Can someone help me with my NU6000DSP? - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #1 of 45 Old 11-30-2016, 03:39 AM - Thread Starter
Mixdoctor's Avatar
Quoted: 240 Post(s)
Liked: 133
I have an iNuke 6000 DSP sitting here because I hate the power on thump. I know there is a diy on getting rid of that thump, but I am just not that good with the electronic thing, so I do not want to attempt it myself.
So, does anyone know who I can send this to do the mods which get rid of that damn turn on thump? Don't have any local fix it shops I know of to take it to.
Sony XBR75X940C
Martin Logan Spires
Seaton Submersive Pair
LG65E6 OLED
Mixdoctor is offline
post #2 of 45 Old 11-30-2016, 06:27 AM
Waterboy77's Avatar
Quoted: 573 Post(s)
Liked: 288
@Fattykidd who has those plug and play triggers?
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is online now
post #3 of 45 Old 11-30-2016, 07:19 AM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
I'm getting mine from a friend of @kevings .
Waterboy77 likes this.
Fattykidd is offline
post #4 of 45 Old 11-30-2016, 07:57 AM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
Here it is.. Had the pic in my phone.
post #5 of 45 Old 11-30-2016, 09:21 AM
FriscoDTM's Avatar
Quoted: 306 Post(s)
Liked: 278
The iNuke shouldn't necessarily thump at turn on or off - at least when I used my iNuke as a sub amp I only had it thump once or twice after moving some equipment around but it immediately went away after pulling everything out and cleaning up the signal and power wiring runs. Most decent amps mute the output while the amp powers up so the transient response in the electronics doesn't hit the output signal.
ejr1212 likes this.
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One S, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #6 of 45 Old 11-30-2016, 09:41 AM
1st Cav's Avatar
Quoted: 182 Post(s)
Liked: 83
Can you clarify what you mean by "cleaning up the signal and power wiring runs"? I also have humming and a thump coming from one of my inuke 3k's.
Sent from my SM-N930V using Tapatalk
1st Cav is offline
post #7 of 45 Old 11-30-2016, 10:21 AM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
Are you turning it on via the front button or a switched outlet on a power center?
All 3 of my 6kdsp thump when turned on via the powercenter. The relay and trigger negates this.
post #8 of 45 Old 11-30-2016, 10:46 AM
asarose247's Avatar
Quoted: 839 Post(s)
Liked: 645
from jan of 2014, BassThatHertz posted a link for a DIY SSR : you can check out my relay build thread for full details.
http://www.avsforum.com/t/1457157/di...tomation/0_100
the unit I built , after reading his stuff and also something out there from going back to info from @not ynt (iirc) lets me leave the powerswitch to the amp "on", and both are plugged into the SSR i built, on its own 20A line.
The trigger from the X5200 fires up the ssr and i hear a few small bumps as the amps come on.
the cleaning up wrt to turn-on as addressed by FriscoDTM was not an issue.
curious to see what you do.
and inspite of my own build, the unit from kevings for the smart lazy man . .
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #9 of 45 Old 11-30-2016, 12:19 PM - Thread Starter
Mixdoctor's Avatar
Quoted: 240 Post(s)
Liked: 133
There is a thump when you turn the 6000dsp on or off via 12v trigger. There is no thump when using the power switch.
Sony XBR75X940C
Martin Logan Spires
LG65E6 OLED
post #10 of 45 Old 11-30-2016, 12:54 PM
kevings's Avatar
Quoted: 299 Post(s)
Liked: 466
Agree 100%. I was hearing a VERY strong thump, each time I powered down my 6kdsp. For clarification, this was happening when my smart strip was cutting power to the amp, after I sent the "system off" command from my universal remote. The thump was loud enough that it would make people in the room jump, if they weren't ready for it.
I asked a buddy of mine, with a strong background in electrical engineering to come up with a harness that is as close to plug and play as possible, and he did. The harness allows for either smart strip or 12 volt trigger control and completely kills the power thump.
I did the install in about 15 minutes and I can now power down my amp via smart strip or via 12 volt trigger, and it's dead quiet ( I tested both methods ). I also recently helped my neighbor install the harness/relay in his 2 amps, and the thump is also now gone.
It's nice being able to power down the system now, without having to turn off the amps manually or give everyone a verbal warning about the power cycle thump.
If anyone has questions, please send me PM, since I may not be on the forum as much as I usually am, due to a few work projects I have going on.
kevings is offline
post #11 of 45 Old 11-30-2016, 04:39 PM
Jk7.2's Avatar
Quoted: 451 Post(s)
Liked: 655
I went with all 3000dsp's because they don't have this smart strip power down issue. I get the 6000dsp's only thump when power is cut to a powered on amp, but why don't the 3000dsp's do it also?
Jk7.2 is online now
post #12 of 45 Old 12-01-2016, 05:21 AM
1st Cav's Avatar
Quoted: 182 Post(s)
Liked: 83
Mine does
Sent from my SM-N910V using Tapatalk
1st Cav is offline
post #13 of 45 Old 12-01-2016, 08:12 AM
Jk7.2's Avatar
Quoted: 451 Post(s)
Liked: 655
Mine does
Interesting. I have six that do not. How are you controlling them? A smart strip?
Jk7.2 is online now
post #14 of 45 Old 12-01-2016, 08:34 AM
FriscoDTM's Avatar
Quoted: 306 Post(s)
Liked: 278
The issue I observed occurred just as a result of my disorganized wiring after I repositioned something. I thought it was an issue with the amp initially and don't know what triggered it, but it went away after repositioning and untangling some of the wires. Back then I was using an unbalanced to balanced signal cable plus a splitter on the signal wire, and there were a bunch of AC mains and other wires tangled into a big mess of sloppiness. Now for comparison all of my signal wires are DIY XLR cables and I have cable raceways separating signal wires from all AC, and I use the clone amp for my subs.
From what I recall about the internals of the 6000, the front panel switch triggers a relay on the board and perhaps you guys are hearing the thump because the circuit prior to the relay is supposed to always energized and provides the mute function when the amp powers on and off. If the front panel switch circuit isn't actually passing much current, you could probably also install a secondary switch onto that wire to accomplish the remote turn and make the amp function as though you were pushing the front panel button. If that's of interest I'd be happy to open my amp up and look into it.
post #15 of 45 Old 12-01-2016, 09:11 AM
kevings's Avatar
Quoted: 299 Post(s)
Liked: 466
Mixdoctor, I completely missed seeing this part of your first post. I sent you a PM.
kevings is offline
post #16 of 45 Old 12-01-2016, 10:37 AM
Quoted: 143 Post(s)
Liked: 120
I had an inuke6000 that never thumped once while I had it. I was using xlr cables between the receiver and the amp, and was powering on and off with the button on the front. My inuke3000 that I still have doesn't do it either.
Receiver: Emotiva Fusion 8100
Fronts: Klipsch klf-10 / Center: Klipsch klf-c7 / Surrounds: Klipsch klf-10
Subs: Two 18" Dayton PA460's + Paradigm PS-1200
Sub amp: Behringer Inuke3000dsp
Television: Sharp Aquos LC70SQ15U
Cryptic1911 is offline
post #17 of 45 Old 12-01-2016, 11:18 AM
kevings's Avatar
Quoted: 299 Post(s)
Liked: 466
It wouldnt thump in this case, because you are turning off the amp via the power button. What's being discussed in this thread is the thump that 6kdsp owners hear, when they power down their amps via a smart strip, instead of the power button.
So to clarify.....the setup that many people have is this:
AVR is plugged into a smart strip, into the master plug. Amps are plugged into the slave plugs. This is done so that when the owner turns their AVR off, the rest of their system turns off (which removes having to turn off amps 1 by 1). With the 6kdsp being turned off via smart strip, rather than power button though, a loud thump is heard by many users.
Cryptic1911 likes this.
kevings is offline
post #18 of 45 Old 12-01-2016, 11:26 AM
dtsdig's Avatar
Quoted: 912 Post(s)
Liked: 1038
Was your 6000 a DSP version?
dtsdig is online now
post #19 of 45 Old 12-01-2016, 11:27 AM
Quoted: 143 Post(s)
Liked: 120
Yeah, mine was a dsp version, but I skimmed over the post too fast. It looks like mine wouldn't have done it since I wasn't using a strip to control the power on the amp
post #20 of 45 Old 12-01-2016, 11:46 AM
1st Cav's Avatar
Quoted: 182 Post(s)
Liked: 83
Currently I only own two 3k's and just received a 6k in the mail Tues (unopened). The thump problem only happens with one of the 3k's.
They're both plugged directly into a standalone wall outlet and I turn them both off individually by depressing their power buttons. I've plugged the offending "thumper" amp into a different outlet and the problem follows. I'm able to control how hard it thumps by turning the amps gain knob up or down. Which coincidentally also affects how loud the hum is that emanates from the same amp.
1st Cav is offline
post #21 of 45 Old 12-01-2016, 01:43 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
I would try and get that fixed.. It's definitely not normal
post #22 of 45 Old 12-01-2016, 01:44 PM
1st Cav's Avatar
Quoted: 182 Post(s)
Liked: 83
Agreed. Question is, how?
1st Cav is offline
post #23 of 45 Old 12-01-2016, 01:48 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
Is it out of warranty? If so contact local repair shop for a quote... Could be less than you would expect.
post #24 of 45 Old 12-01-2016, 08:23 PM
FriscoDTM's Avatar
Quoted: 306 Post(s)
Liked: 278
Isn't that an indication of a DC offset at the output stage of the amp?
post #25 of 45 Old 12-01-2016, 10:30 PM
1st Cav's Avatar
Quoted: 182 Post(s)
Liked: 83
Shouldn't be out of warranty, I purchased one in April and the other in Sept. I'm just surprised there's no other workaround besides sending it back or taking it to a repair shop. What exactly would a repair shop be fixing anyway?
1st Cav is offline
post #26 of 45 Old 12-02-2016, 07:36 AM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
Sorry bud, that one's over my head... I do know that if I had an amp that was introducing noise into my system and was still under warranty I wouldn't hesitate for a second to send it .
post #27 of 45 Old 12-02-2016, 07:43 AM
Jk7.2's Avatar
Quoted: 451 Post(s)
Liked: 655
I had to return one. But it was purchased through Amazon so I just returned it, then bought another. The original has a noisy channel, the replacement was nice and quiet.
Jk7.2 is online now
post #28 of 45 Old 12-02-2016, 08:08 AM
1st Cav's Avatar
Quoted: 182 Post(s)
Liked: 83
I understand, just kinda frustrating especially since the problem seemingly came out of nowhere in the last month or so. All I've added to the system since purchasing the amp in question are my 1299's and I struggle to think that they've somehow added noise to the inukes signal...although anything is possible I guess.
1st Cav is offline
post #29 of 45 Old 12-02-2016, 08:10 AM
1st Cav's Avatar
Quoted: 182 Post(s)
Liked: 83
I purchased my 3k's from Sweetwater and my 6k from Amazon during the Black Friday sale. Guess I'll be giving my guy at SW a call to see if we can rectify this annoying issue asap.
1st Cav is offline
post #30 of 45 Old 12-02-2016, 08:36 AM
Jk7.2's Avatar
Quoted: 451 Post(s)
Liked: 655
Yeah good luck man. These little issues are a pita. It's always worth it in the end though.
Jk7.2 is online now
