NWCgrad's JBL Pro Active Three-Way Build - AVS Forum | Home Theater Discussions And Reviews
 289Likes
post #1 of 702 Old 07-17-2016, 04:03 PM - Thread Starter
NWCgrad's Avatar
Quoted: 1265 Post(s)
Liked: 1304
UPDATE 2/6/2017:
Final Design with Components (After Build)
Design is full active three-way with dbx Venu360 for XO/DSP and Crown amplification.
I have finalized my overall design for my new main speakers (replacing my 4 Pi speakers). The iterative design process was documented in the following link: Next Build - Planning Stage
What I am looking for it a speaker that has high output capability with low distortion, fully capable of being able to reproduce cleanly the sound pressure levels in my home theater room typical of THX-reference levels and rock performances. However, at the same time it must be able to reproduce the individual strings of a 12 string guitar at low sound pressure levels.
Final Design with components:
Front baffle [modeled after the JBL 4345 Studio Monitor]:
Design is tri-amped, with a active LF and MF combined with passive HF [7 Pi XO for the compression driver] due to gain structure of the DSP unit (Peavey VSX 26)
Ordered the Midhorn flatpacks and Eminence Delta 10A drivers from Pi Speakers this afternoon, which marked the end of the design phase and thus a new - and final - thread. I need to build the midhorns to finalize the bracing scheme, but the overall net volume of the cabinet will mimic the JBL 4345, with the same 32 Hz tuning. Desire is for full range performance for music, which will be around 70% of the speakers utilization.
Final design was influenced by lots of people, primarily @LTD02 , @Mfusick , and @Scott Simonian .
Name:	1810 RM w component listing.png
ID:	1551161   Click image for larger version
Name:	Front Baffle - 4345 Inspired.jpg
ID:	1551185   Click image for larger version
ID:	1551217   Click image for larger version
Name:	Final Speaker - All JBL Pro Driverws.jpg
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
Last edited by NWCgrad; 02-06-2017 at 07:17 AM. Reason: Updates to reflect final configuration
NWCgrad is offline
post #2 of 702 Old 07-17-2016, 05:30 PM
chrapladm's Avatar
Quoted: 931 Post(s)
Liked: 348
Great to see a thread starting on this build. Hopefully your build will be done before mine. I have had two ideas rolling around for a while. One idea was a very similar idea 3 way and the other was the two way. If things go well I will do the three way. BUT for now I really want to see how you like your setup.
NWCgrad likes this.
chrapladm is offline
post #3 of 702 Old 07-17-2016, 05:39 PM
LTD02's Avatar
Quoted: 2504 Post(s)
Liked: 2835
@Scott Simonian
scott's successful implementation of the midhorn was probably the major influence, no?
i was all over the map and half the time repeating things you said six months ago, lol. :-)
hopefully you will drop wayne a note to let him know what you are up to (if you haven't already). i'm sure he would think your plan is pretty cool.
still like the blue baffles. :-)
NWCgrad likes this.
Listen. It's All Good.
LTD02 is online now
post #4 of 702 Old 07-18-2016, 08:13 AM
Point Source
beastaudio's Avatar
Quoted: 4027 Post(s)
Liked: 3348
Sub'd
NWCgrad likes this.
beastaudio is online now
post #5 of 702 Old 07-18-2016, 08:34 AM
Bassment's Avatar
Quoted: 945 Post(s)
Liked: 378
Bassment is online now
post #6 of 702 Old 07-18-2016, 11:03 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
You're not seriously using first order xovers on the LF and MF are you?
NWCgrad likes this.
A9X-308 is offline
post #7 of 702 Old 07-18-2016, 01:53 PM - Thread Starter
NWCgrad's Avatar
Liked: 1304
Hopefully the build will progress well.
These will be rather large enclosures, any mistakes will thus me magnified. I am thinking of building an aluminum frame (8020 material) to assist with keeping the enclosures square during the gluing process.
chrapladm likes this.
Home Theater:
NWCgrad is offline
post #8 of 702 Old 07-18-2016, 01:55 PM - Thread Starter
NWCgrad's Avatar
Liked: 1304
@Scott Simonian
Yeah Scott is guilty as charged! I have been emailing Wayne on the project, I know he would prefer the straight 7 Pi build as its his favorite speaker.
LTD02 likes this.
Home Theater:
NWCgrad is offline
post #9 of 702 Old 07-18-2016, 02:09 PM - Thread Starter
NWCgrad's Avatar
Liked: 1304
Depends on the shape of the driver roll-off. Wayne paired the XO with the natural roll-off ala JBL, so with the "quasi" first order design the actual acoustical roll-off is much greater than the simple 6 dB/octave.
For the LF I doubt I can go this way as I am using a larger enclosure and different driver. Will measure and lusten to determine the best approach for me. I know the forth order Linkwitz-Riley, having fixed slopes, 24dB/octave (Q 0.5) and -6dB at crossover point (Bessel), has been adopted as the standard for professional systems as the steep slopes give maximum protection, control and power capability for the drivers.
With my electronic crossover I have the flexibility to try, and measure, various filter options. What I've read in multiple places is that 2nd order 12dB/octave crossovers attenuate the music without hearing a tone or color change in midrange speaker crossed over in isolation (but does that translate to a complete system). Higher order crossovers attenuate the music causing a subtle but noticeable tone or color change (but will I pick them up).
I am not a crossover guru, so the project will probably meander for awhile until I find what I like best at that moment in time.
Home Theater:
NWCgrad is offline
post #10 of 702 Old 07-18-2016, 02:10 PM - Thread Starter
NWCgrad's Avatar
Liked: 1304
Originally Posted by Bassment View Post
Awesome, I'm a fan of the dual horn design
Thanks, I am looking forward to cutting lumber.
Home Theater:
NWCgrad is offline
post #11 of 702 Old 07-18-2016, 02:17 PM
LTD02's Avatar
Liked: 2835
"I am not a crossover guru, so the project will probably meander for awhile..."
i suspect what alpha niner was referring to, in part, is the 2242 has a rising response well into the lower midrange (and on top of that there is baffle step transition). so even with a 6db/oct low pass at 250hz, you might not even end up being down 6db by 1khz (or more) on the woofer section. might want to start with 4th order acoustic slopes and experiment from there. at least that gets phase pretty much in line and limits each subsystem to its intended pass band, but hey...its a free country. :-)
jshadzi likes this.
LTD02 is online now
post #12 of 702 Old 07-18-2016, 02:22 PM - Thread Starter
NWCgrad's Avatar
Liked: 1304
Yeah, the 2242 does have a pretty hearty rising response starting at 800 Hz. If not adequately attenuated it would really muddy the midrange. I have no issues with going with the 4th order on the lf.
No doubt I know a lot less than @A9X-308 on this topic and am always willing to learn.
Home Theater:
NWCgrad is offline
post #13 of 702 Old 07-18-2016, 04:21 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5960 Post(s)
Liked: 5006
I would recommend a 4th order cross from bass to mid if possible.
Scott Simonian is online now
post #14 of 702 Old 07-18-2016, 05:09 PM - Thread Starter
NWCgrad's Avatar
Liked: 1304
It is possible, and will be the first attempt!
Home Theater:
NWCgrad is offline
post #15 of 702 Old 07-18-2016, 08:30 PM
mfagains's Avatar
Liked: 26
Sub'd
NWCgrad likes this.
mfagains is offline
post #16 of 702 Old 07-18-2016, 08:47 PM
jshadzi's Avatar
Quoted: 99 Post(s)
Liked: 353
I highly recommend these, makes box clamping a breeze
http://www.woodpeck.com/boxclampm2.html
HTH,
Javad
NWCgrad likes this.
jshadzi is online now
post #17 of 702 Old 07-19-2016, 05:05 AM - Thread Starter
NWCgrad's Avatar
Liked: 1304
HTH,
Javad
I have one pair that I forgot all about and have never used...just ordered three more pairs so I can clamp all 4 corners simultaneously. I am a fan of pocket screws, after watching the video on the link you provided decided yep, these are the ticket. I am a fan of Woodpecker products.
asarose247 and jshadzi like this.
Home Theater:
NWCgrad is offline
post #18 of 702 Old 07-19-2016, 10:29 AM
asarose247's Avatar
Quoted: 816 Post(s)
Liked: 621
^ pocket screws and good clamping rock the DIY world
almost at the end of my 2nd box of 1000
don't forget the PL3X
NWCgrad likes this.
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #19 of 702 Old 07-19-2016, 10:58 AM
A9X-308's Avatar
Liked: 1142
In one of my early designs, I used a KEF B139 for bass with a 12dB slope to the mid at 300Hz or so. For ages there was a mid anomaly I and a friend could hear occasionally, but didn't show in the measured response*. It turned out the B139 had a sharp resonance over 1kHz. I built a notch for it and the problem was gone. Be very aware that out of band artifacts can turn out to be very audible with shallow slopes even if you think they're far enough out of band to be inaudible.
Another tip would be to not just focus on the FR, but other aspects such as distortion as well. Most drivers start to increase in THD at the lower end of their operating BW, but many do at the top as well. Just because the FR and acoustic slope on a midrange look good at 200Hz, doesn't mean that it won't perform better with a 300Hz xover because of something else like THD or maybe with a steeper slope. Just because the mid on your horn is going to give a nice roll off because it's in a small sealed enclosure, doesn't mean that it won't be better rolled off steeply. With a 200Hz 1st order you'll still be feeding it a significant amount of power below this and if the driver does increase in THD, the components produced will be in the active BW of the driver/flare and likely audible.
Before I moved back to Sydney, I had a very large 5 way front loaded horn system. It had been 3 years work and set up with as little xover as possible (it was powered by a monster own design tube amp**). Sounded great. But then I got the offer to try some new DSP xovers. On a whim, I decided to go the other way and try 8th order slopes. So with levels set I started to listen. It was one of the few jaw dropping experiences in audio for me.
In your response to my first post, you mentioned you'd read about what different slopes sound like: In my own experience, that's malarky. How many of those people have measured many aspects of the system to see what really caused the audible difference? In my experience of the DIY world, very few. They just change the slope and declare the result.
* This was on an analog CRO with custom logarithmic amplifiers. And no capture.
** For those who've read my comments on tube amps here over the years, I did it because it was fun to design and build. It had a lot of SS in it, so purists hated it. It was also the size of a three drawer filing cabinet and for 50W class A, drew >1kW from the wall at idle. I used an SS amp at least as often and was no less satisfied.
Scott Simonian, LTD02 and NWCgrad like this.
A9X-308 is offline
post #20 of 702 Old 07-19-2016, 11:07 AM
A9X-308's Avatar
Liked: 1142
Another thought is the 2242 is perfect for a 6th order ported bass alignment.
A9X-308 is offline
post #21 of 702 Old 07-19-2016, 11:10 AM
Bass Enabler
Liked: 5006
Great post, A9X.
On a very related note, I had recently had to re-do all my crossover settings for my mains. Made one change that really seemed to clean up the midrange. I went from a 24dB L-R to a 48dB L-R on the lowpass for the midrange. I was amazed how much clearer it sounded. Made no difference in the measured (total) response at all but it was audible. (it was measurable when isolated to just the midrange playing)
Anyway...this was a specific instance but it backs up with Alpha Niner is talking about. Already was recommending some steeper slopes than you planned for but also assuring that you need to listen while designing your own speakers. Don't just let some internet papers make your project for you. It becomes yours while you make it.
NWCgrad likes this.
post #22 of 702 Old 07-19-2016, 11:32 AM - Thread Starter
NWCgrad's Avatar
Liked: 1304
Thanks for the great input guys. I currently have the 2242's in the C4645B cabinet, which I believe fits the suggestion (I am assuming you are refering to a system built to utilize a +6 dB filter at resonance as a B6 alignment) and they sound great. With the enclosure being so big I can replicate the running of the 4645B.
Will track distortion on my REW measurements, not sure if a different software would do a better job. I am decent with REW so will probably stick with it.
I was thinking of putting a notch filter on the nasty 1.2 kHz peak on the 2242 if I have a free PEQ band after all the settings. I plan to replace the Peavey AVX with a dbx Venu360 next year which has a lot more powerful DSP engine.
A9X, I bolded the parts on slope above as I agree with you that the audible differences I read about may be over-stated. I trust your experience, and my own ears when the time comes, more than reading engineering stuff of the Internet (from Australia, http://education.lenardaudio.com/en/06_x-over_3.html, among other sources). I have published more than 20 peer reviewed scientific manuscripts and in the process I have learned how to turn a pigs ear into a silk purse.
I am so happy with gaining valuable input on this build. I am just about 52, this will likely be my last big speaker build. If I need to upgrade in 10 yrs or so I will probably just open up the check book and buy some studio monitors from one of the serious design teams (JBL, Meyer Sound, Adam, etc).
Home Theater:
NWCgrad is offline
post #23 of 702 Old 07-19-2016, 11:33 AM
Bass Enabler
Liked: 5006
post #24 of 702 Old 07-19-2016, 11:53 AM - Thread Starter
NWCgrad's Avatar
Liked: 1304
Any recommendations on enclosure material? The plan is 13-ply 18 mm Baltic Birch, but I was thinking about adding a 0.5" layer of MDF to the sides and rear of the enclosure. I know JBL used 1" particle board for their monitor enclosures, so I am wondering if 1.2" thickness would be better than 0.709" thickness. I hate MDF, but would be willing to use it inside the enclosure.
I loathe autocorrect and typing on a smart phone.
Home Theater:
NWCgrad is offline
post #25 of 702 Old 07-19-2016, 02:06 PM
jshadzi's Avatar
Quoted: 99 Post(s)
Liked: 353
Great, I love them, there are a few tricks to using them but once you figure them out they're perfect. Once issue is that as you tighten them down the actually pull the two pieces apart slightly, so as you tighten just rap the parts with a dead low to knock them back together tight.
With good clamping and gluing there is absolutely no need for pocket screws or any type of metal, and then you don't have to worry about routering after either.
Looks like a great project!
Javad
NWCgrad likes this.
post #26 of 702 Old 07-19-2016, 02:13 PM
Point Source
beastaudio's Avatar
Liked: 3348
Great post, A9X.
Completely different environment but I too found 48dB as my preferred slope when running my active 3 way, it actually was my preferred all the way around, but I did often switch to 24dB/oct. to confirm my own personal findings. Didn't have REW back then to fact-check myself tho....
post #27 of 702 Old 07-19-2016, 04:08 PM
LTD02's Avatar
Liked: 2835
the steep slopes are interesting as they reduce the passband of each driver which has benefits as many have mentioned. the downside is the additional phase roll. supposedly that is only audible under very controlled (contrived?) scenarios with headphones and test tones, but i can't help but wonder if all that phase messes up something in our brains. just seems too easy to slap very steep slopes in between the drivers and call it a day. except for the linear phase corrected examples, i can't really think off hand of anybody who does it this way. just thinking out loud....
Thatsnasty likes this.
LTD02 is online now
post #28 of 702 Old 07-19-2016, 04:14 PM
Molon_Labe's Avatar
Quoted: 2152 Post(s)
Liked: 2264
By then, the M2 might be affordable Awesome project Captain - rock steady.
NWCgrad likes this.
Molon_Labe is online now
post #29 of 702 Old 07-19-2016, 06:50 PM - Thread Starter
NWCgrad's Avatar
Liked: 1304
DSP driven crossovers will allow me to play, I mean objectively evaluate, slope and type (LR, Butterworth, etc.). REW should prove to be valuable in this evaluation, but ears are also critical.
The ability of FIR filters to set really steep crossover slopes while keeping phase under control is intriguing. Programs like rePhase make FIR-based crossovers readily accessible for the DIY community. I keep track of this capability but do not think I yet have the acumen to make it work. Perhaps someday a easy to use solution will be readily available.
Home Theater:
NWCgrad is offline
post #30 of 702 Old 07-19-2016, 06:53 PM - Thread Starter
NWCgrad's Avatar
Liked: 1304
Thanks Man! I am excited to see these big old fashioned speakers come to life. The M2 should be affordable by then, but at that point some new must have speaker technology will be the barely attainable goal.
Home Theater:
NWCgrad is offline
