tweeter replacement help needed in So Cal - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By clubwerks
Old 12-26-2015, 06:18 PM - Thread Starter
SteveSatch's Avatar
Quoted: 32 Post(s)
The tweeter in my Swan 6.1 speaker went out. I found a replacement online that I could buy but replacing the tweeter is something I could not do. Is there anyone here I could pay to do it for me? I'm in the Murrieta/Temecula area and could come to you.
Steve
SteveSatch is offline
Old 12-26-2015, 08:15 PM
kevings's Avatar
Quoted: 293 Post(s)
Liked: 455
Just in case you're not able to work anything out with a forum member....
I have used OC speaker repair in the past. They are FANTASTIC. Here' a link to their yelp page, in case it helps you out. I'm sure they could take care of the tweeter install for you.
http://www.yelp.com/biz/orange-count...r-garden-grove
kevings is online now
Old 12-27-2015, 07:08 PM
Quoted: 641 Post(s)
Liked: 750
Another option is a car audio place,
They install various aftermarket car audio components so it should not be a problem fixing your speaker. Give one a call in your area and they should be able to take care of the problem. Good luck!
18Hurts is online now
Old 12-28-2015, 11:12 AM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
post a picture. Swan use hi-vi i think. you can get them from partsexpress. replacing should not be too hard.
datranz is offline
Old 12-28-2015, 12:24 PM - Thread Starter
SteveSatch's Avatar
Quoted: 32 Post(s)
Thanks for your reply. The problem is the tweeter is a top mounted dome type on the speaker with a plastic case type thing around it. I can't figure out how to even get to the old tweeter off.
Old 12-28-2015, 12:27 PM
clubwerks's Avatar
Quoted: 79 Post(s)
Liked: 45
I would venture a guess that the mount is bolted onto the cabinet from the inside so you'd need to remove the top woofer to get to the hardware.
christoofar likes this.
clubwerks is offline
Old 12-28-2015, 01:26 PM - Thread Starter
SteveSatch's Avatar
Quoted: 32 Post(s)
I removed the top woofer and I the only thing on top of the speaker that I can see is the two lead wires going to the tweeter.
Old 12-28-2015, 01:48 PM
clubwerks's Avatar
Quoted: 79 Post(s)
Liked: 45
OK, does that screen come off the front of the tweeter?
Old 12-28-2015, 02:18 PM - Thread Starter
SteveSatch's Avatar
Quoted: 32 Post(s)
It does but it's not supposed to as I knocked it and broke it when trying to get the whole tweeter off.
Old 12-28-2015, 02:36 PM
clubwerks's Avatar
Quoted: 79 Post(s)
Liked: 45
Everything is supposed to come off. God didn't build that tweeter housing as one piece. Did you by any chance call the manufacturer and ask them?
Old 12-28-2015, 02:37 PM
clubwerks's Avatar
Quoted: 79 Post(s)
Liked: 45
I do see your dilemma. That speaker is way too nice to be jamming on it with a prybar.
Old 12-28-2015, 02:48 PM
rsvr79's Avatar
Quoted: 178 Post(s)
Liked: 111
Hivi built that top mount tweeter as a one piece assembly. And it looks like PE doesn't carry it anymore, so if you can snag one, you should.
Hivi's actual headquarters is in Arcadia, sort of just up 215 from you. It might be worth giving them a call and seeing if they do repairs.
Originally Posted by SwanSpeaker.com
HiVi Inc.
Home Theater | Custom Installation | Multimedia | Car Audio | Drivers
11630 Goldring Road , Arcadia , CA 91006 USA
www.swanspeaker.com | sales@swanspeaker.com
Tel: 626-930-0606 | Fax: 626-930-0609
rsvr79 is offline
Old 12-28-2015, 03:23 PM
clubwerks's Avatar
Quoted: 79 Post(s)
Liked: 45
If that speaker mount was built as one piece, any chance is was stuck on with some double sided tape or something?
Old 12-28-2015, 03:28 PM
drab's Avatar
Madisound sells that tweeter.
You should be able ask Jon Lane how to remove it.
drab is offline
