Too much bass for the space? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 92Likes
post #91 of 113 Old 02-17-2017, 11:27 AM
asarose247's Avatar
Quoted: 708 Post(s)
Liked: 469
from about 2 years ago . .
it's only 1 speaker, right?
Name:	SPLEEN  frontal.jpg
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #92 of 113 Old 02-17-2017, 11:40 AM
uniquepattern's Avatar
Quoted: 667 Post(s)
Liked: 613
Yes.... It is....
...and don't you DARE tell my wife otherwise!
or else you may ruin the plans for my next upgrade....
uniquepattern is offline
post #93 of 113 Old 02-17-2017, 12:03 PM - Thread Starter
Quoted: 805 Post(s)
Liked: 247
I bet someone does that on avs forum by year end.....with 24s
Purenv likes this.
1201 is online now
post #94 of 113 Old 02-17-2017, 12:46 PM
Quoted: 667 Post(s)
Liked: 613
Oh geeze.... not with 24's...
I cant believe Im gonna say this, but that would be overkill...
post #95 of 113 Old 02-17-2017, 03:18 PM
Quoted: 666 Post(s)
Liked: 780
Originally Posted by 1201 View Post
those tennis balls were picked out for their special characteristics to tune the elasticity of the midrange.
the midrange was too bouncy without them and regular tennis balls imparted too much tension. I had to order these from Europe
Of course!
Thank you teacher, I have yet to grasp the brilliant pebble from your hand have so much to learn. The tennis balls of a certain type would flex differently at different frequencies to dampen various frequency spikes in the midrange--how did I miss that? The European tennis balls are packaged with a different air type VS conventional tennis balls so impart a more classical tuning in the critical midrange band. I think the European air used in the tennis balls helps the unladen speed of a European swallow.
uniquepattern likes this.
18Hurts is offline
post #96 of 113 Old 02-17-2017, 03:37 PM
asarose247's Avatar
Quoted: 708 Post(s)
Liked: 469
for some there is a certain combination of words that will destroy you etc.
somewhere out there, on the distant edges of reason, is a "joke" combining the words: airspeed, velocity and swallow,
3 words , reminds me of Hoffman's Iron Law for Subs
which 2 words do I chose . . .?
or can we use all 3?
What's a grasshopper to do . . .?
18Hurts and uniquepattern like this.
post #97 of 113 Old 02-17-2017, 03:57 PM
Quoted: 132 Post(s)
Liked: 41
Those FCR speakers look suspiciously like DIYSG Fusion-12's
liffie420 is offline
post #98 of 113 Old 02-17-2017, 10:10 PM - Thread Starter
Quoted: 805 Post(s)
Liked: 247
Didnt diysg basically clone those speakers when elemental designs went under? it even uses the same woofer.
Ive moved away from horns so I no longer use them.
64 base level speakers $10k
28 height speakers $10k,
14 subwoofers $10k
90% of the movie sound coming from the center channel - priceless.
1201 is online now
post #99 of 113 Old 02-17-2017, 10:11 PM - Thread Starter
Quoted: 805 Post(s)
Liked: 247
maybe overkill, but barely
14 subwoofers $10k
1201 is online now
post #100 of 113 Old 02-18-2017, 06:42 AM
Fastskiguy's Avatar
Liked: 1
Too much? You must be joking!
Fastskiguy is offline
post #101 of 113 Old 02-19-2017, 05:07 PM
skris88's Avatar
No. Use all 6!
To get the best spread them out to make use of the comb effect, and use Audyssey bass management. And, with Audyssey turn Off their Dynamic EQ and Dynamic Loudness (at least initially). They do GOOD things, but you need to understand what each does, and your sources must be SMPTE calibrated - and only digitally connected DVDs and BlueRay movies are (although you can do the same to your audio files using ReplayGain).
skris88 is offline
post #102 of 113 Old 02-19-2017, 06:00 PM
Decadent_Spectre's Avatar
Quoted: 330 Post(s)
Liked: 146
coughtheearcough
NCGoldwinger likes this.
Decadent_Spectre is offline
post #103 of 113 Old 02-20-2017, 07:11 AM - Thread Starter
Quoted: 805 Post(s)
Liked: 247
so I got everything going and dialed in. sound output is way more than I could ever use. my subs are at -8 on the receiver
BUT ........ I cant get over the non symmetry of one dual 18 box one one side and the other side only having a small 12" box .
Obvious fix would be to add a second box of dual 18s.
Then Id be getting close to half of uniquepattern's output
hmmmmmmm
1201 is online now
post #104 of 113 Old 02-20-2017, 07:49 AM
Quoted: 132 Post(s)
Liked: 41
so I got everything going and dialed in. sound output is way less than I could ever use. my subs are at -8 on the receiver
hmmmmmmm
Wellllll you know rule number 1 in the AVS Forums:
When in doubt more speakers, especially woofers, is ALWAYS the answer.
1201 likes this.
post #105 of 113 Old 02-20-2017, 08:10 AM - Thread Starter
Quoted: 805 Post(s)
Liked: 247
that should be my new sig.
MOAR BASS IS ALLWAYS BETTER!!!!!1111
funny enough is with 4 18s and 4 12s, on avs forum that would still be baby steps. as in minor leagues, backwoods stuff
14 subwoofers $10k
1201 is online now
post #106 of 113 Old 02-20-2017, 08:31 AM
Quoted: 132 Post(s)
Liked: 41
You are so very RIGHT lol. I came here previously years ago when I bought my Vizio 4k tv. I have branched out into the other areas specifically when i decided to do my 5.2 system. I learned VERY quickly that I am not even in the same universe as probably %60+ of the members here. I was never going to be playing with the big dogs I knew that but I had no idea how low on the totem pole i was until I started seeing peoples recommendations. And the fact that it seems every other person here has a dedicated home theater in their house lol. Or hell even the amount of speakers will put in a room the size of my living room, it just boggled my mind. Granted if I could afford it I would be doing the same thing I am sure. Hell I have even gone from just buying 1 5.1 speaker set and new AVR, to already looking at spending $600 or $800 to replace my front L&R when I spent like $325 for ALL of the speakers LMAO I'm falling down the hole
post #107 of 113 Old 02-21-2017, 06:53 AM - Thread Starter
Quoted: 805 Post(s)
Liked: 247
@liffie420
in the real world, systems go to 10.
in the AVS world, systems START at 11.
liffie420 and uniquepattern like this.
14 subwoofers $10k
1201 is online now
post #108 of 113 Old 02-21-2017, 07:47 AM
Quoted: 667 Post(s)
Liked: 613
For most people a single 12" sub from best buy is epic...
...on AVS 8x 18's is a starter setup...
post #109 of 113 Old 02-21-2017, 07:51 PM - Thread Starter
Quoted: 805 Post(s)
Liked: 247
spent hours moving all the subs around this weekend. nothing helped.
in the end what worked was moving the listening position ( couch)
new unequalized response all subs going
I do like that the spl at 10hz is equal to the spl at 80hz
Name:	new position.jpg
14 subwoofers $10k
1201 is online now
post #110 of 113 Old 02-21-2017, 08:35 PM
derrickdj1's Avatar
Quoted: 891 Post(s)
Liked: 598
I can happily work with that.
1201 likes this.
derrickdj1 is offline
post #111 of 113 Old 02-24-2017, 01:28 PM - Thread Starter
Quoted: 805 Post(s)
Liked: 247
I know this thread has been fun, but on a more SERIOUS note,
please note that very loud protracted bass, can cause permanent hearing damage.
please use the bass loudness knob RESPONSIBLY.
14 subwoofers $10k
1201 is online now
post #112 of 113 Old 02-24-2017, 10:22 PM
Quoted: 132 Post(s)
Liked: 41
You are correct of course, keep turning it up until you ALMOST need a diaper, if your bass made you poo yourself you may have to turned it up a little to much. But you are correct, especially since bass frequencies tend to not "sound" as loud at similar decibel levels as higher frequencies. OF course I say that and I spent most of a 2 hour drum and bass show standing, no practically leaning up against a 12 foot tall stack of bass-bins so I could get a good position to watch the DJ LOL.
post #113 of 113 Unread Today, 09:39 PM - Thread Starter
Quoted: 805 Post(s)
Liked: 247
so now that Im over the loudness of the bass, what do more subs behave like at "reference"? (115db)
150 total watts to reach reference. the amplifiers are barely even working. I think I wasted the $350 I spent on a nu6000. oh well.
how about woofer excursion?
4 mm at reference.again barely even working. that makes for some CLEAN output
ID:	1997321   Click image for larger version
Name:	sub excursion.jpg
14 subwoofers $10k
1201 is online now
