Official SpeakerPower amplifier thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 92Likes
post #61 of 239 Old 07-01-2016, 09:38 PM
rich121's Avatar
Originally Posted by SpeakerPower View Post
There IS a center tap on residential power. The neutral is tied to it. From transformer "ends" you get +120V and -120V. Either hot to neutral gets 120V. Hot to hot is 240VAC. What Luke did is fine as long as the caveats in my email are observed.
I have been a Journeyman Electrician for over 26 years, yes, I know there is a neutral in a 240/120v split-phase residential Service... obviously I was referring to the multi-wire circuit containing L1, L2 and ground.... no neutral. Anal, maybe....
But accurate.
Done
Now, lets see more posts about those amps!
rich121 is offline
post #62 of 239 Old 07-06-2016, 03:33 PM
Gorilla Killa's Avatar
Quoted: 630 Post(s)
Liked: 686
So I don't "ass"ume, are the xlr looping outputs used for another sub. 1 driver 1 box, hooked to 1 driver 1 box. Im looking at the plate amp SP1-4000
Gorilla Killa is offline
post #63 of 239 Old 07-06-2016, 03:38 PM
SpeakerPower's Avatar
Quoted: 46 Post(s)
Liked: 98
The XLR looping output is in parallel to the XLR input, no signal processing applied.
The SP1-4000 has a Speakon looping out that allows a slave cabinet to be connected to the AMPLIFIER output. All signal processing and amplification applied. If you need it.
SpeakerPower is offline
post #64 of 239 Old 07-06-2016, 04:43 PM
Quoted: 630 Post(s)
Liked: 686
Ok, I see its at the bottom next to the power supply. Im still wrapping my head around the Molex pin wiring diagram.
Other than a 2cuft minimum for sealed enclosure any other recommendations as far as heat dispersion is concerned.
post #65 of 239 Old 07-07-2016, 11:51 AM
murphy2112's Avatar
Quoted: 610 Post(s)
Liked: 337
Does anyone have any pictures of these rack-mount SP amps? The 12000 for example?
murphy2112 is offline
post #66 of 239 Old 07-07-2016, 12:01 PM - Thread Starter
lukeamdman's Avatar
Quoted: 1208 Post(s)
Liked: 1471
I have some in the first post.
EDIT: Second post
lukeamdman is offline
post #67 of 239 Old 07-07-2016, 02:40 PM
notnyt's Avatar
Quoted: 2656 Post(s)
Liked: 2431
here
notnyt is offline
post #68 of 239 Old 07-07-2016, 03:02 PM
murphy2112's Avatar
Quoted: 610 Post(s)
Liked: 337
^^ Whoops - I meant to ask about "internal" pictures, not pictures. The inside of the amp
post #69 of 239 Old 07-07-2016, 05:19 PM
notnyt's Avatar
Liked: 2431
Follow the links, scroll.
I'd post em here, but not sure he wants the internal pics published in this thread.
notnyt is offline
post #70 of 239 Old 07-07-2016, 07:21 PM
murphy2112's Avatar
Quoted: 610 Post(s)
Liked: 337
post #71 of 239 Old 07-07-2016, 07:33 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 90
not sure why he would care now if i bought the amp from him shipped it off to china and had it cloned then he might care
cookieattk is offline
post #72 of 239 Old 07-07-2016, 07:35 PM
notnyt's Avatar
Liked: 2431
*shrug* if he wanted that published in any official or semi official channel he likely would have. If he doesn't care I'll post the hires images, but not doing so without an ok.
notnyt is offline
post #73 of 239 Old 07-07-2016, 08:04 PM
cookieattk's Avatar
Quoted: 111 Post(s)
Liked: 90
so u don't mind buying amps from china that are stolen ip , but posting a picture of another amp is taboo b/c the guy who owns the company posts occasionally k lol ....
post #74 of 239 Old 07-07-2016, 08:40 PM - Thread Starter
lukeamdman's Avatar
Liked: 1471
You're the only one in this thread talking about china. Stay on topic or post in another thread please.
notnyt, SpinMonster and 18Hurts like this.
post #75 of 239 Old 07-07-2016, 09:13 PM
notnyt's Avatar
Liked: 2431
And I wouldn't go posting about them in an official LG thread either. The pictures are posted, heavens forbid you have to follow an extra link to view them.
notnyt is offline
post #76 of 239 Old 07-08-2016, 12:53 PM
Quoted: 630 Post(s)
Liked: 686
Any thoughts of 2ohm or 4ohm load as far as better for the plate amps. Im going to use a sp1 4000, starting with 2 drivers in sealed separate enclosures. I may move to 2 enclosures 2 drivers each. I know Seaton does this with f18 but not sure what ohm his speakers are or if they are dvc.
Drivers im using are 12" dvc, I may be overthinking this, any thoughts.
post #77 of 239 Old 07-08-2016, 01:02 PM
notnyt's Avatar
Liked: 2431
the 4000 is voltage limited with 4 ohm loads. You can get more power into a 2 ohm load.
notnyt is offline
post #78 of 239 Old 07-09-2016, 02:07 PM
spanish68's Avatar
Speakerpower SP1-4000-HT plate amp
Hi, I just want to make a few comments regarding the Speakerpower SP1-4000-HT plate amp. I ordered one almost two months ago. I was told it was going to take at least three weeks to receive since they have to make it. I told them if they could do it in 10-days or so since I had my inlaw visiting and I wanted him to run the wires on my subs and connect the amp (he's good with electricity). Anyways, I got my amp shipped to my house in 9-days. I realize that Speakerpower has a lot of work, they provide amps to JTR, Seaton, PSA and Reaction audio. They went out of their way to make my amp and delivered it quickly, that's what I call customer service!!
I've been using the amp for a few weeks now and simply love it. It's powering four 15" JBL GTI MKII DVC6ohms subs in dual opposed sealed boxes. Each box is about 5cf and fully stuffed. All the subs are wired for a final load of 3ohms. The amps does 2,800/4 and 4,000/2 so at 3ohms I'm guessing it does somewhere between 3-3,500 watts which is perfect for my subs which handle 800wrs each. The amp is on the master box connected to a slave box. Both of my sub boxes are in the front corners of the room, which is about 5,500 to 6,000 square feet.
The only thing I found somewhat frustating was when the subs were on the auto switch of the amp. The amp seemed to be hunting for a signal to activate itself, it made clicking sounds. That was when watching TV. I put the switch to on, connected the amp to a smart power strip that I bought and that problem was solved. Also, the back of the amp is open which I find somewhat confusing since previous amps that I had always had the back covered. I wonder why is that? Should not the amp internals be protected with a cover? I don't see any heat sinks or fans on the amp either. Here are the things I like about the amp:
1. Power, there's plenty of it to drive all my subs to or near their limits. This is the most powerful amp I've used. Previous amps I had were Crest Prolite 3.0DSP, Yamaha P7000, ED LT1300 plate amp and Funk Audio 2,400Watts plate amp. Going by Notnyt's test of the SP2-8000 amp, I feel confident that this amp should do half the power of the SP2-8000 amp.
2. Efficiency, I believe this amp is over 90% efficient. Why is that important to me? I have it connected with the rest of my gear on one 15A circuit and so far, no problems whatsoever. It produces less heat and runs cool.
3. Size, it's a very small and lightweight amp, some six pounds or so. Also, I doesn't take any rack space like a regular amp would.
4. Quiet, I love this feature!! I can't overstated it. No need to mod fans or bright lights to worry about.
5. Gain/Volt issues when connected to a receiver, issues I had in the past. No bump boxes to worry about.
6. Built here and by its history, Speakerpower has been a very reliable brand.
7. Features, there's plenty of them. Gain, Delay/Phase, Crossover (to 120hz), auto/on/12v trigger, on/off swicth, speakon outlet out for a second sub, XLR/RCA inputs and LF Adjust. The LF is very valuable since you can adjust it to fit the size of your room. You can bump up the low bass or lower it, depending on your room gain. The Speakon connector out is also important if you need to connect a second sub to the amp, which is my case. Seaton Sound also does it with their submersives.
The negatives? These amps are not cheap but they have come down in price and have more features than before. For under $1,000, I think it's not bad, considering all you get. Are there better bang for the $ amps out there? Yes there are, but do they offer all of the above options? Also, I would like to see a more extensive DSP, perhaps some parametric EQ. In my case, my Denon, with its XT32 does a very good job with the sub's EQ. I took a couple of pics of the amp for you to see. Brian and co. at Speakerpower, great job!
ID:	1537217   Click image for larger version
spanish68 is offline
post #79 of 239 Old 07-09-2016, 03:22 PM
Quoted: 630 Post(s)
Liked: 686
@spanish68 thanks for posting this, couldnt be better timing since im on the verge of pulling the triggger. Im doing the same setup as you have just diffferent drivers. Im looking forward to getting one of these, sounds like you couldnt have had a better experience. Brian Ill be in touch
post #80 of 239 Old 07-09-2016, 03:41 PM
jeno's Avatar
Quoted: 29 Post(s)
jeno is offline
post #81 of 239 Old 07-11-2016, 01:47 PM
krholmberg's Avatar
Quoted: 113 Post(s)
Liked: 29
@SpeakerPower I have a quick question. It looks like the SP1-1400-HT only has one input. That of course means there is no way to adjust the delay of one speaker vs the other, right? Does the SP4-2800-DP have four inputs? It might be worthwhile to put a pic of the back of SP4-2800-DP (and the other rack mount amps) on the website.
Sent from my SM-G935T using Tapatalk
coolrda likes this.
Krister
krholmberg is offline
post #82 of 239 Old 07-11-2016, 04:15 PM
Quoted: 46 Post(s)
Liked: 98
Glad to hear you are enjoying your amp. Eliminating the back cover was one of the cost savings that allowed us to offer the -HT amps at a lower price. But the power and efficiency are the same. Auto On with signal can be made more sensitive by lowing the volume control on the amp and raising the level coming from the preamp.
Brian
post #83 of 239 Old 07-11-2016, 04:32 PM
Quoted: 46 Post(s)
Liked: 98
You are correct, the SP1-1400 has one input and two output amplifier channels with the same signal on both. The SP4-2800 has four inputs and four amplifier channel output. Can be a different signal on each. No built in DSP.
At the bottom of the Technical Specifications page is a PDF that has front and rear photos. http://www.speakerpower.net/specifications.html
krholmberg likes this.
post #84 of 239 Old 07-11-2016, 04:35 PM
Quoted: 46 Post(s)
Liked: 98
It's fine with me if you want to post interior photos. I'm not worried about chinese imitations. The magic is in the details of the circuit, pcb layout, and microcontroller code.
Brian
chrapladm likes this.
post #85 of 239 Old 07-11-2016, 04:37 PM
notnyt's Avatar
Liked: 2431
Well then, for those looking, here's interior of sp2-8000
krholmberg and chrapladm like this.
notnyt is offline
post #86 of 239 Old 07-11-2016, 04:46 PM
zeus33's Avatar
Quoted: 1528 Post(s)
Liked: 1381
To look at that, you would think that there is no way that it makes the power that it does. Impressive!
zeus33 is offline
post #87 of 239 Old 07-11-2016, 04:47 PM
Quoted: 46 Post(s)
Liked: 98
You realize you just voided your warranty....... JUST KIDDING!
dwaleke, baniels, notnyt and 3 others like this.
post #88 of 239 Old 07-11-2016, 04:50 PM
notnyt's Avatar
Liked: 2431
Not mine Still waiting for mine to get built. Then I'll take some nice pics of the SP2-12000
That was still a low res pic, if you have any desire for higher res versions where you can read everything on the boards lemme know, as I have a studio with a nifty lighting setup I've been using to photograph these.
and front/back
notnyt is offline
post #89 of 239 Old 07-11-2016, 07:46 PM
LTD02's Avatar
Quoted: 2462 Post(s)
Liked: 2782
ah man, now the secret of the fan shrouds is out.
are you wiring for 240v while you wait?
Listen. It's All Good.
LTD02 is online now
post #90 of 239 Old 07-11-2016, 07:48 PM
notnyt's Avatar
Liked: 2431
Not until I get them. Still powering my fp14ks. Shouldn't take more than an hour or so. I have dedi 30a runs, just moving the neutral to the other phase and swapping outlets. I have the breakers, outlets, and plates ready to go.
LTD02 likes this.
notnyt is offline
