DIYSG Titan-615LX Build Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 146Likes
post #121 of 186 Old 03-12-2017, 06:20 PM
OJ Bartley's Avatar
Quoted: 240 Post(s)
Liked: 334
Yeah, I'm not honestly pushing the big dollar amps too hard, but you don't want to end up with something you regret.
Sent from my LG-H812 using Tapatalk
OJ Bartley is offline
post #122 of 186 Old 03-12-2017, 06:35 PM
JCJetta's Avatar
Quoted: 162 Post(s)
Liked: 230
Originally Posted by 18Hurts View Post
Carvin has a 4 channel Class D with DSP, I think it runs around $579 for the rig.
I'm running the sans-DSP Carvin 4 channel for my little LCR setup, and I love it.
JCJetta is offline
post #123 of 186 Old 03-12-2017, 09:47 PM
gworrel's Avatar
Quoted: 366 Post(s)
Liked: 314
Originally Posted by VicTorious1 View Post
Does the NU4-6000 have problems with higher frequencies?
The NU4-6000 sounds and measures great in my room for my active setup. I use it for 80-600 and 600-20kHz. Full disclosure: I can't hear 20KHz, so who knows.
gworrel is offline
post #124 of 186 Old 03-13-2017, 05:59 AM
brian6751's Avatar
Quoted: 1083 Post(s)
Liked: 1077
Are these a good choice for LCR? 900 watts bridged
https://www.amazon.com/Crown-XLi1500.../dp/B00AR0A43G
Sent from my ASUS_Z00AD using Tapatalk
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is offline
post #125 of 186 Old 03-13-2017, 08:31 AM
rhodesj's Avatar
Quoted: 940 Post(s)
Liked: 529
@MKtheater is using them and has spoken very highly of them.
rhodesj is offline
post #126 of 186 Old 03-13-2017, 12:03 PM
dtsdig's Avatar
Quoted: 895 Post(s)
Liked: 1002
I met MK yesterday for the first time to buy a crap-ton of subs from him. Great guy! We talked about his use of NU4-6000's for his mains and under his use, it sounded like they worked great. I think the key is that if you are using an inuke with very efficient speakers, you may be using like 50 watts or so which is way below where those amps start to get messy with distortion, etc. I thought that was a great point.
dtsdig is offline
post #127 of 186 Old 03-13-2017, 01:12 PM
corradizo's Avatar
Quoted: 1133 Post(s)
Liked: 836
Him having them is actually why I mentioned it. I didn't know about the reason why he's able to use them. Nice.
corradizo is offline
post #128 of 186 Old 03-13-2017, 01:20 PM
gworrel's Avatar
Quoted: 366 Post(s)
Liked: 314
Who says they get "messy with distortion"? The 20dB difference between an 85dB average and a 105dB peak requires 100 times the power. So if your speakers are using more than a few watts on average then you are almost certainly running into problems reproducing the peaks. I suspect that the clipping in less powerful amps and the compression distortion in speakers is far more common and audible than any measurable distortion in the inuke series when they are not clipping. The limiter in the dsp versions also can be set to prevent clipping entirely.
gworrel is offline
post #129 of 186 Old 03-13-2017, 01:27 PM
dtsdig's Avatar
Quoted: 895 Post(s)
Liked: 1002
I agree with you! My comment was in regard to some of the observations made by Notnyt during his testing of the inukes. On a scope, distortion and other issues are apparent when really pushing the amp. In reality, it may not be of any audible consequence for most users. I was simply saying that if only using a few watts from an amp like this, I imagine they will sound just fine as many who use them have figured out. I've only used my NU4-6000 for sub duty so I can't comment on how it would sound driving my 1099's for example.
gworrel likes this.
dtsdig is offline
post #130 of 186 Old 03-13-2017, 02:03 PM
gworrel's Avatar
Quoted: 366 Post(s)
Liked: 314
I would go even further. I would be willing to bet that it is of no audible consequence for any user. It is all too easy to fall into the audiophile trap of thinking that different amps sound different. What is ironic is that it drives people to using less powerful amps which are far more likely to suffer audible distortion because they are more likely to be over-driven.
gworrel is offline
post #131 of 186 Old 03-13-2017, 03:01 PM
stsand's Avatar
Quoted: 96 Post(s)
Liked: 88
Spot on.
Sent from my XT1575 using Tapatalk
stsand is offline
post #132 of 186 Old 03-13-2017, 05:33 PM
gixerking's Avatar
Quoted: 188 Post(s)
Liked: 205
I dunno about the nu4, but I put my 6000 on the 1899's to get a feel as I have been contemplating more power. First off, this did confirm that noise floor is unacceptable from the 6000 for mains. I left everything flat on the dsp. Now I don't have a mic because they are still out of stock, but to my ear I didn't notice enough difference with the inuke at 0 trim showing clip lights vs my b&k with trim at +7. That couple grand will be going elsewhere
gixerking is offline
post #133 of 186 Old 03-13-2017, 06:19 PM
gworrel's Avatar
Quoted: 366 Post(s)
Liked: 314
Were you able to isolate the noise to the nu6000? Here is an article that talks about tracking down noise in a system: https://www.gcaudio.com/tips-tricks/system-noise/
Setting level controls properly can also make a difference in apparent noise: http://www.rane.com/note135.html
I don't understand your last couple of sentences. You substituted the inuke for your B&K and did not notice a difference? What difference did you think you might hear? What does the trim have to do with it? What were you thinking of spending a couple grand on? I'm just not sure what you are saying.
gworrel is offline
post #134 of 186 Old 03-13-2017, 07:35 PM
gixerking's Avatar
Quoted: 188 Post(s)
Liked: 205
I'll leave the noise floor stuff to those more knowledgeable to go into.
Trim is signal level from the receiver to the amp. I'm saying I will spend the couple grand on something else other than more power for my mains. New surrounds, new receiver, mini dsp, whatever I might get more use out of.
post #135 of 186 Old 03-15-2017, 11:04 AM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 167
Originally Posted by stsand View Post
I'm sure those are all great amps, but I shudder to think what they cost. If you have lots of money to throw around, why not.
I've owned the Emotiva XPA-3, and really, that's all you need. 200 continuous watts per channel for extremely efficient speakers. Just my 2 cents.
I thought that too in the other 615 build thread. But Matt pointed out that in "spirited listening sessions" one could be clipping the 100w amp. If one could clip at 100w, 200w gives only 3dB more headroom, so 400w seems a lot safer if one will listen at reference level and above.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is offline
post #136 of 186 Old 03-15-2017, 11:11 AM - Thread Starter
VicTorious1's Avatar
Quoted: 501 Post(s)
Liked: 515
I'm pretty sure that I experienced amp clipping when I was driving these off my avr with 7 channels driven and the volume above reference level. My AVR (Denon x4300h) can output 165 W at 6 ohms into two channels. Not sure how much that drops with additional channels driven. Alleviating the amp's load by adding an XPA3 into the mix made a difference with the test scenes that I ran. My room is on the smaller side, however, but I was easily able to exceed reference cleanly with the addition of the XPA3.
VicTorious1 is offline
post #137 of 186 Old 03-20-2017, 08:52 AM
Jk7.2's Avatar
Quoted: 331 Post(s)
Liked: 542
Hey Vic did you ever start finishing your cabs?
Jk7.2 is online now
post #138 of 186 Old 03-20-2017, 09:32 AM - Thread Starter
Quoted: 501 Post(s)
Liked: 515
Not yet. I've been researching various methods, but I'm waiting until it warms up because I'll need to finish them outside. I'm looking at either staining them or doing a vinyl wrap.
post #139 of 186 Old 03-20-2017, 04:17 PM
Smurfin's Avatar
Just read this thread, nice build! How are they sounding now?
Have you heard or owned any commercial pro cinema speakers e.g JBL 4722n or QSC SC-2150? Very curious how these would compare!
Smurfin is offline
post #140 of 186 Old 03-20-2017, 05:47 PM - Thread Starter
Quoted: 501 Post(s)
Liked: 515
I've heard both the 4722, 4722N and SC2150. I haven't, however, heard the 4722 with the upgraded tweeter that folks rave about. I hesitate to compare them as I haven't heard either in a side-by-side, head-to-hear comparison. I will say that these sound great. If I had the room, I likely would've pulled the trigger on the 4722 after I heard them, but my room didn't have the width. The SC-2150s are bass monsters especially if you can put them in a baffle wall. The Titans are a pleasure to listen to with music and movies. Clear highs/mids and more than ample midbass. I'd definitely recommend these if you're in the market.
Smurfin and eng-399 like this.
post #141 of 186 Old 03-21-2017, 09:43 AM
turbonut's Avatar
Quoted: 39 Post(s)
Liked: 34
Hey @VicTorious1 just curious where you ended up mounting the crossover, any pics of that?
Matt
My Humble Theater
turbonut is offline
post #142 of 186 Old 03-25-2017, 12:03 PM - Thread Starter
Quoted: 501 Post(s)
Liked: 515
I haven't decided how I'm going to mount them yet. I still have them sitting on top of the cabs. I might get one of the plastic see-through cases from Amazon or I might mount them internally. I'll update when I decide.
post #143 of 186 Old 05-14-2017, 08:30 PM
dlinsley's Avatar
Quoted: 184 Post(s)
Liked: 109
I'm assuming there's no update yet, but thought I'd ask as I'm about to stuff with denim and mount the crossovers.
I've seen some pics in the various threads of behind the wave guide or behind the 15" driver but nothing else. I'm thinking maybe underneath the ports - I was going to first check if the main driver is shielded, as I was concerned with magnetic interaction with placement right behind that. Although mine will be behind a screen, I think I'd rather have them internal.
dlinsley is offline
post #144 of 186 Old 05-14-2017, 09:03 PM
mtg90's Avatar
Quoted: 462 Post(s)
Liked: 885
There's plenty of room on the bottom or back of the cabinet behind the ports if you want to place the crossover there.
mtg90 is offline
post #145 of 186 Old 05-15-2017, 07:45 AM
Jk7.2's Avatar
Quoted: 331 Post(s)
Liked: 542
I attached mine to the bracing, over the insulation. It worked out great for me. Just another idea.
Jk7.2 is online now
post #146 of 186 Old 05-15-2017, 09:53 AM
dlinsley's Avatar
Quoted: 184 Post(s)
Liked: 109
Thanks, the bottom was what I was thinking as manouvering my hands seems fine with the ports and woofer removed. I need to minimize the depth taken by the speakers and so plan on having binding posts on the top along with a 4-pole speakon for the mid and tweeter connection to the inside.
Yes, your mount was what I was referencing about being behind the 15" driver. Your experience has been great, so there doesn't appear to be any interaction issue. That location minimizes wiring length, which is nice.
dlinsley is offline
post #147 of 186 Old 05-18-2017, 07:04 AM - Thread Starter
Quoted: 501 Post(s)
Liked: 515
I agree that there's space in the bottom. There's also space behind the driver. I've not done much with changing my temporary mounting of the crossover. It's still just sitting on top. I should've stained/painted and permanently mounted the crossovers before listening. They sound so good that when I'm down in the theater I'm just enjoying them. Hopefully I'll find some time in between traveling this summer to finish them up.
dlinsley, OJ Bartley and Aerumas like this.
post #148 of 186 Old 05-22-2017, 05:12 AM
Quoted: 71 Post(s)
Liked: 55
Looks like the Titans are back up for preorder! I have mine placed and now we wait. Plenty of time to get the cabinets built and ready to go.
Aerumas is online now
post #149 of 186 Old 05-22-2017, 06:09 AM
Jk7.2's Avatar
Quoted: 331 Post(s)
Liked: 542
Awesome! Waiting sucks, but at least you know you have them coming. It looks like these are selling well for Erich. There awesome. You'll love em.
Jk7.2 is online now
post #150 of 186 Old 05-22-2017, 07:12 AM
gpmbc's Avatar
Quoted: 336 Post(s)
Liked: 206
Trying to figure out where the included gasket tape goes?
gpmbc is online now
