Titan-615 General Discussion Thread - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 666Likes
post #481 of 650 Old 02-10-2017, 11:48 AM
mtg90's Avatar
Quoted: 462 Post(s)
Liked: 885
Originally Posted by VicTorious1 View Post
Ooh. I like. Flatpack or no flatpack. Hmmm... How would you attach the waveguide?
Waveguide has screw holes for mounting, you just screw it in. It would look nicer flush mounted into that kind of baffle but it does not need to be.
mtg90 is online now
post #482 of 650 Old 02-10-2017, 11:55 AM
erwinfrombelgium's Avatar
Quoted: 438 Post(s)
Liked: 237
I am going to stick to that width but as mine are not on the floor it will be with the woofer as low as possible, the horn section directly above it and the slot at the top. I presume this is a different slot section/length vs the round ports included in the kits?
Edit: the slot is 45,7 cm x 6,35 cm = 290 cm2 while two 4" ports add up to only 162 cm2
Edit 2: the slot, the woofer and the mid/high horn section eat about 2 cuft. The biggest suggested net volume: 6 cuft. My screen height is 140 cm. Plus bracing and external panels this means for me a box of 140 x 49,5 x 42 cm (H 55" x W 19.5" x D 16.5"). I will post a design later. This is for the center speaker behind the AT screen as the L&R will be made with an angle so I need CAD to work it out.
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is offline
post #483 of 650 Old 02-10-2017, 06:00 PM
Magibeg's Avatar
Quoted: 293 Post(s)
Liked: 143
So for Canadian's would reship be an effective method to get some titans up north?
Magibeg is offline
post #484 of 650 Old 02-10-2017, 06:56 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 578
It's who I use.
My box is located in Portland, Oregon. Once they recieve my packages from Erich they email me and give me shipping options.
Magibeg likes this.
Fattykidd is offline
post #485 of 650 Old 02-10-2017, 07:21 PM
MajorCanuck's Avatar
Quoted: 14 Post(s)
Originally Posted by Fattykidd View Post
It's who I use.
Is it possible to estimate the total cost of their service beforehand or only after they receive the items?
MajorCanuck is online now
post #486 of 650 Old 02-10-2017, 08:01 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 578
You can use their "calculator" to get an estimate.. but then fedex/ups bends ya over with brokerage fees and taxes after the fact anyway. I usually just lube up and pay the bill when I get it.
post #487 of 650 Old 02-10-2017, 09:01 PM
DevonDeyholos's Avatar
Quoted: 187 Post(s)
Liked: 181
I usually ship to to a place right over the border and drive down to pick it up. When the packages value is in the hundreds, it's well worth the time and gas to just get it your self.
DevonDeyholos is offline
post #488 of 650 Old 02-10-2017, 09:05 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 578
That's all fine and dandy if ya got a passport.
I thought you moved down south...So you're gonna go pick up my titan's for me? LOL.
post #489 of 650 Old 02-11-2017, 12:28 PM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
I am very intrigued by these! I have the 4722s and love them, but man these look incredible as well. Can't wait to hear what you all think!!!
Claybe is offline
post #490 of 650 Old 02-11-2017, 12:47 PM
dlinsley's Avatar
Quoted: 185 Post(s)
Liked: 109
I'd been wanting to order a set of vertical 1099s for LCR back in the fall, but they were out of stock and so ended up buying a set of PSA MTM-210 (which do sound very good). I still don't have my room back up, though will to some extent within the next two weeks, but these are so intriguing that I've preordered three
dlinsley is offline
post #491 of 650 Old 02-11-2017, 01:49 PM
ehoeft's Avatar
Liked: 26
I'd love to hear comparisons between these two... The 4722's with the upgraded CD are on my short list.
Sent from my iPhone using Tapatalk Pro
ehoeft is offline
post #492 of 650 Old 02-11-2017, 02:21 PM
VicTorious1's Avatar
Quoted: 501 Post(s)
Liked: 515
I was considering the 4722Ns initially as well. I was worried that they wouldn't fit in my space so I opted for the 1099s. I've since sold the 1099s (which are great) in anticipation of these. I'd love to hear the Titans in a shootout with the QSC 2150 and the JBL 4722Ns. The JBLs are a two-way with a crossover frequency of 800hz. The QSC is a three-way with crossover frequencies of 500hz and 2200hz, which is more similar to the Titans, which have crossover frequencies of 350hz and 1900hz. I know people rave about the upgraded CDs in the 4722Ns. I've yet to hear the 4722Ns with the upgraded CDs.
openbaffled and hd0823 like this.
VicTorious1 is offline
post #493 of 650 Old 02-16-2017, 02:18 PM
Andrewm1's Avatar
Quoted: 18 Post(s)
What do people suggest as the recommended surrounds if using a LCR of 615LX?
Apart from using more 615LX's what about the non LX model? or the HTM12? Fusion?
Andrewm1 is offline
post #494 of 650 Old 02-16-2017, 05:29 PM
Quoted: 501 Post(s)
Liked: 515
Volts, HTM-10s or 12s, Fusions, 615s. They'd all work well.
post #495 of 650 Old 02-16-2017, 11:18 PM
Quoted: 438 Post(s)
Liked: 237
The basic 615 would be awesome (over the top!), but need a bit of distance from the listeners. At least 6 ft I suppose. Next in line: Fusion 15 > Fusion 12 .. If very close: the Volts. Though the Volts will work in all situations, also for Atmos.
Mine are the Cinema 10 Max (MTM). Though in hindsight, I might have gone for the Fusion 12. Volt 10 (-ish) for Atmos.
post #496 of 650 Old 02-28-2017, 06:28 PM
Quoted: 71 Post(s)
Liked: 55
Sad I did not get to the preorders fast enough, but I just saw these a week ago and been swamped working on finishing my theater. Any idea when the next set of pre-orders might happen? Definitely getting 3 of these built.
Aerumas is offline
post #497 of 650 Old 02-28-2017, 06:33 PM
dtsdig's Avatar
Quoted: 895 Post(s)
Liked: 1002
It says April on the site.
zillerr likes this.
dtsdig is online now
post #498 of 650 Old 02-28-2017, 06:35 PM - Thread Starter
eng-399's Avatar
Quoted: 1614 Post(s)
Liked: 2701
Maybe send Erich a email someone could of dropped out and the diysg page wasn't updated. It's worth a try.
eng-399 is offline
post #499 of 650 Old 03-01-2017, 07:43 PM
LondonBenji's Avatar
Quoted: 135 Post(s)
Liked: 47
DANG IT, MISSED OUT!!!
I would have totally been down for three!
LondonBenji is offline
post #500 of 650 Old 03-02-2017, 02:03 AM
Quoted: 438 Post(s)
Liked: 237
What's one month?
post #501 of 650 Old 03-02-2017, 07:46 AM
Quoted: 501 Post(s)
Liked: 515
Mike @eng-399 - You should have the mods change the title of this thread to "Titan 615 General Discussion Thread" or something similar.
post #502 of 650 Old 03-02-2017, 08:13 AM - Thread Starter
eng-399's Avatar
Liked: 2701
eng-399 is offline
post #503 of 650 Old 03-02-2017, 08:14 AM
Quoted: 438 Post(s)
Liked: 237
Naah! Keep it secretive!
LOL
VicTorious1 and eng-399 like this.
post #504 of 650 Old 03-04-2017, 05:40 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 578
Whoot whoot... I have Titan parts in my posession.. Baffle gets mounted tomorrow then the waveguide and enclosure come to work with me on Monday. Will toss up a couple pics once they're all polished up..
post #505 of 650 Old 03-04-2017, 05:44 PM
Michael Mitten's Avatar
Quoted: 199 Post(s)
Liked: 172
Pics or it didn't happen.
Michael Mitten is offline
post #506 of 650 Old 03-04-2017, 05:45 PM - Thread Starter
eng-399's Avatar
Liked: 2701
Sweetttttt! Congrats looking forward to seeing the cabinets.
eng-399 is offline
post #507 of 650 Old 03-04-2017, 06:28 PM
Quoted: 501 Post(s)
Liked: 515
Excited for you, bud. Can't wait to hear your impressions.
post #508 of 650 Old 03-04-2017, 08:44 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 578
What did you fellas use for screws on the mids? All I got was course thread wood screws.
Michael Mitten and eng-399 like this.
post #509 of 650 Old 03-04-2017, 08:48 PM
Quoted: 501 Post(s)
Liked: 515
I used 4mm machine screws. I don't remember the length, but I took the waveguide in with me to the local hardware store.
Fattykidd likes this.
post #510 of 650 Old 03-04-2017, 08:57 PM - Thread Starter
eng-399's Avatar
Liked: 2701
lol I did the same thing I was walking around Menards with the waveguide in my hands. I used 4mm machine screws like your saying. I think the length I bought was around .75" of an inch but it was in millimeters if I remember correctly.
eng-399 is offline
