I Nuke Input Voltage Less Than Output-Significance - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By FriscoDTM
  • 1 Post By lovinthehd
  • 2 Post By MadHek
Old 02-07-2016, 04:15 AM - Thread Starter
derrickdj1's Avatar
Quoted: 563 Post(s)
Liked: 393
I have not had problems but, notice the input voltage is less than output. Maybe the sub out of the avr has been split to many times. I can get the clip light to activate for all the amps.
derrickdj1 is offline
Old 02-07-2016, 05:29 AM
Quoted: 66 Post(s)
Liked: 39
Maybe I'm not understanding your question, but the input should be less than the output on an amplifier. That's what it does, it amplifies the signal, making it larger.
dorri732 is offline
Old 02-07-2016, 07:54 AM
Quoted: 430 Post(s)
Liked: 181
Input voltage on the inuke amps is ~.77v. Which is the lowest I've ever seen for any pro amp.
Pretty much every possible input device can drive the amp to full power very easily.
Classifieds:
FS: JTR 212s & 228
dwaleke is offline
Old 02-07-2016, 04:13 PM - Thread Starter
derrickdj1's Avatar
Quoted: 563 Post(s)
Liked: 393
I just notice the the input voltage on the GUI screen is always less than the output meters. The reason for the question is that I am running 8 sub and shakers of of the .1 sub out of the avr.
Due to the lower reading of the input on the meters, is the a possibility of the input signal clipping or sending a clip signal to the I Nuke. Would an Art Clean Box make the input and output meters on the GUI screen equal?
Old 02-07-2016, 04:16 PM
muzz's Avatar
Quoted: 378 Post(s)
Liked: 185
What?
The input should be less than the output(mine is slight)
What is the problem?
muzz is online now
Old 02-07-2016, 04:21 PM
FriscoDTM's Avatar
Quoted: 143 Post(s)
Liked: 146
The GUI should be relative to max signal, so if you see a difference it is probably because you jacked up the gain in the software? Try resetting all gains to zero and see if there's still a mismatch.
derrickdj1 likes this.
TV 2013 Samsung 75" UN75F6300
Pre/Amp Marantz 7702mk2 Processor + 11ch DIY Balanced 50ASX2BTL Amp Build Link
Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) - Volts In Progress Volt Build Link
Subs Two 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced
FriscoDTM is offline
Old 02-07-2016, 05:02 PM
BassThatHz's Avatar
Quoted: 1597 Post(s)
Liked: 1186
There is no good reason to EVER clip the input. It achieves nothing good.
If the input is higher than the output then it seems logical to assume that the output cannot clip before the input does, which is a bad thing because that means you aren't getting full (unclipped) power out of the amp, in fact you'd be clipping the input for no good reason and then amplifying it to a fairly high wattage.
This can be fixed by reducing the LFE gain in the AVR a few db to ensure no input clipping at your max level and then adding a few db of boost inside all the inuke(s).
BassThatHz is online now
Old 02-07-2016, 07:30 PM - Thread Starter
derrickdj1's Avatar
Quoted: 563 Post(s)
Liked: 393
I may have been over thinking things and pretty much new that the system was OK. You just read about weak avr's and the need for a Clean Box. Most avr's will support 4 subs without a problem but, I have 8 subs and 8 shakers all on a 7.1 avr. The avr is heavy duty and has done great as the hub of the system.
Old 02-07-2016, 07:48 PM
chadamir's Avatar
Quoted: 171 Post(s)
Liked: 57
Splitting a signal does not affect the voltage.
chadamir is offline
Old 02-07-2016, 09:54 PM
lovinthehd's Avatar
Quoted: 3973 Post(s)
Liked: 3880
lovinthehd is offline
Old 02-08-2016, 03:40 AM
MadHek's Avatar
Quoted: 20 Post(s)
Liked: 31
As already stated no problem splitting avr pre-out signal to many amplifiers.
And in no way should you clip the signal input to the DSP before you clip the output of the DSP (which is feeding the amplifier).
So input signal levels in the software monitor should always read less than or equal to output Level of the DSP.
NOT the other way around.
You always want the output of the DSP, that feeds the amp, to clip first in order to utilize all of the amplifiers power unclipped.
If the input of the DSP clips before the output (say if you reduce the gain much in the dsp) then the signal will clip before the amp does, so not only will you not be able to utilize all of the amps power but when you try to it will be an amplified clipped signal, clipped prior to amplification...
derrickdj1 and K9woofer like this.
MadHek is offline
taboola here
