Official JBL CS1214 thread - Replacement for Infinity 1260/1262 - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 127Likes
post #61 of 324 Old 08-26-2016, 08:45 AM
markymiles's Avatar
Quoted: 119 Post(s)
Liked: 50
Originally Posted by eng-399 View Post
If you have 4 of these jbl's then your box size would be 6.8 cubic ft in one box. You don't need anything dividing these subs up. Just install your window bracing inside like your saying and you will be good. There's no need to have separate chambers for each sub in a sealed box. Don't forget to stuff the box with r-13,polyfill,denim what ever you have available.
Thanks, couldn't think of any reason why, just that most people seemed to be doing it that way. Got loads of bits and bobs lying around from previous builds so won't need to buy anything else luckily. Really am so grateful to the op for this thread
markymiles is online now
post #62 of 324 Old 08-26-2016, 12:27 PM
zeus33's Avatar
Quoted: 1563 Post(s)
Liked: 1406
Originally Posted by styjp View Post
I also had the same question and based on the data-bass test, 8x JBLs driven safely should match an HS24, at least on paper.
You are aware that Josh does his measurements at 2 meters instead of 1 correct?
styjp likes this.
zeus33 is offline
post #63 of 324 Old 08-26-2016, 01:36 PM - Thread Starter
styjp's Avatar
Quoted: 47 Post(s)
Liked: 45
Forgot about it tbh! Thanks for that! It was an honest mistake! So all of the above measurements need to be +6? Correct?
Styj
styjp is offline
post #64 of 324 Old 08-26-2016, 06:09 PM
aaranddeeman's Avatar
Quoted: 1703 Post(s)
Liked: 619
In the official ED thread if you see last few pages, most of the folks (me included) have replaced the stock driver from ED A2-300 to Infinity 1260W.
That has worked very well with that box.
I was planning to add another A2-300 (if found in used market) by replacing the driver.
But discontinuation of 1260w was quite disappointing.
Looks like this JBL may do the trick?
Any ideas?
aaranddeeman is offline
post #65 of 324 Old 08-26-2016, 06:39 PM
Liked: 619
Originally Posted by VectorLabs View Post
Based on the dimensions they look like they would be drop-ins for the PE 1.5cu flat pack. What you all think? At $30 ea thinking of ordering two.
Did the price went up? It shows $42 everywhere..
post #66 of 324 Old 08-26-2016, 06:58 PM
Michael Mitten's Avatar
Quoted: 199 Post(s)
Liked: 175
Well I got 4 boxed up in a corner, not sure when I'll get to them because I got distracted by another 'hobby'. A 65 Bug.
corradizo, UGAd13, eng-399 and 1 others like this.
Michael Mitten is offline
post #67 of 324 Old 08-26-2016, 08:01 PM
Johnny P's Avatar
Quoted: 73 Post(s)
Liked: 71
SWEET CAR MIKE. All you need are the surfboards on top
Michael Mitten likes this.
Johnny P is offline
post #68 of 324 Old 08-26-2016, 09:41 PM
Liked: 619
Could some one please link an appropriate flatpack for the single sealed or ported sub that will work with this JBL driver?
TIA.
post #69 of 324 Old 08-27-2016, 04:52 AM
Quoted: 199 Post(s)
Liked: 175
Thanks. Should be a fun little car. Won't be doing a surfboard in Atlanta! LOL Probably some vintage stuff like luggage, cooler, old picnic basket, and whatever crazy stuff I feel like tossing on top. Today it's just a folding chair as I'm heading to my first VeeDub meet.
post #70 of 324 Old 08-27-2016, 10:05 AM
manuetdeo's Avatar
Quoted: 56 Post(s)
Liked: 79
Vintage luggage that is also a Bluetooth boombox! What any selfrespecting AVS'er would have on their roofrack😀
Sent from my LG-H830 using Tapatalk
Michael Mitten and styjp like this.
manuetdeo is offline
post #71 of 324 Old 08-27-2016, 04:21 PM
Quoted: 199 Post(s)
Liked: 175
Hmmmm, that could happen. She will have a Sundown 10" for a little bump.
post #72 of 324 Old 08-27-2016, 04:50 PM
Liked: 619
Any ideas?
I got a second A2-300 from local CL.
And looks like this JBL would be the replacement for the driver as Infinity 1260 is all gone.
Anyone replaced JBL in their A2-300?
post #73 of 324 Old 08-28-2016, 01:52 AM
Raylon's Avatar
Quoted: 264 Post(s)
Liked: 280
Will the JBL be a drop in replacement for the Infinity? My nearfield box I built for the Infinity's is super beefy and nice and if I didn't have to completely rebuild that if a 1260 craps out that would be awesome if I could swap them all out to JBL's.
Raylon is offline
post #74 of 324 Old 08-28-2016, 03:01 AM - Thread Starter
styjp's Avatar
Quoted: 47 Post(s)
Liked: 45
Based in eng-399's test it should work and also be a bit louder. You can check his infinity thread and post 1 in this thread for comparison measurements
Styj
styjp is offline
post #75 of 324 Old 08-28-2016, 04:43 AM
Quoted: 199 Post(s)
Liked: 175
Guess I need to make some sawdust.
aaranddeeman and styjp like this.
post #76 of 324 Old 08-28-2016, 05:05 AM
nnoble83's Avatar
Quoted: 12 Post(s)
Did anyone determine how these would do in an i-clops box?
nnoble83 is offline
post #77 of 324 Old 08-28-2016, 05:25 AM - Thread Starter
styjp's Avatar
Quoted: 47 Post(s)
Liked: 45
I hear you! Tomorrow!
Styj
styjp is offline
post #78 of 324 Old 08-28-2016, 05:54 AM
Quoted: 199 Post(s)
Liked: 175
What size enclosures are you going to build?
post #79 of 324 Old 08-28-2016, 07:06 AM - Thread Starter
styjp's Avatar
Quoted: 47 Post(s)
Liked: 45
1.7 sealed. 4 drivers on each channel of a 6k in series parallel
Styj
styjp is offline
post #80 of 324 Old 08-28-2016, 08:48 AM
1st Cav's Avatar
Quoted: 182 Post(s)
Liked: 83
I've got 2 JBL's in my possession and 2 more that should be here by tomorrow (secretly contemplating grabbing 2 or 3 more just for the hell of it ) for nearfield duties. Quick question, do I stand to gain/lose anything by going with the DIYSG 1.5cu ft flatpack vs the Sonic Electronix Belva drop in box (both sealed)? I'm game for either and my immediate guess is that the bracing and double baffle of the DIYSG box accounts for the slight markup in price over SE's version. For normal nearfield placement (few inches behind couch) is the cross bracing as critical?
http://www.diysoundgroup.com/sealed-...flat-pack.html
http://www.sonicelectronix.com/item_...va-MDFS12.html
1st Cav is offline
post #81 of 324 Old 08-28-2016, 09:28 AM
Liked: 619
I am interested to know as well.
The DIYSG is almost double the cost and you will also have a labor of putting it together and finishing it.
post #82 of 324 Old 08-28-2016, 10:43 AM
corradizo's Avatar
Quoted: 1183 Post(s)
Liked: 913
When I built my first subs I used car boxes, braced them with 2x4's, stuffed them with r13 and they worked great. If you don't mind the carpet, they are fine.
corradizo is offline
post #83 of 324 Old 08-28-2016, 12:50 PM
Quoted: 20 Post(s)
Liked: 4
I haven't even built my Infinity 1262 enclosures yet, and there is a part of me saying "You regret not getting more of the Infinity subs... just spend $260 on 8 of these".
Should I jump on em? I dunno what I would even use them for yet... but still.
mortron is offline
post #84 of 324 Old 08-28-2016, 01:11 PM
Liked: 619
Do these CS1214 come with gasket tape (that you stick when drop-in)?
If not, is there a place you can buy one?
post #85 of 324 Old 08-28-2016, 01:25 PM
corradizo's Avatar
Liked: 913
Closed cell foam weather stripping is all you need.
http://m.homedepot.com/p/MD-Building...nuRhoCpjHw_wcB
It's what I use. Make sure you mark your driver holes and put the stripping inside and away from the screw holes toward the driver hole on the box. You don't want to screw into it and twist it up.
styjp likes this.
post #86 of 324 Old 08-28-2016, 02:33 PM
Liked: 619
Just pulled the trigger on 4x CS1214,
Ha. I actually wanted 1 or may be 2, but oh well.
I plan to replace these in the eD A2-300. Hopefully they match up.
post #87 of 324 Old 08-29-2016, 02:29 PM
Quoted: 992 Post(s)
Liked: 332
hey guys, I just ordered 8 of these. I figured 8 12s have got to move some air!
I know nothing about VAS, QTS, etc
Can someone kindly give me an idea of how 8 of these would look with sealed boxes.
thanks
THANK YOU!!! for your selfless contribution to the audio world
Anders Torger for Brutefir
Thomas Drugeon for Rephase
John Mulcahy for room eq wizard
Denis Sbragion for DRC room correction
Juha Hartikainen for Winisd
1201 is offline
post #88 of 324 Old 08-29-2016, 05:11 PM
Johnny P's Avatar
Quoted: 73 Post(s)
Liked: 71
thanks
How do you plan on using these. Farfeild? Nearfeild? Half and half?
Johnny P is offline
post #89 of 324 Old 08-29-2016, 05:26 PM
Quoted: 992 Post(s)
Liked: 332
hi, thanks for the followup questions. i want to use four under my main speakers about 10.5 feet away, and 2 each side of the main couch, maybe 2.5 feet from the mlp
1201 is offline
post #90 of 324 Old 08-29-2016, 10:03 PM
Johnny P's Avatar
Quoted: 73 Post(s)
Liked: 71
The ones 2.5 feet from mlp are going to used as mbms(mid bass modules)??? Or in other terms tactile response??
Johnny P is offline
1260 , 1262 , cs1214 , Infinity , Jbl
