2453H-SL on STX825 waveguide over 2265g-1 center channel - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 30Likes
post #31 of 38 Old 08-12-2017, 06:36 PM - Thread Starter
notnyt's Avatar
Quoted: 2790 Post(s)
Liked: 2569
Originally Posted by joebuddyguy View Post
What do you think of the STX waveguide vs 2384? Do you feel its a decent compromise? Is there much of a difference? Thanks for your contributions in testing the various large format compression drivers...I've never heard one in a home setting and I'm interested in trying it out... perhaps cloning a 4722 but using a different lower section maybe if I can't find the 265-h2 drivers at a reasonable price.
Sent from my XT1034 using Tapatalk
The STX waveguide seems to be ok down to like 800hz, but that's as low as you can really run it. It's newer JBL tech so it should be solid, but I haven't gotten to measure off axis on it yet.
The 2384 is awesome, but it's also huge. The 2384 provides a good coverage pattern with smooth off axis response. If you can fit it, don't see any reason not to. The 2384 won't control the pattern down as low, but it seems fine to me so far using at with a steep 800hz xover. Sounds great, no complaints, but I am also using it in a treated room... At some point I'll get it out into a field and take some measurements, but no idea when that's gonna be.
If you're going to clone the 4722, no need to use a 265h-2, you might want to look at the 2265hpl. I used a single 2265g-1 just to keep impedance close to the 4722s bottoms I use for the L/R, but if you're using 2 15s, and of the H drivers in parallel should do. The 2265hpl is a better driver than the 265h-2 and easier to get a hold of. They're all good diff drive units, but if using only one, the 265h-2 can't handle as much power.
When I checked on the price/availability of the 265h-2, there was a big lead time, and the price didn't make sense. The 2265s should do just fine.
joebuddyguy likes this.
notnyt is offline
post #32 of 38 Old 08-12-2017, 08:11 PM
joebuddyguy's Avatar
Quoted: 65 Post(s)
Liked: 110
Thanks for the info man... I'll likely be using 2384s over the 2265 then if/when I proceed
joebuddyguy is online now
post #33 of 38 Old 08-12-2017, 09:45 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
@notnyt
any idea what the difference is between the 265h-2 and the 265h-1?
they appear to use the same cone:
http://reconingspeakers.com/product/...-1-recone-kit/
and they appear to have the same thiele small parameters:
http://www.jblproservice.com/pdf/thi...parameters.pdf
Listen. It's All Good.
LTD02 is offline
post #34 of 38 Old 08-13-2017, 01:14 AM - Thread Starter
notnyt's Avatar
Liked: 2569
@notnyt
I think the 265h-1 originally used a lighter colored cone material. not sure what any actual differences are between them. Maybe the revision was just due to this change? no idea.
LTD02 likes this.
notnyt is offline
post #35 of 38 Old 08-13-2017, 02:05 AM
LTD02's Avatar
Liked: 2888
good eye. that seems to be it. i wouldn't be surprised if that was when they shifted from producing cones in ca to mexico. anyway...perhaps they are available. note also, the ribbing is gone.
265H-1 is still listed on the main web spec page:
while the spec sheet has been updated to reflect the new (dark) cones. it seems the change was made at least as far back as 2009 as that is the date on the pdf properties reflecting the change to the 265h-2
so, sites like this may just be using the old model number, since the picture is showing the dark cone.
original with light cones
newer vintage (2013 or so).
ID:	2266964   Click image for larger version
ID:	2266966   Click image for larger version
Name:	265h-1 jacks.png
ID:	2266970   Click image for larger version
Name:	old photo.png
ID:	2266972   Click image for larger version
Name:	new photo.png
bscool likes this.
LTD02 is offline
post #36 of 38 Old 08-13-2017, 06:43 AM
emilime75's Avatar
Quoted: 56 Post(s)
If only they could get their documentation right.
bscool likes this.
emilime75 is offline
post #37 of 38 Old 08-13-2017, 04:50 PM - Thread Starter
notnyt's Avatar
Liked: 2569
rofl, jbl's documentation is notoriously bad.
notnyt is offline
post #38 of 38 Old 08-13-2017, 05:36 PM
emilime75's Avatar
Quoted: 56 Post(s)
Oh, I'm well aware. Kinda sad, for such a company, with wrong part numbers, wrong photos for products being advertised...
