SI DS4's - 12 cft. ported - AVS Forum | Home Theater Discussions And Reviews
 12Likes
  • 3 Post By brian6751
  • 1 Post By lz7j
  • 1 Post By NWCgrad
  • 1 Post By brian6751
  • 1 Post By chadamir
  • 1 Post By chrapladm
  • 3 Post By LTD02
  • 1 Post By LTD02
Old 04-06-2016, 01:17 PM - Thread Starter
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
SI DS4's - 12 cft. ported 17Hz
Going to be starting this build soon and wanted to get the thread going. So far I have these measurements
tune is 17Hz
22" wide x 23.25" deep x 58" tall . Double front baffle
Port is 3.5 x 19 x 44.75
I get 2975.875 cubic inches for the port volume
Looks like about 12.8 cft before the driver and bracing.
Port velocity and excursion seem good to me.
Man, these things are going to be YUUUGE!
HP at 17Hz. 2db PEQ at 18Hz.
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
Old 04-06-2016, 01:20 PM - Thread Starter
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
reserved
Rivers Edge Theater
Old 04-06-2016, 01:21 PM
lz7j's Avatar
Quoted: 668 Post(s)
Liked: 645
Looking forward to seeing how your Tall Marty turns out.
brian6751 likes this.
lz7j is offline
Old 04-06-2016, 02:02 PM - Thread Starter
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
Thats ridiculous. This is a modified Cyclops
Rivers Edge Theater
Old 04-06-2016, 04:01 PM
NWCgrad's Avatar
Quoted: 1230 Post(s)
Liked: 1222
A Martyclops build.......
Whatever it is it will be nice.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is online now
Old 04-06-2016, 04:40 PM - Thread Starter
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
Mega Tall Marty Clops or Mt. MC for short.
NWCgrad likes this.
Rivers Edge Theater
Old 04-06-2016, 07:29 PM
chadamir's Avatar
Quoted: 177 Post(s)
Liked: 59
If you are aiming for 17 hz, you should design for a lower tune since you are going to end up with a smaller net volume. I ended up with a slightly higher tuning than I wanted on my subs because of that. Also, are you not going to brace the port?
chadamir is offline
Old 04-06-2016, 07:36 PM
chrapladm's Avatar
Quoted: 824 Post(s)
Liked: 286
Not sure what the above comment means. Just make sure you have a net volume of what you simmed. Then add on your ports volume and then see what you will need for an external size. Simple enough.
chrapladm is offline
Old 04-06-2016, 07:59 PM - Thread Starter
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
Trying to understand what you mean here.
I used the volume calculator on hometheatershack for the size which takes into consideration the port volume. Then I added about .8cft. To account for the driver and bracing.
Also, yes the ports are braced. 22" width minus 1.5" for the side walls and another 1.5" for the two braces is 19" width
Rivers Edge Theater
Old 04-06-2016, 08:53 PM
chadamir's Avatar
Quoted: 177 Post(s)
Liked: 59
I didn't realize that you had already factored all of that in. Good luck with the build!
chadamir is offline
Old 04-06-2016, 09:04 PM
Red Devil 24's Avatar
Quoted: 27 Post(s)
Liked: 30
only problem I see is that the first port resonance is a little too low (151Hz)with those dimension.
Anthem MRX510, OPPO BDP103, 2x Emotiva XPA-100, Elusive 1099 LCR in progress, LG FP9000 Clone, 2x Dayton Ultimax 15 tuned to 14Hz
Red Devil 24 is offline
Old 04-06-2016, 09:14 PM - Thread Starter
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
from what I have read, that should be fine crossing at 80Hz, no?
Rivers Edge Theater
Old 04-07-2016, 09:10 AM - Thread Starter
brian6751's Avatar
Quoted: 879 Post(s)
Liked: 675
anyone know if it is ok to have the driver further away from the ground than normal, as in mounting it in the cab so that its closer to center height of the room? Would this excite some bad room modes or something? Im thinking that I want to mount the driver in the middle of the enclosure. Its 58" tall so right at 29". I know thats not the center os the room but it is higher than "normal".
Rivers Edge Theater
Old 04-07-2016, 09:44 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2576
countless builds with first port resonance at 140hz or so. no problems with 80hz crossover.
brian6751, lz7j and squiers007 like this.
Listen. It's All Good.
LTD02 is offline
Old 04-07-2016, 09:47 AM
LTD02's Avatar
Liked: 2576
keep an eye on 1/4 distance cancellations from the boundaries and floor bounce cancellation. other than that, if your cab is heavy enough not to vibrate, mounting the driver like that is ok.
LTD02 is offline
