1099 LCR + Dual Cyclops18 Build - AVS Forum | Home Theater Discussions And Reviews
 12Likes
  • 7 Post By IAccord99I
  • 3 Post By IAccord99I
  • 2 Post By IAccord99I
post #1 of 11 Old 01-28-2017, 10:23 PM - Thread Starter
IAccord99I's Avatar
Quoted: 17 Post(s)
Liked: 33
I finally stopped dreaming and pulled the trigger on some new toys over winter break. Took me a while to decide what to build that would also fit in my space. I eventually finalized on the usual... 1099s and two martysub variants (specifically cyclops18)
I decided to build the 1099 cabinets myself to save some $. I've worked with MDF before so I am familiar with the mess it will cause. But it's nothing a nice sunny day outside and a leaf blower can't handle. I did also bought the XO boards to assemble myself.
The three 1099s + two cyclops 18s will take 5 sheets of MDF with very little waste. I purchased my MDF at lowes as opposed to Home Depot. The person cutting the sheets at my Lowes was a lot more accommodating than my local home depot. They probably did 30+ cuts on the 5 sheets of MDF... no extra charge.
Cut List:
Spoiler!
about 500lbs of MDF
WAF = 0
1099s
Crossover boards.
Going to need to ration portions out to my trash can over a couple of weeks.
LTD02, baniels, OJ Bartley and 4 others like this.
IAccord99I is offline
post #2 of 11 Old 01-28-2017, 11:01 PM
asarose247's Avatar
Quoted: 823 Post(s)
Liked: 634
That should be so F'n awesome, and sky high ROI too . .
and as for "disposing" , re:Going to need to ration portions out to my trash can over a couple of weeks.
my experience in 38 years in my home,
a Milwaukee Sawzall in your friend . . .
ask me how I know . .
lets see some more pics of this set up in action
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #3 of 11 Old 01-28-2017, 11:34 PM - Thread Starter
IAccord99I's Avatar
Quoted: 17 Post(s)
Liked: 33
haha... yea I have a reciprocating saw already. But it's not so much the size.. as much as the volume. The boxes I can recycle, but all that styrofoam wont fit in there with what I normally put in my garbage bin each week. And if I really want to throw it all away within the same week, I would have to purchase extra garbage stickers from the library which would bother me because I would literally be throwing money away. It wont be too bad. Probably going to need to spread it over 2 or 3 garbage cycles. I'm hoping my speakers will be done by then.
Mainly just showing how much packaging comes with each 1099 set. The boxes were actually a lot smaller than I imagined. I don't know how Erich got all those parts for the 1099 AND all that foam inside the box. I had a hard time putting things back in the box without the styrofoam. Erich must be a tetris master.
post #4 of 11 Old 01-28-2017, 11:35 PM
LTD02's Avatar
Quoted: 2524 Post(s)
Liked: 2867
"...about 500lbs of MDF"
Listen. It's All Good.
LTD02 is online now
post #5 of 11 Old 01-29-2017, 07:23 AM
Quoted: 79 Post(s)
Have fun with your build. I am also building 1099s and volt 10's.
jwanck11 is offline
post #6 of 11 Old 01-29-2017, 09:09 AM
Claybe's Avatar
Quoted: 214 Post(s)
Liked: 81
Can't wait to hear what you think of the cyclops!!! I still have the original 2 and they impress me every time I watch a movie
Claybe is offline
post #7 of 11 Old 01-29-2017, 09:35 AM
aggoodin's Avatar
Make sure you contain that. Mine was loose in the can and my garbage man dumped about half of it onto my neighbors yard. I was out there with a hundred feet of extension cord and a wet/dry vac vacuuming the grass.
DIY Theatre room 10'x11'- Integra 30.7, Outlaw 5000, Pioneer BDP-51FD, PS4, DIY HTPC, PS4, Clark Synthesis TST209's, Sealed 15" HO Dayton/iNuke 3000dsp, 2 SVS SB-12NSD's, Fusion Tempest 12 L/R, 88 Special C, Volt 6 R, TDG NFC-83 ATMOS x2, BenQ HT2050, SilverTicket 106", Darbee.
aggoodin is offline
post #8 of 11 Old 01-29-2017, 09:46 PM - Thread Starter
IAccord99I's Avatar
Quoted: 17 Post(s)
Liked: 33
Spent the little time I had today to trim down all the pieces to its exact measurements since I had lowes add 1/8th of an inch to the dimensions just in case. Most of that is done except for the larger pieces that don't fit on my table saw. I'll have to clean those up with the circular saw later on.
These are the left overs pieces. I used a little of it to make a quick stand to help assemble the cross overs.
Crossovers are only hot glued right now. I'll double check the layout again in a few days to make sure nothing is wrong before I solder them.
post #9 of 11 Old 03-13-2017, 12:39 PM - Thread Starter
IAccord99I's Avatar
Quoted: 17 Post(s)
Liked: 33
I had a little bit of set back the past 3-4 weeks but I finished the build over the weekend. I do wish I had access to a router for the baffle but I managed with a jig saw.
My plans started from this thread:
DIYSG LCR + 2x Sub Advice
and this is what it looks like now:
http://www.avsforum.com/forum/attach...mentid=2023873
http://www.avsforum.com/forum/attach...mentid=2023881
I still need to construct a small shelf to hold the receiver/amp and to elevate the center and to clean up the wiring.
I won't have a chance to REW the setup for a while but it's already a huge difference going from an 8" sub + klipsch promedia LCRs to this.
ID:	2023873   Click image for larger version
OJ Bartley and VicTorious1 like this.
post #10 of 11 Old 03-20-2017, 03:06 AM
Altheia's Avatar
Quoted: 50 Post(s)
How wide is your room?
Altheia is offline
post #11 of 11 Old 03-20-2017, 12:05 PM - Thread Starter
IAccord99I's Avatar
Quoted: 17 Post(s)
Liked: 33
15x23.. but it is shared with a dining table. I'm only using half of the space for my setup (15x12).
