2453H-SL on STX825 waveguide over 2265g-1 center channel - AVS Forum | Home Theater Discussions And Reviews
 10Likes
  • 6 Post By notnyt
  • 1 Post By notnyt
  • 1 Post By notnyt
  • 1 Post By notnyt
  • 1 Post By notnyt
post #1 of 26 Old 01-09-2017, 10:08 AM - Thread Starter
notnyt's Avatar
Quoted: 2273 Post(s)
Liked: 2090
Thumbs up 2453H-SL on STX825 waveguide over 2265g-1 center channel
Just got this together the other day to replace a 3677 I was using as a center channel. I needed something that could fit under my screen and wanted something to that would match my left and right closer (4722 with 2452h-be). Very happy with how this came out, sounds great. I considered using the D2430k, but I like the 4" aquaplas and Be CDs better after comparing them back to back.
I'm running this full active driven by a pair of NC400s using brutefir for processing with filters from FIR Designer and an RME fireface UFX+ interface. Keeping the noise floor low was a challenge, but the good interface plus a 12db pad from an autoformer worked well. I compared the 4722s with the network driven by my AVR to running with the active setup and the active config actually ended up quieter.
My build on left, 3677 right.
guts, 3636 autoformer and 100uf cap
bracing and damping
CD w/ spacer
"Rough" eq/xover, will refine this later.... 1/48 smoothing with 35 cycle window.
time aligned step response and impulse. Some room interaction here. I wanted to measure this outside, but winter and snow had different ideas.
linear phase
native response of 2453h-sl on stx825 w/ spacer. There's a bit of a gnarly dip/phase issue without it.
All components without any EQ
impedance
Frohlich, baniels, Erich H and 3 others like this.
notnyt is offline
post #2 of 26 Old 01-09-2017, 10:16 AM
MKtheater's Avatar
Quoted: 1622 Post(s)
Liked: 1156
Very nice! How much did this cost? I wish you tried out the DIYSG BA-750 and SEOS 18 guide. It would be interesting to compare nonetheless.
MKtheater is online now
post #3 of 26 Old 01-09-2017, 10:20 AM - Thread Starter
notnyt's Avatar
Liked: 2090
Haven't tried them. Cost was about $900 for the woofer, cd, waveguide, cap, transformer, wood, paint, etc. The JBL bits came from speakerex.com
notnyt is offline
post #4 of 26 Old 01-09-2017, 11:28 AM
MKtheater's Avatar
Liked: 1156
Not bad, how would compare them to the stock 4722n?
post #5 of 26 Old 01-09-2017, 08:47 PM - Thread Starter
notnyt's Avatar
Liked: 2090
better, the cd goes a long way. if you want plans I can post.
MKtheater likes this.
notnyt is offline
post #6 of 26 Old 01-10-2017, 12:15 AM
chrapladm's Avatar
Quoted: 852 Post(s)
Liked: 293
I forgot you used the 2265 woofer. I, for some reason, thought you used the 22??(2216?) Whatever the M2 woofer was. Anyways everything looks great.
chrapladm is offline
post #7 of 26 Old 01-10-2017, 07:19 AM
tuxedocivic's Avatar
Quoted: 1923 Post(s)
Liked: 1746
Looking good nyt. Have a summed response? This is a 4" diaphragm? Nice top end if it is!
Ryan
tuxedocivic is online now
post #8 of 26 Old 01-10-2017, 08:54 AM - Thread Starter
notnyt's Avatar
Liked: 2090
Yep, 4" CD, ti+aquaplas. I"ll be messing with it and taking more measurements when I get some time again. I still have to start the filters for the l+r
notnyt is offline
post #9 of 26 Old 01-10-2017, 01:31 PM
VicTorious1's Avatar
Quoted: 430 Post(s)
Liked: 433
This looks familiar. I think another guy had a thread with a similar build. Any plans to make speakers similar to, but larger than, your custom center to replace the 4722Ns? I followed your build thread and the center speaker looks quite nice.
VicTorious1 is online now
post #10 of 26 Old 01-10-2017, 02:43 PM - Thread Starter
notnyt's Avatar
Liked: 2090
I made this thread just for the speaker, since the other thread has a mass of content. I don't see a need to replace the 4722s at this time. The LF section is great and the 2384 gets the job done well. They're the right size for what I want there. I just need someone to buy this 3677 now so it can stop taking up space lol.
notnyt is offline
post #11 of 26 Old 01-12-2017, 01:52 AM
Quoted: 466 Post(s)
Liked: 47
So do your L+R 4722's have Be compression driver upgrades? (did I read that right?). If so, how much of an upgrade over the stock 4722 do you percieve?
I was also wondering why you didn't go with a 2384 horn on something like a Be loaded 2447 or 2446 crossed below 1,000hz?
Tip24/96 is offline
post #12 of 26 Old 01-12-2017, 02:00 AM - Thread Starter
notnyt's Avatar
Liked: 2090
Yes, I'm running 2452H-SL with the diaphragms replaced with BeX4008 on the 4722s. The 2453H-SL sounds quite similar. They're both a good upgrade over the 2432h, with the Be being better. For a center channel, I didn't feel there was a need for a Be CD. For music, it's worth it. My front stage is now fully active and the center matches the L&R much better.
notnyt is offline
post #13 of 26 Old 01-12-2017, 02:15 AM - Thread Starter
notnyt's Avatar
Liked: 2090
This is a measurement of the 2452H-Be for comparison. This was in room a couple feet away, no EQ.
It's really good.
notnyt is offline
post #14 of 26 Old 01-13-2017, 02:26 AM
Quoted: 466 Post(s)
Liked: 47
Are the JBL 2452 and 2453 better than the JBL 2446 or 2447?
Tip24/96 is offline
post #15 of 26 Old 01-13-2017, 02:37 AM - Thread Starter
notnyt's Avatar
Liked: 2090
haven't heard or tested the 2446 or 2447. the 2447 would be the 1.5" throat and the one I'd try first.
maybe at some point I'll try the 2450 and 2447 just to compare
I think the phase plug in the 2452 is newer and helps the upper frequency range compared to the others. The 2450 is down 20db from 10khz to 20kHz.
notnyt is offline
post #16 of 26 Old 01-13-2017, 07:50 AM
MKtheater's Avatar
Liked: 1156
I like my 2447 better than the 2446 I had. It does drop off around 15-16khz in the 2352 horn I have. The trade off is it can extend down to 500-600hz.
Marantz 7702 Atmos
post #17 of 26 Old 01-13-2017, 12:03 PM
zeus33's Avatar
Quoted: 1373 Post(s)
Liked: 1035
My build on left....
I liked your original finish, but I must say, this came out great. OEM quality for sure. Nice work!
zeus33 is offline
post #18 of 26 Old 01-13-2017, 12:06 PM - Thread Starter
notnyt's Avatar
Liked: 2090
Original finish? I only had one on there... It was really hard to photograph in this room. I bounced a flash off my projector... this is the finish in better light..
VicTorious1 likes this.
notnyt is offline
post #19 of 26 Old 01-13-2017, 12:35 PM
zeus33's Avatar
Liked: 1035
Your first "test spray" in the other thread that had more texture. You weren't pleased with it and posted this:
It was a little too rough. I couldn't get an even coat. I knocked it down a bit and went at it some more.
things I've learned spraying duratex:
1) mix with water
2) don't use a filter in your gun
3) every little seam is going to show.
4) Clean your gun and pot quickly.
If you ever doubt the protective power of duratex, just let it sit in your pot a bit.
I'll hopefully get the final coat on tomorrow. Once dry I'll mount up the electronics then let it cure a bit. Hopefully I'll have it fully assembled middle of next week.
zeus33 is offline
post #20 of 26 Old 01-13-2017, 12:42 PM - Thread Starter
notnyt's Avatar
Liked: 2090
Oh this finish I had/have on the back? It was spraying very dry and there was a lot of 'air' in the finish. Fairly easy to recreate, just spray lots of coats without mixing as much water as I ended up using. The pictures didn't really show it very well. It would have been one of those impossible to clean finishes. I ended up blocking it down a bit and spraying more over it...
I think this pic is a little better representing how it was...
notnyt is offline
post #21 of 26 Old 01-15-2017, 02:52 PM - Thread Starter
notnyt's Avatar
Liked: 2090
cutlist attached, this doesn't have the bracing in it. Ports are PE part 260-480 https://www.parts-express.com/speake...lared--260-480
Cut to size for desired tune.
Ag4t likes this.
notnyt is offline
post #22 of 26 Old 02-04-2017, 01:07 AM - Thread Starter
notnyt's Avatar
Liked: 2090
impedance measurements of the LF section
tune came out to 34hz. I didn't bother cutting em shorter after I put em in. Didn't really care to.
notnyt is offline
post #23 of 26 Old 02-05-2017, 08:16 AM
NWCgrad's Avatar
Quoted: 1249 Post(s)
Liked: 1265
Can you post a diagram of your jig for the impedance measurements? The one in the REW help section is not clear to me (the circles with line connecting them do not seem to make sense).
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is online now
post #24 of 26 Old 02-05-2017, 01:51 PM
MKtheater's Avatar
Liked: 1156
This looks awesome BTW.
post #25 of 26 Old 03-01-2017, 08:21 AM
cdy2179's Avatar
Quoted: 750 Post(s)
Liked: 437
cdy2179 is offline
post #26 of 26 Old Today, 06:08 PM - Thread Starter
notnyt's Avatar
Liked: 2090
After spending a few hours redoing my filters after putting more treatments up, this is the response of the center channel averaged over 8 positions around the listening position. Pretty happy with that.
lukeamdman likes this.
notnyt is offline
