Damaged speaker "coating". - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By squiers007
post #1 of 2 Old 04-18-2016, 02:47 AM - Thread Starter
Liked: 0
Question Damaged speaker "coating".
Hello,
I'm not really going to make my own speakers, but I'd like to repair them. I have a couple of Q-Acoustics with a damaged graphite "coating" on the corners of the box (see pictures in attachment). I have no idea why this is happening, but I'm guessing the sun might be the culprit...
Is there a way to fix this myself? Just to be clear: I have never done anything like this before.
Thank you in advance for your answers!
ID:	1388514   Click image for larger version
ID:	1388522   Click image for larger version
Frogroar is offline
post #2 of 2 Old 04-18-2016, 08:58 AM
squiers007's Avatar
Quoted: 757 Post(s)
Liked: 378
Looks like it is a veneer and it is starting to peel off. UV and sun can cause this and also moisture damage. Unfortunately it is difficult to repair short of removing all of the veneer and re-doing it...
Face2 likes this.
Check out my End-Table Marty Build
squiers007 is offline
