Quick iNuke Fan mod question. - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By ZLTFUL
  • 2 Post By Cichlid109
post #1 of 13 Old 02-15-2017, 10:24 AM - Thread Starter
jkhome's Avatar
Quoted: 103 Post(s)
Liked: 66
To the folks who have done the mod. Do you reinstall the shroud, or leave it out?
Have two NU3000s, I will be using Noctua NF-R8 fans and heat sinks.
Edit 2/16: These fans: https://www.amazon.com/Noctua-NF-R8-.../dp/B002CQTYL6
jkhome is offline
post #2 of 13 Old 02-15-2017, 11:10 AM
ZLTFUL's Avatar
Quoted: 210 Post(s)
Liked: 179
My NU4-6000s didn't have a shroud. All 3 of them.
Haven't done my NU1ks yet
jsgrise likes this.
I keep confusing my intentions with my abilities.
The Blank Slate Cinema/MacGillvray Pub Build Thread
ZLTFUL is online now
post #3 of 13 Old 02-15-2017, 11:34 AM
jsgrise's Avatar
Quoted: 235 Post(s)
Liked: 144
My 6000DSP neither.
Dedicated HT | FRONTS: Sonus Faber Venere 1.5 CENTER: Sonus Faber Venere Centre SURROUNDS: Sonus Faber Venere Walls RECEIVER: Marantz SR-7010 SUBWOOFERS: DUAL 18" Dayton RSS460HO Custom Build | Behringer iNuke 6000DSP | Velodyne SMS-1 DISPLAY: JVC D-ILA RS-46 w/ 128" 16:9 1.4 TREATMENT: Custom Bass Traps and Acoustic Panels (11)
jsgrise is offline
post #4 of 13 Old 02-15-2017, 11:37 AM
moosifee's Avatar
Quoted: 16 Post(s)
Liked: 52
I run mine fanless into a Lil'Wrecker with the SI 15, bridged to 8 ohms, and have to work it pretty hard for a good while to drive it to shutdown.
moosifee is offline
post #5 of 13 Old 02-15-2017, 12:10 PM
MattSPL's Avatar
Quoted: 25 Post(s)
Can you post a pic of the shroud? No shroud on my 6000dsp.
I'm currently running 1 x Noctua NF-S12A FLX at full speed and one NF-A8 FLX with the low noise adapter.
The 120mm fan is really silent as its mounted externally, and the 80mm fan running at medium speed is silent too.
MattSPL is offline
post #6 of 13 Old 02-15-2017, 12:35 PM
Cichlid109's Avatar
Quoted: 148 Post(s)
Liked: 90
I reinstalled the shroud I have the non dsp 3000. The shroud is not really attached to anything and even after you replace the fan it goes back in fairly easily.In case your wondering amp has never shutdown due to overheating.
Integra DTR 40.6 LCR BIC DV84's w/ 2 SX2400 amps, Volt6 front height w/nu3000, Volt6 rear height by AVR, BIC DV64's w/EPX2800
Infinity1262's in Quad Opposed box w/ nu6000,SI DS4's in 2 sealed Marty Cube w/ IT 8000, 2 SI HST18's in Dual Opposed w/ A14K
Cichlid109 is offline
post #7 of 13 Old 02-15-2017, 01:04 PM - Thread Starter
jkhome's Avatar
Quoted: 103 Post(s)
Liked: 66
LOL. I didn't realize some of the iNukes came without shrouds. These are also non-dsp 3000s. So I will put them back on after the mods.
jkhome is offline
post #8 of 13 Old 02-15-2017, 01:28 PM
MattSPL's Avatar
Quoted: 25 Post(s)
Thanks for the picture, first time I've heard these shrouds mentioned
MattSPL is offline
post #9 of 13 Old 02-15-2017, 11:41 PM
Quoted: 46 Post(s)
Liked: 33
Hey home f you haven't purchased the redux fan yet DON'T. Get the original nf-r8. It costs more but there's a reason why. That crappy brown color may be ugly but it's way quieter than the grey redux model. I have 2 inuke nu6000dps 1 with original noctua's other with redux noctua's. The redux are EASILY twice the volume. In fact they were so loud I had to put voltage limiters in-between then and my inuke to make it quieter than my ps4. Save urself some trouble and spend the extra $5
Acrjoey is offline
post #10 of 13 Old 02-16-2017, 04:42 AM - Thread Starter
jkhome's Avatar
Quoted: 103 Post(s)
Liked: 66
Thanks, actually it appears I mis-spoke. The ones I ordered are these, assumed they were the redux version, guess not?
jkhome is offline
post #11 of 13 Old 02-16-2017, 04:56 AM - Thread Starter
jkhome's Avatar
Quoted: 103 Post(s)
Liked: 66
Acrjoey, did you re-use the iNukes fan mounting hardware or the plastic pins that come with the fan? Heres a pic from that HTS "Behringer iNuke NU1000 Amp Amplifier Fan Swap How To w/ PICS". Looks like if the metal guard is left off, that reduces more noise?
jkhome is offline
post #12 of 13 Old 02-16-2017, 06:15 AM
Cichlid109's Avatar
Quoted: 148 Post(s)
Liked: 90
When I did the fan replacement all I did was swap out the fan and reused the existing hardware. It may not make much of a difference only reason I can see for the stock grill to keep things away from the fan. If you really want to go cheap you can go to your local Best Buy and get one of their fans:
http://www.bestbuy.com/site/insignia...?skuId=3646017
I decided to give one a try and as of yet the amp has never over heated as far as noise cannot tell its even on.
Fabricator and jdubs like this.
post #13 of 13 Old 02-16-2017, 11:08 AM
Quoted: 46 Post(s)
Liked: 33
I left the grill off just like the one in the picture. The noise I'm referring to is the noise from the redux series fans when the rpm is high. They are just noisy well NOISY compared to the normal noctua's. Original brown noctua's like the one in picture are basically silent when in use. The grey redux fans are definitely audible at any speed over 1200 rpm. Now mind you my nu6000dps with the redux fans limited to 1200rpm has never overheated on me but for $5 more I would get original noctua's like I have in my other inuke which are running 1800rpm and produce the same volume. 600rpm make a big difference in airflow cfm.
Acrjoey is offline
