Behringer iNuke wiring help - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By LTD02
post #1 of 6 Old Today, 04:30 AM - Thread Starter
Javs's Avatar
Quoted: 1922 Post(s)
Liked: 1558
Just a quick question, I did a bit of a search and couldn't find a quick answer.
I am about to push the button right now on an order for parts etc to make 4x VBSS style subs using the Dayton PA460 drivers. Each sub will be located almost in the four corners of my room, two up in the front soundstage, and two in the rear,
I need to order the Speakon connectors and such at the same time. I will be buying the iNuke 3000DSP. I am not sure how the wiring is going to work for connecting the 4 subs to the two outputs on the iNuke, can anyone just quickly school me on how this is going to work using four subs wired for 4ohm?
How do I wire four subs using Speakon to the two outputs on the inukes? Its such a simple thing I am sure there is a super clear way you guys are doing it. Do I daisy chain two subs using two speakon terminals on a single sub and just wire them internally so the output speakon cable contains both subs? Or do I run four separate speakon cables right to the amp and then do some trickery there?
Thanks guys, I need a bit of a quick answer if you don't mind so I can catch today's shipping.
Right now I have:
4x Speakon Chassis Mounts,
8x Speakon Cable end connectors in the cart. NL4.
My Marantz has XLR so I will just use those two outputs in XLR going to the iNuke so no issues there... Just want to make sure I am not missing some kind of Speakon Splitter cable if there is such a thing?
JVC X7000 (RS500) | OZTS Majestic 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | Rotel RMB-1555B | DIY Javelin Audio TPL-150 L/C/R | DIY Faital MTM TPL-150 Surrounds | DIY Dolby Atmos MKII Modules | Krix Seismix 3 MK3 Subwoofer
Shootout - JVC RS500 (X7000) & Sony 320ES | My Panasonic UB900 HDR and SDR Settings | My MadVR Settings
Javs is offline
post #2 of 6 Old Today, 05:26 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2573
How to Make a Y-Splitter Speakon
Listen. It's All Good.
LTD02 is offline
post #3 of 6 Old Today, 05:36 AM - Thread Starter
Javs's Avatar
Liked: 1558
Bingo Thanks so much!
Javs is offline
post #4 of 6 Old Today, 06:02 AM
rhodesj's Avatar
Quoted: 852 Post(s)
Liked: 470
Depending on the gauge of wire being used, you can just take two wires, twist them together slightly, and insert directly into the back of the speakon. The screw connector speakons are supposed to take 12 gauge wire, if I recall, so two 14 gauge wires might well fit.
rhodesj is online now
post #5 of 6 Old Today, 06:16 AM
LTD02's Avatar
Liked: 2573
yeah, lots of ways to go about it. didn't mean to suggest that was the only solution. :-)
rhodesj and chadsmith013 like this.
LTD02 is offline
post #6 of 6 Old Today, 11:16 AM
Cichlid109's Avatar
Quoted: 77 Post(s)
Liked: 38
Here is another option, I use this sometimes:
http://www.the12volt.com/caraudio/wo...igurations.asp
All you have to do is select the qty. of the speakers and the impedance click on wiring options and you will see how it needs to be wired.
Yamaha RX-A2010 1pr. Volt 6LX's and 1pr PolkAudio RT-35 as surrounds, 1pr. Volt 6LX's as Front Height ( these powered by AVR )
BIC DV84 L and R powered by Samson SX2400 BIC DV84 Center powered by Samson SX2400
1 Dual Opposed cabinet with 2 HST18D1's powered by A14K
2 Sealed Marty Cubes with SI DS4 stacked powered by nu-6000
2 Infinity 1262's powered by EPX2800, 2 Infinty 1262's powered by nu3000
Cichlid109 is online now
