Quad submaximus v3 build thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 261Likes
post #121 of 464 Old 03-20-2017, 01:18 PM
Jk7.2's Avatar
Quoted: 447 Post(s)
Liked: 644
Originally Posted by hd0823 View Post
Originally Posted by brian6751 View Post
Lol. You could act like your playing it to be all romantic and then ......BOOOOOOOOM????
Sent from my ASUS_Z00AD using Tapatalk
Lol I know when we played it i was like what the heck is this and than the bass hit I was like
Sent from my SM-N920V using Tapatalk
It worked on me too. How embarrassing.
Jk7.2 is online now
post #122 of 464 Old 03-20-2017, 02:36 PM
asarose247's Avatar
Quoted: 839 Post(s)
Liked: 644
Explaining your subwoofer build/ size to the "uninitiated" . . .
Me: it's BIG!
Them: How big is it?
Me: How big is your refrigerator? 19, 22, maybe 25 cubic feet?
Them: I dunno. fairly normal sized, i guess.
Me: So take a brief moment and try to visualize your refrigerator 1 1/2 times or maybe even twice as big. As it's in your living room.
the variety looks you will get are priceless.
worth all the effort, fussing and expense.
especially when you fire it up . . .
eschew mediocrity
JCJetta, eng-399 and hd0823 like this.
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU Sammy 82" 4K/HDR
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x 6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is offline
post #123 of 464 Old 03-20-2017, 03:24 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
This is driving me nuts that I can't figure out panel c
hd0823 is online now
post #124 of 464 Old 03-20-2017, 03:46 PM
Waterboy77's Avatar
Quoted: 573 Post(s)
Liked: 288
Whats up with C?
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is online now
post #125 of 464 Old 03-20-2017, 03:49 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
All my measurements are right except for 7 and 8 and can't figure why there a quarter in off
post #126 of 464 Old 03-20-2017, 03:49 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
10 is on and all the surrounding measurements
post #127 of 464 Old 03-20-2017, 03:52 PM
Waterboy77's Avatar
Quoted: 573 Post(s)
Liked: 288
I'm guessing your long on 7 and 8....
due to plywood not being a true 3/4"
Family Cave Theater
post #128 of 464 Old 03-20-2017, 03:53 PM
brian6751's Avatar
Quoted: 1173 Post(s)
Liked: 1153
Could it be that your panels are not completely 3/4" thick? That would change that measurement
That's not science! - Cyborg
FOR SALE: nothing at the moment
Rivers Edge Theater
brian6751 is online now
post #129 of 464 Old 03-20-2017, 04:00 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
Actuality short but every other measurement is on
post #130 of 464 Old 03-20-2017, 04:01 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
Messaged John to see off its going to make a big difference
post #131 of 464 Old 03-20-2017, 04:05 PM
Waterboy77's Avatar
Quoted: 573 Post(s)
Liked: 288
Bold below quoted from John
i've copied the important information into this post so that it is all in one place. if i left anything out, please let me know and i will add it. thanks...
- good bracing is required.
- i'm not sure if the black diagonal deflector at 14/15 actually does anything other than serve as a brace.
- side panels are 36" x 80". best practice would be to draw the panel layout onto a side piece.
- the measurements will vary by a slight amount depending on the precise thickness of the wood panels ("three quarter inch plywood" in many cases is 23/32). that won't affect performance in any way, just be aware of it where you want the panels to line up just right (on the outside of the cab for example).
- try to get measurement 1 as close as possible to 3.23 inches. that measurement sets the "compression ratio", which for this horn is actually pretty low, so there is actually some wiggle room there. but still, if only one measurement on the entire horn is 'perfect', that should be it.
- a removable panel could be cut in the side for access to the driver if that is desired.
- this aspect of the design process actually required the most time/work. if somebody could double check these measurements, i'd appreciate it.
one bracing strategy--single row of 6" braces down the center of the cab. two rows might be even better, but more work. doubling up on the first brace in front of the driver might not be a bad idea.
Family Cave Theater
post #132 of 464 Old 03-20-2017, 04:07 PM
Waterboy77's Avatar
Quoted: 573 Post(s)
Liked: 288
I'm very surprised at your measurement being short
What is your F board?
Family Cave Theater
post #133 of 464 Old 03-20-2017, 04:10 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
It's right . It's actually the 7 and 8 distances that are off not the actual panel c but 10 is dead on it doesn't make sense to me
post #134 of 464 Old 03-20-2017, 04:12 PM
Jk7.2's Avatar
Quoted: 447 Post(s)
Liked: 644
I maybe would have cut some scrap 'spacers' at the dimensions of numbers 2, 4, 8, and 10 just to temporarily space things out and be sure the panels are right on.
Jk7.2 is online now
post #135 of 464 Old 03-20-2017, 04:15 PM
Jk7.2's Avatar
Quoted: 447 Post(s)
Liked: 644
In the glass business we use the term "split the difference", so nothing tracks too far off. If one dimension is off out of four, adjust them all so there equally off just 1/32 or 1/64 and that should be better then one being off 1/4". Just another $0.02.
wreckingball likes this.
Jk7.2 is online now
post #136 of 464 Old 03-20-2017, 04:30 PM
Waterboy77's Avatar
Quoted: 573 Post(s)
Liked: 288
Do you have C at 90 degrees to F?
Just throwing ideas out there.... but its probably going to be a split the difference like Jk7.2 said
Family Cave Theater
post #137 of 464 Old 03-20-2017, 04:36 PM
asarose247's Avatar
Quoted: 839 Post(s)
Liked: 644
I concur . .the layout for the first 1 due to .702 thickness for the sanderply,
challenging . . but not insurmountable
Just think about how easy the next 3 will be . .
(not so dissimilar to having /raising kids -YMMV)
love the pics
post #138 of 464 Old 03-20-2017, 05:33 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
Yeah it's at 90 degrees to f. Probably just going to split the difference it will throw a few other measurements off but 7 won't be as far off. 8 is actually only off by about 1/8
post #139 of 464 Old 03-20-2017, 06:10 PM
brian6751's Avatar
Liked: 1153
I still think its because your material is less than 3/4" thick. The measurements from edge to edge are assuming the material is 3/4"
Fattykidd and hd0823 like this.
Rivers Edge Theater
post #140 of 464 Old 03-20-2017, 06:14 PM
wreckingball's Avatar
Quoted: 170 Post(s)
Liked: 74
Nother glass guy, eh? Small World..
Far as construction advice, I agree with the rest, split the diff...
On another note: These fuggers gon'rock!
hd0823 likes this.
Actually, I love tube amps..
I play guitars through them.
wreckingball is offline
post #141 of 464 Old 03-20-2017, 06:38 PM
Waterboy77's Avatar
Quoted: 573 Post(s)
Liked: 288
My OCD got the better of me....
The addition of Ply (5*3/4) + 2 (6 1/8) + 4 (6 1/2) + 8(9 1/8) + 10 (10 13/16) = 36 5/16
The thinner ply is 23/32" which would bring that down to 36 5/32" (just over an 1/8th)
F is 36" thus the reason you measured 8 as short
This doesn't take into account the angle that the ply in on... but really that's splitting hairs
Hope that makes sense.
Family Cave Theater
post #142 of 464 Old 03-20-2017, 07:01 PM
asarose247's Avatar
Quoted: 839 Post(s)
Liked: 644
It will make perfect sense
when he fires up all 4 at the same time . .
finishing #1 very important . .
sitting down, listening "raw", and integrating, somewhat, into the system before finishing the other 3,
maybe the only 1 fatal flaw in the plan
(o.k @Fattykidd - that's your cue)
good to see the due diligence for finding that lost 1/8th".
post #143 of 464 Old 03-20-2017, 07:09 PM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 580
finish all 4 before you....
Fire it up
brian6751 likes this.
Fattykidd is offline
post #144 of 464 Old 03-20-2017, 07:18 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
Fire it up
Picture or video isn't showing up for me . I'm definitely going to finish all 4 before I fire them up i know of it fire up the first progress will slow dramatically.
post #145 of 464 Old 03-20-2017, 07:19 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
So would you split the difference or just leave it be
post #146 of 464 Old 03-20-2017, 07:37 PM
Waterboy77's Avatar
Quoted: 573 Post(s)
Liked: 288
Split the difference
As noted by John the most critical measurement is #1
And Ya get all four done first
LTD02 and brian6751 like this.
Family Cave Theater
post #147 of 464 Old 03-20-2017, 07:52 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
OK thanks yeah I have measurement 1 dead on
brian6751 and Waterboy77 like this.
post #148 of 464 Old 03-21-2017, 01:28 PM
LTD02's Avatar
Quoted: 2553 Post(s)
Liked: 2888
the difference is probably just the accumulation of panel thicknesses being a little less than 0.75.
if measurements 2, 4, and 10 are all accurate AND the exterior panels are all the way to the edge of the side panels, then you will have lost 5 panels * about .05" per panel of width, which is 0.25"
if you shift panel c over by about half the distance, that would be the easy fix.
Listen. It's All Good.
LTD02 is offline
post #149 of 464 Old 03-21-2017, 02:43 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
Thanks I'll get that moved over tonight when I get home. Hopefully the next 7 stencils go better. Should I figure the next one out for 3/4 and just position the boards in the center of the 3/4
post #150 of 464 Old 03-21-2017, 02:46 PM - Thread Starter
hd0823's Avatar
Quoted: 239 Post(s)
Liked: 441
Did anyone have trouble getting the pl premium 3 to work with there caulk gun. It was not wanting to come out. Broke my caulk gun after 1 panel
