Curved UM18 sealed build - AVS Forum | Home Theater Discussions And Reviews
 6Likes
  • 1 Post By MattSPL
  • 1 Post By MattSPL
  • 1 Post By michaelddd
  • 1 Post By OJ Bartley
  • 1 Post By MattSPL
  • 1 Post By sandydankness
post #1 of 16 Old 12-18-2016, 03:50 PM - Thread Starter
MattSPL's Avatar
Quoted: 16 Post(s)
I started building this enclosure about 4 years ago, but left it unfinished in my shed for various reasons, until a month ago I decided I needed bass back after selling my Velodyne DD12 at the start of the summer.
Here's the build pics from 4 years ago
Here's how I left it until taking it out the shed last month
Mashie Saldana likes this.
MattSPL is online now
post #2 of 16 Old 12-18-2016, 03:54 PM - Thread Starter
MattSPL's Avatar
Quoted: 16 Post(s)
I used 'No more nails to fill the kerf cuts
Marking the cutout for the driver
I rounded over the edges with the router
post #3 of 16 Old 12-18-2016, 03:59 PM - Thread Starter
MattSPL's Avatar
Quoted: 16 Post(s)
This was painstakingly slow dripping glue down the cuts from the top and bottom to fill where the 'No more nails' didn't reach.
Hole for the speakon connector
The UM18-22
Extra bracing added
Acoustic wadding
And driver installed
Amp is an inuke6000dsp
sdb777 likes this.
post #4 of 16 Old 12-18-2016, 04:27 PM
michaelddd's Avatar
Quoted: 321 Post(s)
Liked: 207
Well, I would say the glue is probably dry by now.
Very nice build. I've always wanted to try kerfing MDF but just never had a need...and probably not the talent either. And kerfing 3/4" stuff must be pretty challenging. It was smart to fill in the kerf gaps with filler or glue or whatever that stuff is.
I would imagine that you've moved since you started this build? Typically when someone builds anything other than a square box, it's for looks. I.E. the final product will be out in the open and seen. Looks like now, it's in a corner. Nothing wrong with that, of course, but sort of a shame to hide all that hard work. What are the plans for finishing the box?
MattSPL likes this.
michaelddd is offline
post #5 of 16 Old 12-18-2016, 04:52 PM - Thread Starter
MattSPL's Avatar
Quoted: 16 Post(s)
Thanks Michael.
The MDF is 1" and it was trial and error gradually cutting into it until it bent enough.
My original plan was that this would be a test box for size and shape, then I wanted to build a curved stacked ply box and leave the layers of bare wood on show.
I'm in the same house but moved the room around 90deg to mount the tv over the fireplace to save floor space, so I'm a bit tight for space
I'm unsure on how to finish the sub yet as I'm going to build another but don't know if I can face the effort of another curved box to match this. I might even build subs into units for storage like a sideboard.
Cheers
Matt
post #6 of 16 Old 12-19-2016, 10:47 AM
OJ Bartley's Avatar
Quoted: 145 Post(s)
Liked: 225
Step 1: Leave unfinished for 4 years.
Step 2: Remove dust...
It looks really cool, and I can understand not wanting to go through that process again for another curved box... but think how awesome a pair of them would look. Finish them both at the same time. Really nice build.
MattSPL likes this.
OJ Bartley is online now
post #7 of 16 Old 12-19-2016, 04:11 PM - Thread Starter
MattSPL's Avatar
Quoted: 16 Post(s)
I might convince myself to build another in the spring or summer as I would like a matching pair.
I hope to use them as speaker stands, like a Wilson audio watt puppy style with something between speaker and sub for isolation.
post #8 of 16 Old 01-06-2017, 04:18 PM
Brazle's Avatar
Quoted: 46 Post(s)
Liked: 32
How does it sound!? Box looks good to me!
HT setup: Vizio 50" 4K | Xbox & PS3 | Pioneer Elite VSX-94TX | Bose 701 towers (V1) | JBL S Center | Def Tech Reference SuperCube & Def Tech PF15TL+
Brazle is online now
post #9 of 16 Old 02-15-2017, 01:23 PM - Thread Starter
MattSPL's Avatar
Quoted: 16 Post(s)
It sounds great. Only playing 30hz and down at the moment as my speakers are running full range.
It's reaching down to 5hz with plenty of eq and room gain. Having the door open in the room causes quite a large peak at 8hz which seems useful
Brazle likes this.
post #10 of 16 Old 02-17-2017, 06:55 AM
Mashie Saldana's Avatar
Quoted: 511 Post(s)
Liked: 304
What is the internal size/volume of that enclosure? I like the curves.
My HT build: Tower Cinema - 9.1.6 in a 12'x12' room
Marantz | NAD | Monitor Audio | SVS | Pioneer
Mashie Saldana is online now
post #11 of 16 Old 02-17-2017, 03:31 PM
sandydankness's Avatar
Quoted: 107 Post(s)
Liked: 75
Perhaps your room is acting as a huge bandpass enclosure, and the door is the port
MattSPL likes this.
sandydankness is offline
post #12 of 16 Old 02-17-2017, 03:35 PM - Thread Starter
MattSPL's Avatar
Quoted: 16 Post(s)
The cabinet is 22 inch cubed, but curves to about 18 inches at the back. I guess around 100 to 120L.
It's built from 1 inch mdf with a 2 inch baffle and lots of Acoustic wadding inside.
post #13 of 16 Old 02-17-2017, 03:36 PM - Thread Starter
MattSPL's Avatar
Quoted: 16 Post(s)
Yes I think your right, because when I close the door, the 8hz peak flattens out.
post #14 of 16 Old Today, 11:20 AM
Quoted: 12 Post(s)
Liked: 1
Subscribed
Purenv is online now
post #15 of 16 Unread Today, 01:31 PM
erik.vanhamme's Avatar
Quoted: 29 Post(s)
Liked: 1
Was the reason for the curve to reduce standing waves, or just for looks? I considered going trapeziod for mine to not have all the panels parallel.
erik.vanhamme is online now
post #16 of 16 Unread Today, 02:19 PM - Thread Starter
MattSPL's Avatar
Quoted: 16 Post(s)
It was partially for looks and also to reduce standing waves.
This box was originally intended as a test box for an LMS Ultra, then I was going to attempt a layered birch ply box. All these ideas went out the window due to finances.
Then recently I decided to finish this box but on a tighter budget, so the UM18 and nu6000 were the logical choice as I can add a second sub to this amp when I have the time and money to build one.
