Is this mineral wool ok as subwoofer insulation? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By brian6751
Old 01-28-2016, 02:23 PM - Thread Starter
BBS G35's Avatar
Quoted: 29 Post(s)
Liked: 34
Been spending hours trying to figure out if regular old polyfill really is just as good as fiber glass or Acousta-Stuff or Mineral Wool.
I've seen some response graphs showing benefits of Mineral Wool over polyfill. So I'm really intrigued by the mineral wool.
The cheapest and easiest way to get mineral wool seems to be this from Home Depot for those of us outside Canada.
http://m.homedepot.com/p/Roxul-Safe-...1525/202531875
Now is 3" thick Mineral Wool to thick for a 4.3 cubic ft enclosure? (Volume before bracing)
Also does it matter that it's branded as Safe n Sound for sound dampening? Instead of the typical Roxul ComfortBoard or Comfortbat
BBS G35 is offline
Old 01-28-2016, 07:57 PM
derrickdj1's Avatar
Quoted: 563 Post(s)
Liked: 393
I have had a couple of sub with that in them. No problem. I don't how you determine how much stuff to use for that.
derrickdj1 is offline
Old 01-28-2016, 08:17 PM
brian6751's Avatar
Quoted: 502 Post(s)
Liked: 395
just get 4 polly pillows from Walmart and stuff them in there
kaiforce likes this.
brian6751 is online now
Old 01-28-2016, 08:26 PM
chadamir's Avatar
Quoted: 171 Post(s)
Liked: 58
Can you post the response graphs?
chadamir is online now
Old 01-28-2016, 10:33 PM
K9woofer's Avatar
Quoted: 41 Post(s)
I used the 3" safe n sound for my ported cabs. About 50% coverage. I did a sweep with REW with and without the insulation and it made little difference.
I would use something else if i had to do it over as Roxul is hard to glue to wood.
K9woofer is offline
taboola here
