DIYSG Titan-615 Build - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 593Likes
post #151 of 391 Old 02-13-2017, 02:47 PM
lz7j's Avatar
Quoted: 688 Post(s)
Liked: 669
@eng-399 can you please snap a pic of the backside of the new 15" woofer? Thanks!
lz7j is offline
post #152 of 391 Old 02-13-2017, 03:51 PM
OJ Bartley's Avatar
Quoted: 204 Post(s)
Liked: 281
Wow, try to keep it in good taste, buddy.
LOL
Sent from my LG-H812 using Tapatalk
lz7j, NWCgrad, gixerking and 1 others like this.
OJ Bartley is online now
post #153 of 391 Old 02-13-2017, 04:12 PM - Thread Starter
eng-399's Avatar
Quoted: 1494 Post(s)
Liked: 2344
eng-399 is online now
post #154 of 391 Old 02-13-2017, 06:06 PM
Quoted: 101 Post(s)
Liked: 34
Where is the link to the live stream?
cellarnoise is offline
post #155 of 391 Old 02-13-2017, 06:39 PM
gixerking's Avatar
Quoted: 183 Post(s)
Liked: 195
You know, I just looked and yes, I do have some dollar bills on me so hurry up and get them on that theater stage!
gixerking is offline
post #156 of 391 Old 02-13-2017, 06:46 PM
Quoted: 841 Post(s)
Liked: 977
Woofer got back!
Thanks Sir Thumps-a-lot, looks great--it must work out.
eng-399 likes this.
18Hurts is offline
post #157 of 391 Old 02-13-2017, 07:05 PM
Erich H's Avatar
Quoted: 1435 Post(s)
Liked: 1833
It's the larger neo magnet that they use on all the Kappalites.
A year or so ago I started a thread and showed some custom parts I was working on with Eminence. Two things they made for me were copper lined neo motors that are used in the Deltalites and Kappalites. That might still be a go at some point after more testing, but these don't have that copper in it. My goal with the copper sleeves was mostly aimed at making the Deltalites even better than they already are. I should jump start that project again to see how it goes.
_______________________
The SEOS Waveguide Project
Erich H is offline
post #158 of 391 Old 02-13-2017, 10:10 PM - Thread Starter
eng-399's Avatar
Liked: 2344
post #159 of 391 Old 02-14-2017, 06:20 AM
OJ Bartley's Avatar
Quoted: 204 Post(s)
Liked: 281
@eng-399 , I have a new request for you. Finish the enclosures however you'd like, but then get the waveguides hydrographically dipped! You can get basically any pattern you want, and it flawlessly covers curves, corners, etc. I don't think I've seen anyone dip speakers yet, but I bet it would be an amazing look for the big WG.
ID:	1966273   Click image for larger version
ID:	1966281   Click image for larger version
post #160 of 391 Old 02-14-2017, 09:31 AM - Thread Starter
eng-399's Avatar
Liked: 2344
The state of the boxes address
As of a few minutes ago all the bracing is complete in every box. I have two of the baffles on and the third will go on tonight or tomorrow because I ran out of clamps. After that the second baffle will be glued down and then we're of to the waveguide part of the build. I decided that I'm basically going to do what Erich had lauded out for it for it until later this year when I rebuild all three boxes and make them look like the latest picture Matt drew up. I have one waveguide part that Erich sent me and I'll copy that and glue it together so it shouldn't take to long to do. Here's some pictures of today's work so far.
Every box is identical.
More to come
post #161 of 391 Old 02-14-2017, 01:44 PM
VicTorious1's Avatar
Quoted: 487 Post(s)
Liked: 491
What are you lining your cabs with? Ultratouch? Also, what are the dimensions of your cabs? What's the length you're using for your precision ports?
VicTorious1 is online now
post #162 of 391 Old 02-14-2017, 01:55 PM - Thread Starter
eng-399's Avatar
Liked: 2344
The cabinets are 20 inches wide 29.5 high and 16 inches in depth. It's just over 4 cubic ft. Per cabinet. I'm lining my cabs with ultra touch insulation and for the ports I'm using the front and back end of the flared ports with no extension piece just the coupling to hold together the front and back of the ports as directed by Matt. A flat pack would of been much easier and faster maybe next time.
post #163 of 391 Old 02-14-2017, 02:20 PM
brian6751's Avatar
Quoted: 1022 Post(s)
Liked: 960
Mike, do you plan on using a gasket or anything between the box surface and the port?
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
post #164 of 391 Old 02-14-2017, 02:26 PM - Thread Starter
eng-399's Avatar
Liked: 2344
Yep that was my plan speaker gasket attached to the back of the port. The 15" speaker/woofer has gasket tape on the back of it already so I'm set there. I'll have to see about the 6 inch mid. It still hasn't hit me yet that these are replacing my behringer's up front I'm so excited. I still have two of my slot ported boxes in there I need to get out. There soooo heavy.
brian6751 and corradizo like this.
post #165 of 391 Old 02-16-2017, 01:00 AM
Chris Young's Avatar
Quoted: 37 Post(s)
Liked: 29
Subbed
Chris
"The Boy has no patience" Yoda
"He will learn patience. Was I any different when you taught me?" Obi-Wan
Work is what we do to pay for our HT.
My attempt living room build The Story Time Theater
Chris Young is offline
post #166 of 391 Old 02-16-2017, 09:07 AM
RCC Tim's Avatar
Quoted: 35 Post(s)
Liked: 62
Originally Posted by eng-399 View Post
XO boards for the Titan-615. Thanks @mtg90 who built them for me!
I have one board to cut and then to figure out the bracing for them. Assembly should start soon.
Hi Mike, or @mtg90 ,
I was wondering if you could provide the dimensions of the assembled XO? I just pre-ordered my kits, and I was thinking about having the XO mounted in a clear box on top of the cab, behind the horns. I'm assuming there would be room there, on the narrow flat packs, yes?
Tim
RobertChicken and Altzheimer like this.
RCC Tim is online now
post #167 of 391 Old 02-16-2017, 10:07 AM
Erich H's Avatar
Liked: 1833
There's a flat section behind the brace on the horn bracket that's big enough to put the assembled crossover. MTG90 made sure the board would fit there.
Erich H is offline
post #168 of 391 Old 02-16-2017, 10:52 AM - Thread Starter
eng-399's Avatar
Liked: 2344
Tim
Hi Tim the board is 9" by 6"
post #169 of 391 Old 02-16-2017, 10:56 AM - Thread Starter
eng-399's Avatar
Liked: 2344
Progress...
All three boxes have the second baffles glued together and I'm now sanding down the cabinets. Once done I'll cut the brackets for the waveguide and glue them together. Making them seamless is my next step after what I mentioned above.
I'll post pictures of all three boxes together once there all sanded down.
fun video breaking garage speakers
OJ Bartley likes this.
post #170 of 391 Old 02-16-2017, 11:53 AM
RCC Tim's Avatar
Quoted: 35 Post(s)
Liked: 62
Awesome, thanks. How high does that large cap stick up from the PCB? Looking great BYW. Can't wait to get mine, although I cheated and went with the flat packs
post #171 of 391 Old 02-16-2017, 12:21 PM
Quoted: 40 Post(s)
Liked: 35
Earlier he posted a pic, the cap has a similar diameter to a Coca-Cola can.
Edit: It was Erich himself who posted it here.
mushroommunk is online now
post #172 of 391 Old 02-16-2017, 01:26 PM
RCC Tim's Avatar
Quoted: 35 Post(s)
Liked: 62
Ok, thanks Erich. Good to know.
post #173 of 391 Old 02-16-2017, 01:43 PM
OJ Bartley's Avatar
Quoted: 204 Post(s)
Liked: 281
https://youtu.be/qQYCP9Teyyg
Oh, the humanity!
eng-399 likes this.
post #174 of 391 Old 02-16-2017, 02:04 PM
Quoted: 703 Post(s)
Liked: 368
Pardon my lack of knowledge, is that speaker supposed to go in wall, since mid and high have open back?
Revel Ultima Salon 2, Revel M106, Revel C208, Yamaha P5000S, Denon X5200, Panasonic 65" VT50, SVS PC13-Ultra
Kef LS50, Parasound New Classic, Focusrite 2i2
donktard is offline
post #175 of 391 Old 02-16-2017, 02:22 PM - Thread Starter
eng-399's Avatar
Liked: 2344
2-3/8" high
Btw the wife wanted to see a movie so we saw John wick 2 this one was the bomb. I think it's better than the first one lots of bass and midbass throughout the movie.
PTAaron and Brazle like this.
post #176 of 391 Old 02-16-2017, 04:05 PM
RCC Tim's Avatar
Quoted: 35 Post(s)
Liked: 62
2-3/8" high
Thanks again Mike.
post #177 of 391 Old 02-16-2017, 04:17 PM - Thread Starter
eng-399's Avatar
Liked: 2344
The mid is enclosed and screwed in with 4-4 mm screws.
The cd gets screwed in the waveguide.
Brazle and Purenv like this.
post #178 of 391 Old 02-16-2017, 05:12 PM
Quoted: 68 Post(s)
Liked: 43
The mid is a sealed back. The CD (as all are) is also sealed.
They will work fine in wall or sitting in the middle of the room.
dorri732 is offline
post #179 of 391 Old 02-17-2017, 08:42 AM - Thread Starter
eng-399's Avatar
Liked: 2344
All boxes are sanded down
After that I finished the waveguide guide mounting deal.
Saw dust everywhere
Now I'm going to double check the height of the waveguide to the wood then glue those together and start hiding the seams I. The box.
post #180 of 391 Old 02-17-2017, 11:05 AM
chadsmith013's Avatar
Quoted: 950 Post(s)
Liked: 874
looks awesome..you always do great work..
eng-399 likes this.
Receiver : Denon x2300
Front Stage : 3 DIYSG Fusion 10's
Surround Speakers :2 DIYSG Volt 6's
Subwoofers : Dual Dayton HO 18's in sealed cabs w/Inuke 3000 DSP
chadsmith013 is online now
