I assume one uses a jigsaw? And router if you want to round the edges? I actually can't recall seeing or reading any step by step process.
Yea it will be a long time coming when that actually happens :roll eyes: I won't go Tom Logan style and take a decade! I am hoping two years will give me enough time to build and fund the entire project.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #12 of 387 Old 12-15-2015, 10:32 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
Sounds good, I will take my wife with me to deplete the Eugene Walmart pillow stock
Yes the final product will be well made. I may not have sub enclosure experience but have used tools my whole working life and have done quite a bit of sealing work as well in numerous applications.
LTD02 likes this.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #13 of 387 Old 12-15-2015, 10:34 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
Will do, need to swing by and grab some PL still. I assume it's normal to tack a couple brad nails into the brace from the outside of the box to hold it along with the PL?
Ports were planned that way for sure
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #14 of 387 Old 12-15-2015, 10:39 AM
NWCgrad's Avatar
Liked: 1311
But Tom did complete it in the end....
I am starting the research and development for a sub system that I will build when i retire from active duty in 2 yrs, 8 months, and 17 days.
I enjoy the R&D part, it's what I do for a living so I get a little obsessed in the details at times. The procurement is an additional, often harder, hurdle.
Home Theater:
NWCgrad is offline
post #15 of 387 Old 12-15-2015, 10:39 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
Gonna start tonight!!!
So I was planning on recessing the driver a bit. I like the look and the screen will be not far from the mains and subs. So I was thinking perhaps the double baffle piece on the inside should be at least 1" piece of plywood perhaps maybe a couple 0.75 pieces, thoughts?
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #16 of 387 Old 12-15-2015, 10:41 AM
brian6751's Avatar
Liked: 1143
jigsaw works great for the windows. No need to router the edges unless you want to. Its easier to toenail the braces in from the inside with small brads than try and hit them from the outside, less filling and sanding too.
jlpowell84 and eng-399 like this.
Rivers Edge Theater
post #17 of 387 Old 12-15-2015, 10:45 AM
brian6751's Avatar
Liked: 1143
The way Jon H drew it up has a single full baffle with another baffle behind it to make 1.5" to screw the driver into. As for recessing, most go with .75" but remember that adds to the total depth and wont make the driver any less close to the screen.
Rivers Edge Theater
post #18 of 387 Old 12-15-2015, 11:13 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
Yea we didn't get into discussing recessing the driver much. Originally yes a second 0.75 piece on the inside for 1.50 total. Thats why I mentioned going to a thicker piece but perhaps it may be best to not recess the driver. Any idea how much internal cab volume would be lost recessing it 0.75 and then using two additional 0.75 pieces on the inside? So technically it would be three 0.75 layers. The front baffle cut to recess the driver then two more pieces at the 30" on the inside for a total of 1.50 for screws to grab. But if it screws up volume forget it, these will be ultimately hidden. Not 100% sure if it's right but a random volume calculator online says the 22.5x30x0.75 second baffle piece eats about 0.292 cu ft.
I am not understanding how recessing the driver will not move it away from the screen however deep the recess is. If not recessed then the driver surround sticks out however thick it physically is, if recessed it moves back however far is decided correct?
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #19 of 387 Old 12-15-2015, 11:20 AM
brian6751's Avatar
Liked: 1143
All of the recessed drivers I have seen have been an outer baffle. I have never seen someone recess the driver the way your talking about. Not sure how well that would work because if you do that, the only thing really attaching the driver to the enclosure is the PL holding the two inner baffles to it.
Rivers Edge Theater
post #20 of 387 Old 12-15-2015, 11:31 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
Okay, I see what your saying. I think my confusion was the fact I did not know that 0.75 is the general recess depth people use. I hadn't really thought about a number but was assuming 3/8 to 1/2 inch or so. I agree recessing 0.75 and mounting driver to the smaller internal baffle piece may not be a good idea. Could always add an entire full length external piece if I really want to recess the driver that bad.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #21 of 387 Old 12-15-2015, 11:35 AM
brian6751's Avatar
Liked: 1143
right, thats where my comment about it not changing how close the driver is to the screen. Unless you move the whole sub back, which you dont need to recess the driver to do. It does look nice but it will make the enclosure bigger and heavier, not to mention its more work, so doing it for something that wont be seen is a personal preference.
It will be more appealing when you sell it to upgrade though
Rivers Edge Theater
post #22 of 387 Old 12-15-2015, 11:45 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
I have thought about resale appeal. Although I am hoping to be "blown away" by these monsters and have a long term relationship
What about a mild recess? Like 3/8's? It's hard to tell if a small recess would make much visual impact. Naturally it feels it would have some cosmetic value if the recess was just enough to flush the the driver mounting metal part round thingy :roll eyes: But I can't remember the thickness of it, I do remember Nate saying it was pretty sturdy and thick. Maybe 3/8's (but no more than half thickness of the front front baffle piece) then a 1" second baffle piece. Seems that wouldn't change internal volume much, could have cosmetic appeal and still enough for driver to grab for mounting.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #23 of 387 Old 12-15-2015, 11:58 AM
brian6751's Avatar
Liked: 1143
that would work fine. Its easy to set your router to the right depth with the turret.
Rivers Edge Theater
post #24 of 387 Old 12-15-2015, 12:01 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
What about cutting a plywood ring to attach to the inner baffle to give you more to screw into after you've recessed the driver into the outer baffle? It won't take much internal volume and gives that little extra grip. As long as you brace the **** out of the inners the baffles should be plenty strong to support all this. No?
Fattykidd is offline
post #25 of 387 Old 12-15-2015, 12:57 PM
eng-399's Avatar
Liked: 2995
Plywood ring is a good idea see the picture attached.
post #26 of 387 Old 12-15-2015, 01:02 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
Yeah same basic idea. You could even do two 1/2" rings of ply for a total 1" thickness.. and some 1.75" screws.. those drivers will never pull out and you wouldn't have to worry about stripping out the mdf baffles. I don't think it would change internal volume any more than adding an extra brace or something. If I'm off on another planet with my thinking please correct me.
post #27 of 387 Old 12-15-2015, 02:12 PM - Thread Starter
jlpowell84's Avatar
Liked: 915
No it should be fine. a 0.75x22.5x30 inner baffle piece is 0.292 cu ft, and same in 1" thickness was like 0.396 or something close. So little pieces or even a ring would be a fraction of those numbers. I may look into just recessing the driver to were the mounting ring is flush, should not be much. Maybe nothing at all, just thinking out loud here is all
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #28 of 387 Old 12-15-2015, 05:28 PM
BassThatHz's Avatar
Quoted: 2388 Post(s)
Liked: 2161
Damn that is a big box, it's only 8inches smaller than the HzHorn.
But I think your scaling might be off if those are SEOS-24's and your sub box is 24 wide.
I count 10ft wide, you may need a bigger screen to hide everything behind it; and you'll probably want at least a 1/4" spacing between each box so that they don't rub. So 10' 1"
If they are JBL's they'd be 30" wide I guess... which then the image scaling makes sense. Roughly ~13ft wide...
BassThatHz is online now
post #29 of 387 Old 12-15-2015, 06:55 PM
Quoted: 109 Post(s)
Liked: 37
I'm going to do a ported experiment but plan on eventual sealed. Want to see if ported adds much more over the two sealed 21s I have now in experience. I like port air moving around in my live playing music bass, but have gone sealed so far in my HT.
The air timed with bit bass hits is cool but it will be interesting if it adds over bass shakers and pure woofer shake (now @ 2 ftw-21s) from 9 feet away. Ive got two more coming and in the prime position can have either 2 more nearfield or one big 30 cf ported.
Shall see.
cellarnoise is offline
post #30 of 387 Old 12-15-2015, 08:13 PM
LTD02's Avatar
Liked: 2888
@BassThatHz the driver in this case is 21" ftw (mach 5/ist audio) and the cabs are 24". the jbl's are 30". tight fit, hence the tall cabs.
@jlpowell84 adding a second (22.5" x 30") internal baffle and so as to be able to flush mount the driver will have a minimal impact on cab volume and a negligible effect on performance.
brian6751 and jlpowell84 like this.
LTD02 is offline
