Shallow form factor subs for behind side acoustic panels - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1 of 58 Old 01-29-2017, 11:26 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Continuing the build process to outfit my new HT with primarily DIY speakers, this thread is for the build and documentation of a pair of subwoofers for the room. The room already has a pair of MartySubs that I've tweaked a bit, to fit behind the screen wall. Those go loud and deep, and give me great bass. The point of these subs are for more even sound distribution around the room.
The design is for a shallow, ported sub, that I can hide behind acoustic panels. To test my idea out, I'm using a different subwoofer, that I haven't seen in any build thread I've found yet, Dayton Audio LS10-44. I don't know how much faith I have in these, but since I'm using left over BB from other projects, it's not that big of an investment to find out.
The subs call for a 1.1 cuft box for a ported design, to get down to 30Hz. The fronts are tuned to 15 Hz, but I'll take 30 Hz for these, given the space contstraints I'm putting on them.
How big are they, here's my cutlist and box mockup. The size and shape may look familiar to some, but I'll just say that I've never seen it ported before.
Ok, now the modeling in WinISD:
Thoughts??
ID:	1928321   Click image for larger version
ID:	1928329   Click image for larger version
ID:	1928337   Click image for larger version
ID:	1928345   Click image for larger version
DougUSMC is offline
post #2 of 58 Old 01-29-2017, 11:29 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
DougUSMC is offline
post #3 of 58 Old 01-29-2017, 11:29 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
DougUSMC is offline
post #4 of 58 Old 01-29-2017, 02:51 PM
VicTorious1's Avatar
Quoted: 504 Post(s)
Liked: 522
Interesting. What type of SPL are you getting in your model? What will be powering these? Why not go up in size to the LS12-44?
VicTorious1 is offline
post #5 of 58 Old 01-30-2017, 05:11 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
You know, I've never used the SPL charts before, so I don't know if I pulled them right, but here's what I get. Can you translate these for me?
The plan was to try to figure out how to wire them into my iNuke6000DSP. So far I have my custom Martys on a channel each, but they're not using any where near what it can offer. I was thinking about putting both on Ch A, and running these two on Ch B.
You nailed it on the 10 vs. 12 tho. I went back and forth a bunch of times on that question. They both only handle 250W, and their depth isn't that different that it impacts cabinet depth. The only difference is that the 12 wants overall cabinet to be larger, for tuning down only a couple of Hz difference, and I don't really know why I'd bother?
ID:	1930065   Click image for larger version
DougUSMC is offline
post #6 of 58 Old 01-30-2017, 06:21 AM
Quoted: 504 Post(s)
Liked: 522
I'd increase the y axis on your spl chart as the result is not being fully shown. Try increasing the y axis to 120 or 125 or somewhere that shows the slope of the line. Additionally, you should compare the spl chart of the 12 as well. I would expect them to have greater output than the 10s.
post #7 of 58 Old 01-30-2017, 07:36 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Ok, I changed the y axis to get the entire curve in view. This is what it looks like for the 10"
Then I had to go get the 12" data entered into WinISD, b/c my luck always proves that none of the drivers I ever want to use are ever in there! After knocking that out, I modeled it for a bit, and was having a heck of a time trying to get it to look nice, 'til I realized that the driver is intended for a much larger cabinet than I'm trying to build. Here are the 2 drivers, in the same box. You can see that I lose most of the lower stuff, for a nominal gain.
Next, I played with the box until I got something that seemed worthwhile, for changing to the larger driver. To even pick up a modest increase, I had to more than double the size of the cabinet. This takes me well beyond the intent of the design, which I think rules out the 12" driver.
What do you think??
ID:	1930297   Click image for larger version
ID:	1930305   Click image for larger version
ID:	1930321   Click image for larger version
DougUSMC is offline
post #8 of 58 Old 01-30-2017, 08:07 AM
Quoted: 504 Post(s)
Liked: 522
Can you also post the SPL comparison of the 10 vs 12?
post #9 of 58 Old 01-30-2017, 10:14 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Here you go. The difference is noticable, but not overly so. Keep in mind that the 10" is in a 1.1 cuft box, and the 12" is in a 2.8 cuft box. It looks like the peak is < 5db difference @ the tuned freq.
DougUSMC is offline
post #10 of 58 Old 01-30-2017, 03:31 PM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Ok, so maybe I took silence as consent...
Unfortunately, I started before ordering the woofer, and I'm out of DuraTex. Ordering those today, might have these up and running in time for the Superbowl...
DougUSMC is offline
post #11 of 58 Old 01-30-2017, 10:31 PM
bscool's Avatar
Quoted: 753 Post(s)
Liked: 590
5db would take double the drivers and double power almost to match. So 2 12" = 4 10" plus doubling the power.
bscool is online now
post #12 of 58 Old 01-31-2017, 04:25 AM
Quoted: 504 Post(s)
Liked: 522
If you don't have the space to fit the larger boxes, the two 10s should be fine. Do you have space for the 2.8 cubic foot cab? If you're simply using these to even the response across listening positions, you should be fine. You're still planning on a custom marty-style sub for the rear, right?
post #13 of 58 Old 01-31-2017, 04:32 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
I understand both of these points, but I really don't have the space for the 2.8 cuft cabinets. I mean, technically I could fit them, but then they'd be the only speakers not hidden by the acoustic panels. Given all the effort I went through to hide all the others, I'm not ready to make that sacrifice.
I'm really getting into tuning the performance of the room now, moving on to acoustic treatments and EQ. If these 2 subs don't do the trick, then I'm most likely going to add that Marty in the rear. I'll have space enough for another 18" there, and if that doesn't do the trick then nothing will!
Then again, if this shallow design works well, it'd be pretty easy to just make another pair of these, and have 2 of them on each side of the room.
DougUSMC is offline
post #14 of 58 Old 01-31-2017, 05:50 AM
Rowan611's Avatar
Quoted: 392 Post(s)
Liked: 463
Cool design. Be interested to see how these turn out and how they sound.
HT: Marantz 7702mkII | Crown Amps | 1299 L/C/R | Volt 8s | THTs | 1200Ds | Panamax 5300PM | LG OLED 65B6P | Oppo UHD-203 | PS4 |
Family: Pioneer SP-SB23W | Pioneer Kuro Elite 111 | X1
Rowan611 is offline
post #15 of 58 Old 01-31-2017, 07:14 AM
OJ Bartley's Avatar
Quoted: 286 Post(s)
Liked: 360
I envy your ability to just go ahead and whip up a pair of impulse subwoofer cabinets in what... a few hours?
OJ Bartley is offline
post #16 of 58 Old 01-31-2017, 08:11 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Lol, well...
They're pretty small boxes, and made from left over wood. Making the cut sheet took an hour, then it was really just a matter of a few runs across the table saw, some time at the chop saw, and some glue, clamps, and brads. Since the glue was still wet from assembling the boxes and the ports, the ports aren't installed in the boxes yet, they're sitting there. I need to caulk all the box seams and the ports, then I can install them, and caulk that too.
Heck, I haven't even routed out the speaker hole on the front baffles yet.
Thanks for the complement tho!
OJ Bartley likes this.
DougUSMC is offline
post #17 of 58 Old 01-31-2017, 07:54 PM
Chris Young's Avatar
Quoted: 39 Post(s)
Liked: 34
Subbed and nice job so far. I've been thinking for awhile about putting subs in my side surround columns. I can fit up to 12" subs there and was also leaning toward MBM instead of sub bass content. Your Shallow subs you are using I had wondered if they would bottom out early which is why I had not looked in that direction. I would be interested to hear your thoughts on the outcome of these drivers once you have them dialed in to your system.
Have fun,
Chris
"The Boy has no patience" Yoda
"He will learn patience. Was I any different when you taught me?" Obi-Wan
My attempt living room build The Story Time Theater
14 M&K S-100B, 2 Servodrive Contrabass. 2 SVS PB12/2 Plus. 6 V.B.S.S., 2 Sunfire TrueSub's MkII Near field Fun all in one room.
Chris Young is offline
post #18 of 58 Old 01-31-2017, 10:22 PM
Mark Seaton's Avatar
Quoted: 695 Post(s)
Liked: 1869
Did you get around to testing the drivers at all? I was discouraged to find how much ticking noise these 10" & 12" drivers make in operation. Most might not hear it with music, but if things are playing without a lot of noise to mask it, these were rather noisy. They are a nice form factor and all the parts/mechanics look very promising. Maybe current batches don't have reduced this issue.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is offline
post #19 of 58 Old 02-01-2017, 06:26 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Have fun,
Thanks Chris, I'll be sure to post my opinion when done. I'm not the expert by any stretch though, so I hope my own input isn't too useless.
Wow, speaking of experts!!
Hey Mark, thanks for the info. This project got up and running pretty quickly, using an idea and materials that have been lying around, so I haven't even had the chance to order the drivers yet! ( 2 y/o and 3 m/o in the house) I was hoping to get them up and running before the SuperBowl, but now I'm hoping to have the 15 minutes to get them ordered by it!
Just so I know what to look for: When you say "ticking" do you mean a literal sound like ticking that is audible when the components are moving during normal operation?
DougUSMC is offline
post #20 of 58 Old 02-01-2017, 09:48 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Ok, wiring help please.
I'm stretching the extent of my own skills for amplifier / sub wiring here. After a bunch of research I think what I'm trying to do is right, but I'd appreciate some help to keep me honest.
I currently have 2 Custom Marty subwoofers with 18" Dayton Ultimax DVC powered by an iNuke6000DSP. The iNuke is getting its signal from the AVR as 2 line outputs, one into channel A, one into Channel B. Each of the subs is wired in series, on its own output channel of the subwoofer (A & B out).
What I'm trying to do is re-wire it so that it supports these 2 new shallow subs as well. My plan is to leave everything before the iNuke the same, but run the 2x 18's off Channel A, and these 2x10's off Channel B. If I've done it right, keeping the 2x 18s wired in series, limited to 2000w makes that 4 Ohm x2 @ 1000w per driver. The 2x 10s wired in series, limited to 500w makes that 8 Ohm x2 @ 250w per driver.
The iNuke is rated at 3100w per channel @ 4 Ohm, and 1600w per channel @ 8 Ohm, so this should work. Diagram explaining below:
Did I get this right?
DougUSMC is offline
post #21 of 58 Old 02-01-2017, 10:05 AM
notnyt's Avatar
Quoted: 2791 Post(s)
Liked: 2576
keep in mind, the inuke 6k into 4 ohms at 40hz will output about 1800w burst 1700w sustained with only one channel running. with two channels running it'll only output 1500w burst 1200w sustained per channel. Into 8 ohms you'll see about 1kw.
notnyt is offline
post #22 of 58 Old 02-01-2017, 10:16 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Wait, huh? Are you saying they're stretching the truth in their documentation, or is it 3100w total, not 3100 WPC @ 4 Ohms?
Either way, it sounds like you're saying it'll work the way I have it wired, but I might find the bigger drivers are hungry, and I might need to dedicate the 6000 to the 18s, and get another one for these new subs?
DougUSMC is offline
post #23 of 58 Old 02-01-2017, 10:20 AM
notnyt's Avatar
Liked: 2576
yeah they overrate by a good bit.
notnyt is offline
post #24 of 58 Old 02-01-2017, 10:24 AM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Ok, good info, thanks for the heads up. I'd probably have driven myself crazy, the first time I ran things and it was noticeably quieter.
DougUSMC is offline
post #25 of 58 Old 02-01-2017, 12:03 PM
bscool's Avatar
Quoted: 753 Post(s)
Liked: 590
You have the 2 channel dsp6000, not the 4 channel? If so you could use it to try out the 10s and 18s since it sounds like it is not a 100% sure thing if these 10" will do what you want. That way you wouldn't have to buy another amp before knowing if they will do what you want them to or not.
I have a Dsp6000 and I have ran 2 UM18 off of one channel when trying different configurations. Like using the other channel for another sub or a Crowson. I have also ran 2 UM18 off a DSP3000 bridge so it works on more than just 1 Inuke I have. The amp should be seeing higher than 2 ohm. I am thinking more around 2.25 - 2.5+ if you look at the impedance in WINISD when you have them loaded in an enclosure.
But your wiring above will not work if you do want to try it. You want the UM18 on channel A and the 10s on channel B. So you can adjust each separate as for gains and delays.
Use Biamp mode in the Inuke software. Do not click the Xover tab under the Filter/Crossover section, that is for having a high channel and a low channel which you do not want.
post #26 of 58 Old 02-01-2017, 01:11 PM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Yup, I have the 2 channel now, and that's the plan.
I haven't measured the amp, I was just giving 2 Ohm as Dayton reports it on PE. Does it matter for my math somehow that I don't get?
Sorry, I should've drawn the picture better, b/c it's supposed to be showing both 18s sharing a connector, plugged into A. The 10s also share a second connector, and it's plugged into B.
Since I have two sub in, why Biamp and not Dual mode? I was going to run Dual so I could set DSP and XO for each pair independently? I currently run both XOs (high and low) and PEQ on my 18s.
DougUSMC is offline
post #27 of 58 Old 02-01-2017, 01:43 PM
bscool's Avatar
Quoted: 753 Post(s)
Liked: 590
I missed the part about your AVR has 2 sub outs, does it let you adjust distance on each or is it just an internal Y? If it is just a why I use biamp because you only need to run 1 XLR to channel A and it feeds both channel A and B inside the amp. But you could run another XLR and use dual mono if you want. No big deal.
As for both 18s sharing a connector, I get that but I just wanna be clear you would only connect the 18s the 1+ and 1-. The 10s would go on the 2+ and 2-. Is that what you meant also?
I read over stuff too fast and missed the end part of your post, both dual mode and biamp will let you adjust delays and DSP each channel separately, only stereo doesn't.
post #28 of 58 Old 02-01-2017, 01:55 PM
bscool's Avatar
Quoted: 753 Post(s)
Liked: 590
On the NL4FC that gets plugged into the back of the amp. You want the 18's connected to 1+ and 1- only. Then you can use the same connector NL4FC or another separate one, I like a separate one plugged into the B channel for(more confusion, if you use the separate channel B port for the 10s, you would use 1+ and 1-). Then 10s get connected to 2+ and 2- only if you just use 1 NL4FC to connect the 18s and the 10s on 1 NL4FC.
Ill try and find a picture, because it is hard to tell from the pic you posted what you mean for sure or I am just slow
post #29 of 58 Old 02-01-2017, 04:05 PM - Thread Starter
DougUSMC's Avatar
Quoted: 352 Post(s)
Liked: 266
Hmmm, don't forget that the 2 18s are in 2 separate cabinets. They're not wired in the same cabinets, so I was using the NL4FC so I could connect 2 different copper runs to the same iNuke Channel A output.
DougUSMC is offline
post #30 of 58 Old 02-01-2017, 04:47 PM
bscool's Avatar
Quoted: 753 Post(s)
Liked: 590
Yeah I get that but if you connect the 2 UM18s to a NL4FC into the back of the Inuke in the channel A speak on port and you connect 1 sub to A 1+ and 1- and the other sub to A 2+ and 2- it will be mixing the sub that is connected to A 2+ and 2- with the subs on channel B 1+ and 1-.
You would need 3 amp channels to do what I think you are trying to do unless I am misunderstanding you.
