How well does a PA 460 model in this size box? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By Samps
post #1 of 7 Old 02-15-2017, 04:17 PM - Thread Starter
Quoted: 136 Post(s)
Liked: 54
How well or not well does a pair of PA 460 drivers model in a cabinet that is 24" wide x 25.5" deep and 48" tall. Want to put 2 drivers in this size cabinet and am afraid it will not have enough internal volume for this driver to really perform well.
I have room for 4 of these cabinets.
Want to make sure before I commit to constructing 4 of these large cabinets that the performance will be worth it.
I am more interested in response down to the 30hz range. 20hz response is great and all but with groups of folks watching movies I keep the volume lower. When listening to music however I can crank it up.
jake515 is offline
post #2 of 7 Old 02-15-2017, 04:39 PM
gworrel's Avatar
Quoted: 377 Post(s)
Liked: 330
With 2 Pa460 in 16 cubic feet, tuned to 22 Hz, maximum output is about 118dB from 20Hz and up. Above 40Hz, it starts climbing to about 127dB at 70Hz. You could get about 4 dB more output at 30Hz if tuned to 28 Hz, but the 22 Hz tune seems a better compromise for movies and music. With 4 of these boxes, with 8 drivers total, you can add about 12dB to those numbers. Not bad at all.
gworrel is offline
post #3 of 7 Old 02-15-2017, 06:46 PM - Thread Starter
Quoted: 136 Post(s)
Liked: 54
The dimensions listed above are external. Will be using 3/4 ply from HD for this project.
jake515 is offline
post #4 of 7 Old 02-15-2017, 07:04 PM
BassThatHz's Avatar
Quoted: 2391 Post(s)
Liked: 2169
Here is 4 of your boxes with 8 460's: 20, 25 and 30hz
You'd have to make each box 8 times the planned size to be flat to the actual tuning.
The Dayton PA's like bathroom-sized ported boxes, they don't make efficient use of what they are given when ported low.
BassThatHz is online now
post #5 of 7 Old 02-15-2017, 07:13 PM - Thread Starter
Quoted: 136 Post(s)
Liked: 54
How much input power are we talking here? 500 w a driver?
The 30 hz tune seems to look the best on this graph.
jake515 is offline
post #6 of 7 Old 02-15-2017, 07:35 PM
Samps's Avatar
Quoted: 939 Post(s)
Liked: 529
This is what I got, in room at MLP with two 460s in 14 cubic feet net, ported to 25hz.
LTD02 and Brazle like this.
Samps is offline
post #7 of 7 Old 02-17-2017, 02:21 AM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
after driver, ports, bracing, etc. the net internal volume will probably be pretty close to 13.5 cu ft or so or a little over 6.5 c.f. per driver. the v.b.b.s. sub is around 6.25, so you would pretty much get that type of performance and could use the dsp settings for those cabs to good effect.
with all those drivers, I'd suggest a low tuning, perhaps something in the 16hz ballpark.
300 watts per driver into 8 drivers at ~6 cubic feet per driver.
mid bass goes "off the chart" and under 30hz, if you have a medium size room or smaller, you'll pick up quite a bit of room gain.
ddigler is running 6 and he was more than happy. 8 would be just a bit 'more better'. :-)
6 sub budget build - an LTD02 design
if you go this route and need some help getting the dsp figured out, plenty of folks here can assist. feel free to pm to me as well.
Listen. It's All Good.
LTD02 is offline
