Strafi Translam FaitalPro Tower Build - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 214Likes
post #121 of 246 Old 05-18-2017, 09:27 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
You arent getting phase issues with a second order roll off on the half woofer?
Yes there are some unwanted interactions, I'm waiting for a 5mh inductor which will be here tomorrow and should suffice for a 6db slope
jshadzi is online now
post #122 of 246 Old 05-19-2017, 12:51 AM
Javs's Avatar
Quoted: 3433 Post(s)
Liked: 2946
What software are you using to design and model the crossover?
I see REW there, so thats not the answer I am looking for.
What freq are you planning on crossing over to the CD at?
JVC X9500 (RS620) | OZTS Majestic 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | Rotel RMB-1555B | DIY TPL-150 L/C/R | DIY MTM TPL-150 Surrounds | DIY Dolby Atmos Modules | DIY Quad 18" Subs 30cf
Shootout - JVC RS500 & Sony 320ES | My MadVR Settings
Javs is online now
post #123 of 246 Old 05-19-2017, 08:27 AM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
I use REW and Omnimic for measurements and I'm modeling in WinPCD, CD will be XO around 1500hz, currently working with 18db slopes, nothing is finalized.
post #124 of 246 Old 05-19-2017, 10:47 AM
PrimeTime's Avatar
Quoted: 599 Post(s)
Liked: 299
Originally Posted by jshadzi View Post
Currently a 3.5mh and an 80uf cap to roll it off around 250hz which plays a baffle step function as well. And thanks! =)
Looks like tuxedovic beat me to the punch. Which is:
I suggest eliminating the shunt capacitor and going to a larger (5-10 mH) series inductor for the lower woofer.
Using a two-pole network (inductor plus shunt capacitor) introduces excessive phase shift near that x/o point and can cause sharp cancellation dips there. Which is to say, once the lower woofer's relative phase shift approaches and exceeds 90 degrees (which is what happens passing the x/o point in a 2-pole network), the lower woofer, though attenuated somewhat, will be fighting the upper woofer.
With a single inductor sans shunt capacitor, the lower woofer's phase shift will increase gently and will not be fighting the upper woofer as the lower woofer rolls away.
(If you're building your own iron-core inductors, you can "tune" the inductance during design by sliding the core partially out, like a nuclear control rod.)
jshadzi likes this.
PrimeTime is online now
post #125 of 246 Old 05-19-2017, 02:24 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Thanks for the comments, see my reply above was just temporary, 4.7mh I ordered showed up today, will test that tonight, a 9.1mh indicator was just too big.
Javad
post #126 of 246 Old 05-19-2017, 02:54 PM
corradizo's Avatar
Quoted: 1183 Post(s)
Liked: 909
Hi Javad,
I noticed you used a CLD method for your fatboys design on the baffle and another method inside the box. This design employs CLD on the end caps only. Could you comment on if you are able to hear or measure differences with/without the CLD baffle? I'm thinking to try the CLD baffle on a set of speakers I'm going to build but cannot determine if it would be worth the hassle. Also (if you don't mind) could you comment on the brand of the CLD glue, foil damping materials for the fatboys and the source for sorbothane for this project? Thanks so much for sharing your designs in such detail!
Pete
corradizo is offline
post #127 of 246 Old 05-20-2017, 04:30 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Little update, I've been working on the XO for the last week and I think I'm quite close to where I want to be, I've been using a combination of REW, Omnimic and PCD, as well as changing component values and measuring/listening. Slopes are 18db around 1500hz, with the .5 rolling off at around 250hz 6db with a 4.7mh inductor.
I wired up both speakers (which measure almost identically) and got to listen to them in stereo today, fun!
First impressions very dynamic and sharp, lively, smooth top end with no sibilance, and still has air and sparkle. Bass rolls off starting at 60hz but above that very fast and sharp bass from these pro 8" drivers. Probably never going to have that refined Scan Speak sound though.
I've been listening to my reference tracks as well as the MWAF tracks (man that Lorde song is a doozy!) and am quite pleased. Also got to hear them playing Money for Nothing at 112db/1 meter, wow, these things really crank with about 96db efficiency.
Also experimenting with finishes, I'm leaning towards spray Spar varnish, goes on really smooth and the stuff is tough as nails, here is a test piece with no grain filler, just clear gloss spar urethane over the 220grit finished wood. 3 coats no sanding
I'll break the cabinets down to raw wood this week and spend a few weeks on the clear coat process, stay tuned.
Javad
post #128 of 246 Old 05-20-2017, 05:29 PM
Javs's Avatar
Liked: 2946
Javad
Very nice.
I have those woofers in an MTM for my rears. They are fantastic. They may not have the refinement of the Scanspeaks, but they will outgun them in the upper SPL levels for sure and remain very composed until your ears give out. Make no mistake, these are designed for north 100db output and they take it while smiling.
They will also loosen up on you a bit, I found the bass got a lot better over some time, those spiders are very stiff.
Personally I would do a darker stain then clear on top, that would set those speakers off! Boiled linseed oil maybe and when that dries try the clear. It will make the grain absolutely pop.
jshadzi likes this.
Javs is online now
post #129 of 246 Old 05-20-2017, 05:41 PM
Javs's Avatar
Liked: 2946
Javad, what is that 3-way you have in the background there behind your Strafi's?
I am hoping there is a build thread on those they look really nice.
Javs is online now
post #130 of 246 Old 05-20-2017, 08:57 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Very nice.
Of course I'm well aware of your project, saw them last year, first time I saw the 8PR200 and I was inspired, in Dec I modeled just about every 8" Pro woofer on the market and nothing compared to the 8PR in terms of Fs and efficiency =)
I'm leaning toward Minwax Natural stain which simply brings out the grain much like oil, then clear spar urethane, I really couldn't stand to cover up this wood with a stain or color, it's just too beautiful but I think the grain will really come out. This is a test piece with Crystalac grain filler used as well
Thanks Javs!
Javad
post #131 of 246 Old 05-20-2017, 09:01 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
You bet! Those were a Parts Express speaker design team project I did, see thread here http://techtalk.parts-express.com/fo...river-15-3-way
and also see the videos I posted on YouTube so you can hear them, very fun speakers!
post #132 of 246 Old 05-20-2017, 09:05 PM
Quoted: 94 Post(s)
Liked: 89
Why would you finish these!! They already look amazing.
Trimlock is online now
post #133 of 246 Old 05-20-2017, 09:22 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Hah, well they'll look even better not to mention to protect the wood and keep moisture out, I appreciate the sentiment though, I promise they'll look even better =)
post #134 of 246 Old 05-20-2017, 09:35 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Originally Posted by corradizo View Post
Hi Javad,
Pete
Hey Pete happy to help!
I detail everything in my Fatboys build thread here http://techtalk.parts-express.com/fo...-speaker-build. I use a different technique with polyurethane adhesive, it's a little involved but works really well. This is the foil CLD I used https://www.amazon.com/dp/B00KIUDWES..._EIrizbT22Y5NQ
The other method I use in these Strafis, go back a ways and I cover the technique and materials, same as what I used on my Baronets build here http://techtalk.parts-express.com/fo...r-build-thread
Sorbothane sheets are available from McMaster.com
And I use a mass loading technique in this build here http://techtalk.parts-express.com/fo...r-build-thread
And you can see how I used extensive high density bracing in this build here http://www.diyaudio.com/forums/multi...er-towers.html
Basically all these techniques accomplish the same thing, they reduce the amplitude of acoustic output of the enclosure panels, with CLD you can get away with minimal bracing, but if you have plenty of room for bracing then CLD is not needed.
Every one of these enclosures are dead quiet, my final test is to play the speakers at 100db 1 meter and put my ear in each panel including the baffle (if possible), all these speakers easily pass that test with minimal sound with my ear touching the cabinet.
Let me know if I can help any further Pete,
Javad
corradizo likes this.
post #135 of 246 Old 05-21-2017, 06:17 AM
Quoted: 22 Post(s)
Can't wait to see them finished!
jshadzi likes this.
brireeves629 is online now
post #136 of 246 Old 05-21-2017, 10:36 AM
corradizo's Avatar
Liked: 909
Javad
Thanks for all of this detail. I've got some reading to do! Thx again.
Pete
jshadzi likes this.
post #137 of 246 Old 05-21-2017, 12:29 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Pete
My pleasure! Exactly why I post this stuff, so others can share in what I'm learning *thumbsup*
bimmaguy likes this.
post #138 of 246 Old 05-21-2017, 04:47 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Someday when I'm on my death bed and I recall the most incredible moments of my life, they'll be
1 - seeing my stunning wife walk down the aisle towards the pulpit at our wedding
2 - seeing each of my 4 children as they were born
3 - when I opened the letter from the IRS notifying me that the first top to bottom audit on my last 3 years taxes was over and I owed $0.
4 - the first time I accelerated from 0-60mph in under 2 seconds
5 - when I applied Minwax Natural stain to the Strafi speakers
Haha, boy was that satisfying!
That grain was there all along, so good to finally see it.
Ready to start finishing
2 coats of Minwax Natural
And first coat of clear, will put a second cost on and then sand with 400 between coats, thinking of doing 5 coats. I decided to skip the Crystalac, it was lightening the wood and I'm happy with how it looks so far.
Javad
brian6751, SmittyJS and Javs like this.
post #139 of 246 Old 05-21-2017, 05:04 PM
tuxedocivic's Avatar
Quoted: 2202 Post(s)
Liked: 2078
Nice speakerd, but I gptta know how you did 0-60 in 2 secs. That is rocket ship fast!
My youtube channel: Impulse Audio
tuxedocivic is offline
post #140 of 246 Old 05-21-2017, 05:15 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Hah, yea I've had the pleasure to build and drive some very fast cars over the years, here's one car we built, car had over 1000HP at the crank
post #141 of 246 Old 05-21-2017, 05:24 PM
Quoted: 22 Post(s)
The speakers look amazing. Nice choice doing the natural stain.
jshadzi likes this.
post #142 of 246 Old 05-21-2017, 08:05 PM
Javs's Avatar
Liked: 2946
Hah, yea I've had the pleasure to build and drive some very fast cars over the years, here's one car we built, car had over 1000HP at the crank https://youtu.be/zPbBTBqffYA
Respect!
My first car was a B5 A4!
I have an 8v A3 now, and my RS3 Sedan arrives next month
Javs is online now
post #143 of 246 Old 05-21-2017, 10:49 PM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Respect!
Nice! I have an RS3 on order for product development, and if you get European Car we're on the cover currently, our S3 won their Grand Prix http://www.superstreetonline.com/eve...-tire-2-0t-gp/
post #144 of 246 Old 05-22-2017, 12:58 AM
Javs's Avatar
Liked: 2946
You work for 034 Motorsports??
In what capacity?
Javs is online now
post #145 of 246 Old 05-22-2017, 07:00 AM
Liked: 2078
You must be single or retired I have 4 kids a wife and full time job. I get one hobby and thats it
jshadzi likes this.
post #146 of 246 Old 05-22-2017, 07:18 AM
FriscoDTM's Avatar
Quoted: 306 Post(s)
Liked: 278
Nice work
jshadzi likes this.
Display 2013 Samsung 75" UN75F6300 TV Media Xbox One S, Dune Solo, QNAP TS-453A NAS
Pre/Amp Marantz 7702mk2 Processor + DIY 11ch Icepower 50ASX2BTL Monoblock Amp Amp Build Link
7.2.4 Speakers DIYSG 1099s (LCR), Volt 10LX (SL, SR), Volt 8LX (BL, BR), Volt 10LX (TF, TR) Volt Build Link
Subs Dual 19Hz DIY Ported UXL-18s + FP14k Amp + MiniDSP 2x4 Balanced Tactile Crowsons + iNuke 6000DSP
FriscoDTM is offline
post #147 of 246 Old 05-22-2017, 07:35 AM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
In what capacity?
Owner/President, definitely let me know if we can help with anything.
Oval56, Javs and Brazle like this.
post #148 of 246 Old 05-22-2017, 07:41 AM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Hah not retired yet! I'm early 40's, I own and run a 35 employee manufacturing company, I have 4 kids under 10, married etc.
Fortunately one of my hobbies is how I make my living, speaker building definitely fills in the spare moments. My wife is very understanding and I sleep about 5-6 hours a night during these bigger projects which allows me to put in an extra 10 hours a week plus a weekend day, and I can easily take a day off from work too several times a month as I have a very good team. Key is making every minute of the day count.
Oval56 and Javs like this.
post #149 of 246 Old 05-22-2017, 08:13 AM
Liked: 2078
Ah, thats helps having your career be a hobby. I certainly make every minute count. No way to survive otherwise! But lately my speaker building hobby has morphed into a honey do list of house renovations... thats ok. I have 3 speaker projects on the go so I cant complain. She's very understanding.
Gouie and jshadzi like this.
post #150 of 246 Old 05-22-2017, 11:54 AM - Thread Starter
jshadzi's Avatar
Quoted: 106 Post(s)
Liked: 383
Did a quick sand with 400 and another coat this morning, I think I'll do 5 coats total and see how it looks, possibly more on the top and buff that out. I may still use the grain filler if things aren't smoothing out, it can be used between layers as well but it seems to lighten the wood which I don't like
