Wet sanding paint for clear coat prep - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By Carbon66
  • 1 Post By Ferroll Givens
post #1 of 14 Old 07-22-2016, 08:35 PM - Thread Starter
Ferroll Givens's Avatar
Liked: 7
Question: If my base coat is pretty level, do I really need to wet sand it to get it perfectly smooth when I am going to cover it with a clear coat anyway? After several layers of clear coat are layed down, Would anyone really see the Imperfections below the clear coat once it is leveled and buffed out?
Ferroll Givens is offline
post #2 of 14 Old 07-22-2016, 08:41 PM
Carbon66's Avatar
Quoted: 25 Post(s)
Liked: 33
Most solid colors won't show anything, especially black. Getting into metallics is where you see the base. What paint system?
Carbon66 is offline
post #3 of 14 Old 07-22-2016, 09:05 PM - Thread Starter
Liked: 7
Paint System
I am working with Gloss Black oil base, and oil based Polyurethane.
Roughing up the black with 220 grit after fully cured, about one week. Then mixing in holographic powder in the polyurethane about two coats followed by two coats without the powder.
post #4 of 14 Old 07-22-2016, 09:19 PM
Carbon66's Avatar
Quoted: 25 Post(s)
Liked: 33
Ok. That's going to be a lot of cure time. Your first coat with the powder is going to be the most important. Go easy on the first and judge from there how much more you want on the second. You can always add more, but not less. Too much and they'll start getting into the charcoal grey family. Knocking the sheen off after a day or so will show you how much orange peel you have and will also let the solvents escape. Wet 320-500 on this step.
Carbon66 is offline
post #5 of 14 Old 07-23-2016, 01:31 AM - Thread Starter
Liked: 7
Here are the best pics for now of the painted surface.
ID:	1560953   Click image for larger version
Name:	Top Surface.jpg
ID:	1561777   Click image for larger version
Name:	Polyurethane Layers.jpg
uniquepattern likes this.
post #6 of 14 Old 07-23-2016, 05:39 AM
Quoted: 454 Post(s)
Liked: 47
Why would you wet sand the paint? Should you just go over it, lightly, with 400g dry sandpaper? That is what I normally do and it always works out well. I would also recommend going over your primer with 400g too, before you paint.
Tip24/96 is online now
post #7 of 14 Old 07-23-2016, 06:52 AM
Bill Fitzmaurice's Avatar
Liked: 4630
If it's very smooth then you don't need to sand. Typically when painting a car you specifically do not want to sand the color coat, as the clear coat will adhere better if it's not sanded. But that assumes that you're spraying and you're experienced in how to minimize orange peel. 'Pretty level' isn't good enough.
+1.
Bill Fitzmaurice is offline
post #8 of 14 Old 07-23-2016, 12:02 PM
Jk7.2's Avatar
Quoted: 151 Post(s)
Liked: 187
I have painted cars in the past. Typically we sprayed the clear over unsanded base coat, just used a tack cloth between coats. After clear coat is cured, we wet sanded with 1500 to remove orange peel, then 2000 to smooth the 1500 grit scratches, then wheeled out the clear to a high gloss with a three step process. Mirror finish by this point. Hope that helped.
Jk7.2 is offline
post #9 of 14 Old 07-23-2016, 12:38 PM - Thread Starter
Liked: 7
I am applying everything by hand. So that information may or may not apply, but thanks.
post #10 of 14 Old 07-28-2016, 07:18 PM - Thread Starter
Liked: 7
I guess not many of you have tried to do a Piano Black by hand ( no sprayer ). So here is the answer to my question, because now I know - Trial and error = Experience. Yes, applying a clear coat over imperfections will not eliminate them, no matter how smooth and flat the top clear coat is. A perfectly prepared base coat will allow for a perfect top coat. This my first attempt at a Piano Black finish.
post #11 of 14 Old 07-28-2016, 07:44 PM
Oval56's Avatar
Quoted: 14 Post(s)
Liked: 58
It goes back further .
A perfectly prepared surface allows for a perfect undercoat surface . Paints only for colour .
My back ground was automotive refinishing .
Cheers
DIY , Ikea Style
Oval56 is offline
post #12 of 14 Old 07-28-2016, 07:45 PM
Carbon66's Avatar
Quoted: 25 Post(s)
Liked: 33
Yes, you could get a piano black finish without spraying. But why? A cheap Harbor Freight gun is $15. Used compressor on craigslist for less than $100. I can't imagine sanding everything flat after rolling or brushing. Especially all of the paper you would go through with polyurethane.
Here's a link where I built some stands finished in "piano black" https://community.klipsch.com/index....heresy-stands/
Hopefully you can get a couple tips out of that thread. I would go with automotive paint, or even a rattle can system.
Carbon66 is offline
post #13 of 14 Old 07-28-2016, 08:51 PM - Thread Starter
Liked: 7
Cheers
Yes, that is very true, but already implied.
Trial and Error= Experience
post #14 of 14 Old 07-28-2016, 08:54 PM - Thread Starter
Liked: 7
I do not have the area to do spraying. I wish i did, and even if i did, I lack experience to do so. So I do what I can with what I have.
