Buying used DIY 2 or 3 way speakers ... how to demo - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Jk7.2
post #1 of 6 Old 02-05-2017, 09:12 AM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 789
I'm helping a work co-worker buy used DIY speakers, these happen to be 1099's.
We went over to the sellers home last night, I bought a demo blu-ray, scubasteve disc, and we listened to pearl harbor clip.
Then some music.
I did advise my friend to buy them, he should be there today (Sunday Feb-6th) picking them up.
Q: What are prudent things to do/consider when buying DIY 2 or 3 way speakers?
  • Listen to demo clips you are used to? (we did)
  • Listen to music? (we did)
  • Listen nearfield then 6 feet away to each speaker, go thru say a sine sweep 100hz to 5khz? (we did not), to make sure every component working?
  • Other?
TIA
mtbdudex is offline
post #2 of 6 Old 02-15-2017, 04:57 AM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 789
I guess people build DIY 2 or 3 way speakers but generally don't sell them, nah I'm just sarcastic here.
So, if you are the owner of DIY 2 or 3 way speakers what are your sales methods/techniques?
Do you share the build process you did?
Do you share the testing results/graphs/etc you did? (if you did)
or do you just let them stand/speak/sound for themselves, and buyer beware?
Taken "as is", no 5 day in home trial, etc.
A search revealed this.
http://www.ebay.co.uk/gds/The-Dos-an...8357949/g.html
mtbdudex is offline
post #3 of 6 Old 02-15-2017, 05:42 AM
dtsdig's Avatar
Quoted: 912 Post(s)
Liked: 1037
dtsdig is offline
post #4 of 6 Old 02-15-2017, 06:08 AM
tuxedocivic's Avatar
Quoted: 2202 Post(s)
Liked: 2077
I would probably insist on having the seller remove a woofer to see the stuffing is placed well and actually there. Also look at the XO to make sure its not cobbled together with electrical tape. Even if you're not sure how the XO should be wired, youll know if its a hack job.
Make sure the enclosure is put together straight and sturdy. The care the person put into the enclosure shows the care he put into making it function right (bracing, etc.).
My youtube channel: Impulse Audio
tuxedocivic is online now
post #5 of 6 Old 02-16-2017, 09:55 AM - Thread Starter
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 789
Originally Posted by dtsdig View Post
Is your friend satisfied with their purchase?
His HT portion of the basement is under construction right now, he's hired a contractor to complete everything.
He negotiated a "Win-win" price for them, all based on me going with him, listening to them, and they were from a fellow AVS person.
I'll post his post HT review results in 2 months.
I also advised him (4) Volt-8 for the ceilings and (2) Fusion-8 for the rears, due to open layout he cannot install sides.
He's also going dual 18" ported subs, false front AT screen wall.
It's good to know that asking someone to remove a driver and see the inside guts is within bounds, kinda like when you buy a car you lift up the hood and poke around as much as possible.
mtbdudex is offline
post #6 of 6 Old 02-16-2017, 10:13 AM
Jk7.2's Avatar
Quoted: 433 Post(s)
Liked: 632
I just sold my DIY two ways. I posted pics of the build, bracing, stuffing, and of the crossovers. Unfortunately the buyer is out of state, so a demo wasn't possible. My sales technique always involves non pressure demo of material the buyer is used to hearing.
Brazle likes this.
Jk7.2 is online now
