Too much bass for the space? - AVS Forum | Home Theater Discussions And Reviews
 99Likes
post #1 of 113 Old 02-13-2017, 02:47 PM - Thread Starter
Quoted: 935 Post(s)
Liked: 313
I have a 950 ft3 room with four 12" subs.
I thought the drivers were junk but it turns out the way I set them up was junk.
meanwhile I already bought 2 um-18s and inuke 6000 and built a box for them.
So....if you were in my shoes, would you just use the two 18s, or would you use the two 18s PLUS the four 12s?
dilemma is it only adds 1.5 decibels but now I will have multiple subs that I would want to time align and that is a lot of effort.
THANK YOU!!! for your selfless contribution to the audio world
Anders Torger for Brutefir
Thomas Drugeon for Rephase
John Mulcahy for room eq wizard
Denis Sbragion for DRC room correction
Juha Hartikainen for Winisd
1201 is offline
post #2 of 113 Old 02-13-2017, 02:52 PM
rontalley's Avatar
Quoted: 718 Post(s)
Liked: 359
64 base level speakers $10k
28 height speakers $10k,
14 subwoofers $10k
90% of the movie sound coming from the center channel - priceless.
LMAO!
2 um-18s will fill up that room without breaking a sweat.
Rob West likes this.
My Media Room
AVR 1-Yamaha RX-A3050 (7.2 Bed), AVR 2 Pioneer VSX-815-K(Used for 4ch Amp TF+TR)
Mains-Polk Audio RTi8, Center-Polk Audio CSi5, Surrounds-Polk Audio RTi4 Monitor Series II, Ceilings-Micca M-8C, Sub 1-Klipsch RW12D, Sub 2-MTX SW2
Projector-Optoma HD33 DLP 3D, Screen-Da-Lite 100" Model B, TV-Insignia 65" LCD 1080p (NS-65D550NA15)
rontalley is offline
post #3 of 113 Old 02-13-2017, 02:59 PM
rhodesj's Avatar
Quoted: 941 Post(s)
Liked: 530
There's no such thing as too much bass. Time aligning doesn't have to be too hard, particularly if you have measuring gear. If you've got a spot or two that gives the best response, stack them all near there. You don't have to spread them out.
What type of enclosures, what type of tuning? Think if it this way, you can have really epic bass if you want.
rhodesj is offline
post #4 of 113 Old 02-13-2017, 03:05 PM
MrMky's Avatar
I couldn't believe this thread name in this forum! As I understand it if you don't have broken drywall or windows, and no flashing lights or sirens, you don't have too much bass,...
Lynkage, drwinlied, Broxer and 3 others like this.
MrMky is offline
post #5 of 113 Old 02-13-2017, 03:19 PM
dtsdig's Avatar
Quoted: 897 Post(s)
Liked: 1006
Here is the door....
Now, you've been shown the door. Too much bass in a room...LOL
The nerve of this thread!
dtsdig is offline
post #6 of 113 Old 02-13-2017, 04:03 PM
Cichlid109's Avatar
Quoted: 145 Post(s)
Liked: 88
Your almost there you just need 2 more 18's and another 6000 plus the 4 12's. Then you can go deaf like the rest of us!!!
mikeTRON250LM likes this.
Yamaha RX-A2010 LCR BIC DV84's w/ 2 SX2400 amps, Volt6 front height w/nu3000, Volt6 rear height by AVR, BIC DV64's w/EPX2800
Infinity1262's in Quad Opposed box w/ nu6000,SI DS4's in 2 sealed Marty Cube w/ IT 8000, 2 SI HST18's in Dual Opposed w/ A14K
Cichlid109 is offline
post #7 of 113 Old 02-13-2017, 05:10 PM
K9woofer's Avatar
Quoted: 74 Post(s)
Liked: 54
Now you can have nearfield 18's, unless you can only fit the 12's.
K9woofer is offline
post #8 of 113 Old 02-13-2017, 06:50 PM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 714
4 subs around the room for the best FR. Keep the small subs closer to the MLP and the other 2, nearfied. Sounds like a dynamite system.
AudioJosh likes this.
derrickdj1 is offline
post #9 of 113 Old 02-13-2017, 07:26 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
I had 4 21" and 8 12" subs at one stage, so I'd say use the lot. Eventually there will be the 4 21" and 4 UM18's.
If I were you, I'd put the 18's up front and the 12's nearfield.
1.5dB sounds too low. What are the 12"s?
Buy a MiniDSP so you can set the delays differently easily and the EQ will be useful.
A9X-308 is offline
post #10 of 113 Old 02-13-2017, 08:39 PM
SpinMonster's Avatar
Quoted: 260 Post(s)
Liked: 111
Too much what?
Lynkage, Prize78 and Gdaddy66 like this.
SpinMonster is offline
post #11 of 113 Old 02-14-2017, 04:33 AM - Thread Starter
Quoted: 935 Post(s)
Liked: 313
14 subwoofers $10k
LMAO!
and in one stroke, i have become, oh no, a consumer.
adding 4 12s for a meager 1.8 db increase doesnt seem worth it to me.
1201 is offline
post #12 of 113 Old 02-14-2017, 04:47 AM - Thread Starter
Quoted: 935 Post(s)
Liked: 313
three of the subs are not moving. so its going to make time aligning tricky. they are sealed subs and they sound very good.
normally I would think you were joking but in the diy bass thread with 8 21s being the norm, you just might be serious as a heart attack
so you are the one who reported me to a moderator for daring to even think that there might be such a thing as too much bass?
I got a warning- THERE IS NO SUCH THING AS TOO MUCH BASS. YOUVE BEEN WARNED.
you have a point. if i do that, do you think I'll finally be able to hear the marvel movies "as they were meant to be heard?" lol
the um18s box will be four ft from the MLP
unfortunately, three of the 12s are the bottom end of my three way active speakers, so those are not moving. having said that I do firmly believe that the subs should come from the same general area as the main speakers.
iirc, the um 18s modelled 121 db at 30hz. the 4 12 modelled 118 db at 30, so 121+118 =122.8
so I guess a 1.8 db increase?
I have something thats kinda like the minidsp that can do delays.
1201 is offline
post #13 of 113 Old 02-14-2017, 06:02 AM
OJ Bartley's Avatar
Quoted: 249 Post(s)
Liked: 345
Try things out with all of them, and make an effort to get them all to play nice together. I doubt you'll want to give up any of them if you can dial things in. Especially if the 12s are part of your main speakers... set your crossovers for those three down low, make sure your AVR isn't set to "LFE+Main" and then just locate the new 18s in the best (feasible) locations. It will be great! If you have one "extra" 12 floating around you can always use it nearfield as an end table or something.
OJ Bartley is offline
post #14 of 113 Old 02-14-2017, 06:37 AM
uniquepattern's Avatar
Quoted: 723 Post(s)
Liked: 701
Ha ha ha, I lost it laughing....
I have cracked drywall (a few times) and still think I could use a little more... ya know... just cause.....
Lynkage and ss nimrod like this.
uniquepattern is offline
post #15 of 113 Old 02-14-2017, 06:45 AM - Thread Starter
Quoted: 935 Post(s)
Liked: 313
lol
you do realize that 2x 24s could be used to provide the low end for a mid to large size auditorium right?
uniquepattern likes this.
1201 is offline
post #16 of 113 Old 02-14-2017, 06:57 AM
Quoted: 43 Post(s)
Liked: 40
lol
Yes, but we all know here that small home theater provides acoustical issues that an auditorium doesn't have, so we have to compensate somehow. Right? That's how I see it.
1201 and uniquepattern like this.
mushroommunk is offline
post #17 of 113 Old 02-14-2017, 07:09 AM
Quoted: 723 Post(s)
Liked: 701
lol you do realize that 2x 24s could be used to provide the low end for a mid to large size auditorium right?
Yes.... yes I do...
Oh yeah.... Any lie I can tell myself to get new gear is great!
1201 and kodyaudette like this.
post #18 of 113 Old 02-14-2017, 07:16 AM
Quoted: 312 Post(s)
Liked: 144
Oh lord I knew this was going to devolve quickly lol. i was hoping I could be the first one in here to scream "ARE YOU MAD NEVER ASK THAT QUESTION HERE!!!" haha. This is a place where anything under 18" is considered tiny, one of the folks on here has a 21" sub in each end table, I've seen photos of people home theaters with a wall of 18" subs or larger. People here buy subs like you buy eggs by the dozen LOL
liffie420 is offline
post #19 of 113 Old 02-14-2017, 07:20 AM
Quoted: 723 Post(s)
Liked: 701
Originally Posted by liffie420 View Post
Oh lord I knew this was going to devolve quickly lol. i was hoping I could be the first one in here to scream "ARE YOU MAD NEVER ASK THAT QUESTION HERE!!!" haha. This is a place where anything under 18" is considered tiny, one of the folks on herehas a 21" sub in each end table, I've seen photos of people home theaters with a wall of 18" subs or larger. People here buy subs like you buy eggs by the dozen LOL
only a 21" sub??? Pffft..... lol
post #20 of 113 Old 02-14-2017, 07:23 AM
Quoted: 12 Post(s)
Quote of the day.
Fattykidd and uniquepattern like this.
kodyaudette is offline
post #21 of 113 Old 02-14-2017, 07:30 AM - Thread Starter
Quoted: 935 Post(s)
Liked: 313
Yes.... yes I do...
you know you want to come to texas and pick up two more 24s . I saw you lurking in that for sale thread.
I think acoustically , for your space. you need four 24s. matter of fact how do you even bear 2 24s. in that small space I would consider two unlistenable. yuck
1201 is offline
post #22 of 113 Old 02-14-2017, 07:40 AM
clientnumber9's Avatar
Quoted: 24 Post(s)
Liked: 45
Are you still thinking about building those extra subs @uniquepattern ?? lol Well, i guess the more accurate question is, have you already started?
clientnumber9 is offline
post #23 of 113 Old 02-14-2017, 07:41 AM
Quoted: 723 Post(s)
Liked: 701
4 24's up front, and 4 18's nearfield is probably about right for the room...
Gotta have a goal in life... lol.....
skipz likes this.
post #24 of 113 Old 02-14-2017, 08:05 AM
Quoted: 312 Post(s)
Liked: 144
I don't know personally I wanna put about 4 up these up front
But then again considering Michael J. Fox is only like 4 feet tall that speaker is probably only a 24" which is hardly worth even considering lol
post #25 of 113 Old 02-14-2017, 08:21 AM
Quoted: 723 Post(s)
Liked: 701
I have to admit, I saw a thread titled 18ft subs for under $300 and got all excited....
Then I realized he was talking about the tiny little 18 inch Ultimax subs.... Cute little things they are.....
post #26 of 113 Old 02-14-2017, 08:44 AM
derrickdj1's Avatar
Quoted: 982 Post(s)
Liked: 714
Depending on room constraints and personal taste, you can leave the subs like that. I am talking in general and a distributed bass system will give the most even response in the room and best FR in the majority of rooms. Another approach is to have the front sub integrated with the mains at the XO and use a lpf on the rear subs so that they don't interfere with the front subs/main combo. Ultimately, each of us has to find the combo that works best in our rooms and suits our taste.
post #27 of 113 Old 02-14-2017, 10:16 AM
Quoted: 43 Post(s)
Liked: 40
Are you familiar with Rotary Woofers? A few adventurous DIY'ers have built them. If you want to beef up the ultra low end. Once I get the rest of the theater squared away I plan on making one if I can.
post #28 of 113 Old 02-14-2017, 05:18 PM
A9X-308's Avatar
Liked: 1142
I'll soon have 2 21's in an ottoman and 2 immediately behind the couch.
A9X-308 is offline
post #29 of 113 Old 02-14-2017, 05:20 PM
A9X-308's Avatar
Liked: 1142
When using dissimilar subs I work out the total volume displacement and calc the SPL from that.
A9X-308 is offline
post #30 of 113 Old 02-14-2017, 05:58 PM
BassThatHz's Avatar
Quoted: 2317 Post(s)
Liked: 2069
More like: STILL not enough bass.
  • Until you have dual 36's and 100kW A/B epoxyed directly to your eardrums, then there is still room to grow.
  • If you aren't down -0db @ DC (or atleast 194db @ 0.1hz), then there is still room for improvement.
  • Until you have a Hover dam or nuclear power plant in your backyard, then there is still room to grow.
1201, Purenv and mikeTRON250LM like this.
BassThatHz is offline
