Can folded horn subs fit an enclosure 17"w X 19"h X 19"d for Home Theater? How low? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 31 Old 01-05-2017, 05:25 PM - Thread Starter
Lynx_TWO's Avatar
Question Can folded horn subs fit an enclosure 17"w X 19"h X 19"d for Home Theater? How low?
Hello!
My wife and I are building a new house, and everything is wired for speakers and subs. There are two enclosures framed in with the rough framing being 19"w X 21"h X 20"d. There is 5/8 typeX drywall going in throughout the house, so the enclosure will actually probably be more like 17.75"w X 19.75"h X 19"d
The two subs will be about 16' apart sitting in the enclosures built into the front wall.
We are kinda being pushed toward two SunFire HRS-12 sealed subs ($1k each)
I built a BFM AutoTuba several years ago and used it for a HT sub for awhile. I love the effortless deep bass out of the thing.
I do enjoy making my own stuff, and if I'm gonna spend $2k plus taxes on subs that will be hidden in boxes, I'd rather have the fun of building something better if possible...
I wanted to build two full HT Tubas, but the WAF shut that down quick
Are there any plans for two folded horn tuba subs that would work for this application, or do I have to go with two sealed subs?
If I have to go with sealed subs, are there any plans that would fit the bill and be at least a good as the crossfire subs?
Thanks so much in advance for your time!
Yay! A Signature!
Lynx_TWO is offline
post #2 of 31 Old 01-05-2017, 05:37 PM
Samps's Avatar
Quoted: 939 Post(s)
Liked: 529
Pretty small for horns. Probably better off with two high powered sealed 15s. I'm not sure what the go to 15 is for a small sealed cab. The sundown zv4 is one of the best 18s in small sealed. The 15 is likely also good. Then you just need as much amp as you can afford. With 2,000 to spend you might have enough for a speakerpower amp. That would crush that Sunfire setup.
Samps is offline
post #3 of 31 Old 01-05-2017, 06:01 PM
Liked: 5
Originally Posted by Lynx_TWO View Post
Hello!
only tuba in that size scale would be the t18, which while enjoyable for a lot of music, hardly digs for home theater.
why are your only choices horn or sealed?
VegaMan is offline
post #4 of 31 Old 01-05-2017, 06:51 PM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 533
That size box is about 3 CF gross internal. A sealed 15, maybe a ported 12 would be the best you could do. But you can easily beat 1K each.
If possible, make that space larger. You can do two sealed UM18s for less than 2 grand, if you can make the space larger, more like 5 CF gross.
Also, rather than building a cubby to place a sub in, make the cubby the sub enclosure. Deck it with plywood instead of drywall, and that becomes the sub enclosure itself.
rhodesj is offline
post #5 of 31 Old 01-05-2017, 09:17 PM
asarose247's Avatar
Quoted: 838 Post(s)
Liked: 644
It's Table Tuba, a 30x30x16 inch horn loaded sub
@ billfitzmaurice.com
maybe
Lynx_TWO likes this.
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #6 of 31 Old 01-06-2017, 04:46 AM - Thread Starter
Lynx_TWO's Avatar
All good suggestions, but I guess I'm going to have to go with sealed 15's as the WAF wont allow anything bigger... I was thinking perhaps the Dayton Audio UM15-22 15"
As for reasons why sealed or folded horn, I've never really liked the sound of ported subs, plus it's not a good idea to put a ported sub in a hole in the wall The Tube18 would fit, but there's a big drop at 50hz, so not really great for movies...
The box will need to be in the cabinet, can't build the sub directly into the enclosure however, I might be able to not line the inside of the framing, so that could maximize cabinet volume... If I build the box with two layers of 3/4" MDF, or a layer of MDF on the inside clad with 1/2" baltic birch plywood on the outside, that should stiffen it enough, right? Weight is not an issue...
Yay! A Signature!
Lynx_TWO is offline
post #7 of 31 Old 01-06-2017, 05:42 AM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 533
That's a solid driver. Pair them with an NU6000DSP. Note that you'll want speaker cable run to the subs, not RCA or other line level cables.
Just curious, why not?
Noooooo, that's just going to waste huge amounts of interior volume. Do a single layer of MDF or BB and brace liberally tic-tac-toe style.
rhodesj is offline
post #8 of 31 Old 01-06-2017, 10:07 AM
asarose247's Avatar
Quoted: 838 Post(s)
Liked: 644
Ultimax 15 Sealed Build
google this, a recent build here at AVS from 2015
maybe some good ideas and results for your constraints
HTH
post #9 of 31 Old 01-06-2017, 10:14 AM
asarose247's Avatar
Quoted: 838 Post(s)
Liked: 644
are several,
seemed like good info / discussion in the thread , but not exclusively, by
@techguysteve
post #10 of 31 Old 01-06-2017, 05:18 PM
biga6761's Avatar
Quoted: 42 Post(s)
Liked: 74
Love my um18-22. Ultimax are no joke. A couple 15" in sealed flat packs from Parts Express in the driver and cabinet bundle are about $400 each. That leaves a great budget for some serious power which the Ultimax likes. Like someone mentioned already SpeakerPower is where it at or you could risk a Lab Gruppen Clone from Sanway or Inuke like me.
I would stay away from the Sunfire's for 2k as that buys a lot of sub from Hsu or SVS if you decide not to go DIY. Either company offer potent sealed subs that should fit your size requirements.
So many options but if it were my 2k I'd have 4 sealed Ultimax 15's flat packs and an Inuke 6000. Happy with both mine!
Panasonic PT-AE4000 100" 16:9 125" 2.35:1 - Xbox One S - Philips BDP7501 UHD
Marantz av7702 - 2 Crown Xls 2000 - 1 Crown Xls 1500 - 1 Qsc rmx 850 - 2 Inuke 3000dsp -
Speakers= 5.1.4 Atmos NHT's} 2 _ 2.9's - 2 _ Sb 3's - 1_ Ac-2
Subs= 1 Si HT18 D2 Stonehenge - Full Marty UM18-22 - 2 Buttkicker LFE's -
biga6761 is online now
post #11 of 31 Old 01-08-2017, 08:33 PM - Thread Starter
Lynx_TWO's Avatar
OK, so. Since the enclosure size is set, I'm working with what I have at this point
I built a box in sketchup, and calculated the internal volume using 1" dowels for bracing.
Internal volume of the Box: 5033.4375 in^3
Internal volume of the 1" dowels: 650.3096793 in^3
Internal volume of the driver: 224.64 in^3
Actual volume of the box once driver and bracing is accounted for:
4158.487821 in^3
--or--
2.40625 ft^3
I see from research, stuffing the box with polyfill can make the driver "see" up to a 40% larger enclosure(?), so best case scenario the driver would "see" a box that is:
3.36875 ft^3
Anyone have any ideas for miniDSP or similar to maximize output?
ID:	1883633   Click image for larger version
Name:	Sub Exploded View.png
ID:	1883641   Click image for larger version
Name:	Left & Right Panel.png
ID:	1883649   Click image for larger version
Name:	Front and Back.png
ID:	1883665   Click image for larger version
Name:	Top & Bottom Panel.png
Name:	No Damping.png
ID:	1883681   Click image for larger version
Name:	Max Damping.png
Yay! A Signature!
Lynx_TWO is offline
post #12 of 31 Old 01-09-2017, 09:18 PM - Thread Starter
Lynx_TWO's Avatar
Oh my... I just figured out an UM18-22 will barely fit into that box....
I will be re-modeling this tomorrow, but I think with some power, a miniDSP and Linkwitz transform, we just might have a winner!
Yay! A Signature!
Lynx_TWO is offline
post #13 of 31 Old 01-10-2017, 01:54 PM
andrewlef's Avatar
Quoted: 130 Post(s)
Liked: 45
What's behind that wall? Would infinity baffle work?
andrewlef is offline
post #14 of 31 Old 01-11-2017, 04:00 AM - Thread Starter
Lynx_TWO's Avatar
I don't think IB would work as the left sub goes into the master bedroom closet and the right sub goes into the second bedroom closet. Since the rooms are all open doorway, no such luck. Plus there's that WAF again lol
Yay! A Signature!
Lynx_TWO is offline
post #15 of 31 Old 01-11-2017, 09:07 AM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 533
Sorry, that's a complete misnomer. Stuffing lowers Qtc, and making the box larger lowers Qtc. But stuffing lowers efficiency, and the smaller box will limit driver excursion, so you'll lose output no matter how much you stuff it. Larger boxes increase efficiency, which means more excursion for less power, and more low-end bass.
I personally wouldn't consider using a UM18 in less than 4 CF net internal, and with 2.4, you're on the small side for the UM15 as well. That's why I was suggesting making the spot into the enclosure, rather building a cubby and sliding a sub into it. It lets you maximize volume for the driver.
rhodesj is offline
post #16 of 31 Old 01-11-2017, 10:08 AM - Thread Starter
Lynx_TWO's Avatar
OK, so what about shortening the sub enclosure to like 12", sealing the front, sealing where the box frame meets the concrete, and leaving the back totally open? The sub would be then open to the rest of the box frame and the insulated wall cavity.
The issue with building the box into the current frame is that there is 5/8 drywall currently on the outsides of the boxes where they protrude into the closets. Will upload a couple more detailed photos later tonight.
Lynx_TWO is offline
post #17 of 31 Old 01-12-2017, 04:35 AM - Thread Starter
Lynx_TWO's Avatar
OK< so actually I just re-built the frame in Google Sketchup, and even with the massive amount of 2x4s as seen in the photos, the internal volume is 9.01 cubic feet! I am having them framed boxes clad in 3/4" plywood with construction adhesive today to make the box air tight, and will also seal from the inside. Also, the boxes don't not lead into the wall cavity which is a bonus.
Think I'll still need any bracing?
Name:	_Framing ISO view.png
ID:	1890361   Click image for larger version
Name:	_Framing Bottom view.png
ID:	1890369   Click image for larger version
Name:	_Framing Back view.jpg
ID:	1890377   Click image for larger version
ID:	1890385   Click image for larger version
ID:	1890401   Click image for larger version
ID:	1890409   Click image for larger version
ID:	1890417   Click image for larger version
Name:	_Framing Top view.png
ID:	1890425   Click image for larger version
Name:	_Framing Right view.png
Name:	_Framing Left view.png
Yay! A Signature!
Lynx_TWO is offline
post #18 of 31 Old 01-12-2017, 06:54 AM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 533
Now you're cooking with gas. I'd think about a single brace tieing the sides together, and maybe one from the top down to the bottom, as the sides and the top look like relatively large panels.
Be sure to figure out how you're powering the thing. If you're using an amp like the oft-recommend NU6000DSP, figure out where you want it and have appropriate speaker wire run to the sub.
rhodesj is offline
post #19 of 31 Old 01-12-2017, 02:16 PM - Thread Starter
Lynx_TWO's Avatar
Awesome, will definitely do that! That was actually gonna be a question for you - currently I have only line-level going to each box, along with a separate 20-amp outlet. Is there a good way to get a seperate amp that will take the line-level and simply amplify? Will the miniDSP work with that? I'd like to amp and EQ each sub separately if possible, with a short line right to the driver - I'd just leave the amp and miniDSP in the box
Oh, also, see attached what the contractor sent:
ID:	1891713   Click image for larger version
Yay! A Signature!
Lynx_TWO is offline
post #20 of 31 Old 01-12-2017, 02:45 PM
Bigus's Avatar
Quoted: 412 Post(s)
Liked: 386
Looks like you are on the right track. This should work great.
Bigus is offline
post #21 of 31 Old 01-12-2017, 03:36 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
You've just obviously never heard a properly implemented ported sub.
Rubbish, so long as the port is on the front.
A9X-308 is offline
post #22 of 31 Old 01-12-2017, 04:51 PM - Thread Starter
Lynx_TWO's Avatar
Ahh yes, good point!
Sent from my iPhone using Tapatalk Pro
Yay! A Signature!
Lynx_TWO is offline
post #23 of 31 Old 01-12-2017, 05:16 PM
rhodesj's Avatar
Quoted: 942 Post(s)
Liked: 533
Budget? Do the amps need to be quiet? How silent? How much power do you think you want? How many subs are you planning on? And in four months, when you want more bass than that, how many subs will you really have?
There are plate amps, some that even have a built in DSP. There are silent amps. There are amps with lots of power. Getting all those qualities can be expensive.
rhodesj is offline
post #24 of 31 Old 01-12-2017, 06:21 PM - Thread Starter
Lynx_TWO's Avatar
Well, we were looking at the SunFire 12" sealed (2) for 1K each plus tax, so I wouldn't want to go past 2k in total. The amps would need to be quiet, would need to be able to put out 800-1000 watts (preferably continuous, not peak)
We will only have the two, there's no room for more (WAF, otherwise I'd have two TubaHTs )
Would probably be using two miniDSPs after reading a little about their capabilities, but didn't know if it'd be possible to eq the line level signal to the amp between the AVR and the amp...
Yay! A Signature!
Lynx_TWO is offline
post #25 of 31 Old 01-12-2017, 06:44 PM
Bigus's Avatar
Quoted: 412 Post(s)
Liked: 386
Yes, minidsp goes between avr sub out and amp. You only need one minidsp (smallest one the make can handle two channels... one or two channels in from avr, doesn't matter, then two channels out, one to each sub each with own eq if needed).
Bigus is offline
post #26 of 31 Old 01-13-2017, 07:11 PM - Thread Starter
Lynx_TWO's Avatar
Any thoughts on doing Compound or Isobaric - Dual Drivers setup such as here?
http://www.danmarx.org/audioinnovation/theories.html
Yay! A Signature!
Lynx_TWO is offline
post #27 of 31 Old 01-14-2017, 12:22 AM
A9X-308's Avatar
Liked: 1142
Don't bother with isobaric. The link explains why.
What do you mean by 'compound'?
A9X-308 is offline
post #28 of 31 Old 01-14-2017, 01:08 PM - Thread Starter
Lynx_TWO's Avatar
Basic Theory
Two drivers are mounted together in an enclosure with a cavity of air between the two drivers. The drivers must operate in phase with each other. The cavity of air between the drivers should be made as small as possible without compromising the operation of either driver. The modeling for this type of enclosure is done just as you would any other speaker enclosure except you take the Vas of the driver and divide by 2. This will in effect make all your speaker enclosures half as big as they would normally be for any particular driver.
Advantages
Improved sonic bass response. Bass is claimed as being tighter, faster, more accurate and more pure. Vas of the driver is cut in half. The volume of enclosure required to obtain a specific frequency response can be achieved in only half the volume. This is where isobaric enclosures have their biggest advantage.
Disadvantages
Wasted amplifier power to driver the internal sub. Efficiency of the system is down 3 dB as compared to a single driver due to the added cone mass and the reduced Vas. When you compare isobarics to a system which houses two drivers each in their own enclosure, this system wis actually 6 dB less efficient.
Best Applications
Where size is a big issue. When you want the box to be very small. Where more accurate bass is more important than lots of bass. If you have a hefty amplifier with plenty of juice to spare and a driver that can handle a good amount of power. Suited for music, home theater and car. Not used too often these days.
However, I just modeled it and it wouldn't work anyway due to lack of physical size of the box
Name:	Isobaric - Won't work.png
Yay! A Signature!
Lynx_TWO is offline
post #29 of 31 Old 01-14-2017, 01:14 PM
asarose247's Avatar
Quoted: 838 Post(s)
Liked: 644
quote: Bass is claimed as being tighter, faster, more accurate and more pure.
and , if not using the "wrong' speaker stands elsewhere in the room, the bass will also be less "flabby".
who writes this stuff anyway ?
post #30 of 31 Old 01-15-2017, 07:10 AM - Thread Starter
Lynx_TWO's Avatar
C'mon now, you know it's people who, to them, audio is a religion and not a science. It's kinda like the Audioquest speaker cable box I saw the other day that claimed using their cable "reduces harshness and confusion" Oh my g-d, the cable that brings clarity to my eyes and lightens my wallet (hears angels singing)
In addition, after poking around the internet a bit it seems the consensus is, with the advancement of driver technology, unless you are doing car audio where there is no space, the benefits of isobaric are becoming pretty minimal.
I have uploaded the Sketchup file along with the volume calculations if anyone is interested - wants to check for errors Looks like the total box volume after all is said and done will be ~8.22 ft2
Off topic, before uploading any PNG or JPG files y'all may want to compress them first using TinyPNG (google it, it's free) The server storage will thank you I'm sure!
ID:	1896353   Click image for larger version
Name:	Sub Design_top View.png
ID:	1896361   Click image for larger version
Name:	Sub Design_Left View.png
ID:	1896369   Click image for larger version
Name:	Sub Design_ISO View.png
ID:	1896377   Click image for larger version
Name:	Sub Design_back View.png
Yay! A Signature!
Lynx_TWO is offline
15" subwoofer , sealed box , sealed subwoofer , small enclosure , tuba ht
