speakers for my shop: what should I build - AVS Forum | Home Theater Discussions And Reviews
Old 01-29-2017, 05:05 PM - Thread Starter
genocide74's Avatar
Liked: 5
im sure this topic has been discussed many times before, but one more time couldn't hurt. I'm looking to build four speakers to ceiling mount in my shop. Mostly Music duty with the occasional football, hockey game on TV. The space is 24x36 with 10' ceilings. I guess I'm looking for a speaker to provide more than just "noise". My first instinct was to build four volt6's, but I could do 8's or 10's, or something else entirely. I'd like to keep the budget around a wife friendly $500 (kit price, not all-in price), just a ballpark. I plan on running these off an AVR to keep things simple. Any feedback, experience, etc is appreciated
genocide74 is offline
Old 01-29-2017, 08:27 PM
mitchyz250f's Avatar
Liked: 0
I think that is a good start. If you decide to get more serious that those can become your surround speakers. You will always be able to use them.
mitchyz250f is offline
Old 01-30-2017, 10:20 AM
mhutchins's Avatar
Quoted: 82 Post(s)
Liked: 95
I would buy 4 of the Monoprice 15" Passive PA speakers. @imagic thought highly of them and you can't build anything for that price with better sound.
I'm in the middle of mounting two in my garage this week.
Mike
mhutchins is offline
Old 01-30-2017, 08:08 PM - Thread Starter
genocide74's Avatar
Liked: 5
While there may be exceptional value/sound quality ratio with the monoprice PA speakers, buying them wouldn't scratch my itch to build something. Plus, I'm planning to ceiling mount and those look to be a little on the big side. Thanks anyhow for the recommendation
Old 01-30-2017, 09:45 PM
Vince_B's Avatar
Quoted: 38 Post(s)
Liked: 30
Build two and play them loud. F15?
Sent from my SM-N910V using Tapatalk
Vince_B is offline
Old 01-31-2017, 12:27 AM
Quoted: 642 Post(s)
Liked: 752
If it was me,
I'd use the Volt 10 which would allow getting decent bass response out of them and gain efficiency. I think you can get them down to 50 or 45Hz reasonably flat with the 10s which should do well for typical music. The kit costs between the 6, 8 and 10 is minimal so the extra 20 to 25 bucks each across the range is not unreasonable.
Good luck with your project and be careful, the rabbit hole is deep.
18Hurts is offline
