Have you been broken a Jasper jig? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-03-2016, 09:11 AM - Thread Starter
chadamir's Avatar
Quoted: 177 Post(s)
Liked: 59
I know Jasper works great but I've also heard that they break easily. Wondering if I should really just do a diy circle jig.
chadamir is offline
post #2 of 6 Old 02-03-2016, 09:20 AM
dtsdig's Avatar
Quoted: 776 Post(s)
Liked: 844
I broke one by accidentally having my router fall of the bench onto the concrete with the jig installed. Broke it clean in half. My second one has been just fine! If you treat it as a piece of 1/4 inch thick plexiglass, which is what it is, it will provide many years of service.
dtsdig is offline
post #3 of 6 Old 02-03-2016, 09:29 AM
ClintonH's Avatar
Quoted: 101 Post(s)
Liked: 50
Mine is nylon, it's taken a few falls not very high mind you. But it's still perfectly fine.
ClintonH is offline
post #4 of 6 Old 02-03-2016, 09:35 AM
rhodesj's Avatar
Quoted: 769 Post(s)
Liked: 433
I've knocked mine off the workbench with router attached as well. Just took a chunk out of the side though, so it's still usable. There's nothing particularly fragile about it. If you're less clumsy than dtsdig or myself, you won't have an issue.
rhodesj is online now
post #5 of 6 Old 02-03-2016, 09:38 AM
asarose247's Avatar
Quoted: 529 Post(s)
Liked: 344
I have a Milescraft set-up from Lowes that has given me no issues for a bunch of 15's and 18's
TBS It seems that the Jasper jig usually asked about is the #400 for 1" to about 6"+, it's made of 3/8th's acrylic
There's been a fusion 4 build where the member here used Zerba , iirc, for his front baffles,
it may be what he used, again, with no issues
ands really good looking results
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
DUAL LOWARHORNS , SUBMAXIMUS, Custom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #6 of 6 Old 02-03-2016, 10:13 AM
dtsdig's Avatar
Quoted: 776 Post(s)
Liked: 844
Hey, how dare you say I was clumsy!?!
.....Ok, I was clumsy.
dtsdig is offline
