Tips on unloading heavy driver from existing cab - AVS Forum | Home Theater Discussions And Reviews
 14Likes
  • 1 Post By asarose247
  • 6 Post By neo_2009
  • 4 Post By Samps
  • 1 Post By STL D
  • 1 Post By acras13
  • 1 Post By derrickdj1
post #1 of 12 Old 03-14-2017, 11:35 AM - Thread Starter
SeekingNirvana's Avatar
Quoted: 248 Post(s)
Liked: 164
Going from sealed to ported and I need to remove my LMS Ultras from the sealed cabinets they are in. Wondering if there are any quick tips.
SeekingNirvana is offline
post #2 of 12 Old 03-14-2017, 01:42 PM
drunkpenguin's Avatar
Quoted: 1350 Post(s)
Liked: 1367
I recently had to replace my SVS driver (50 lbs I think) and they sent me a real handy tool for this. I don't know what its' called but it basically screwed into the screw holes (with the screws out) and gave me 2 handles to lift the driver out.
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is offline
post #3 of 12 Old 03-14-2017, 02:15 PM
asarose247's Avatar
Quoted: 825 Post(s)
Liked: 638
linguistically and mechanically, .01 each
the OP kinda nailed a simplistic way to "giter" done
with his first word in the title,
just prepare for a soft , controlled and strategically cushioned landing . . .
worked for my UXL, also 50#,
Fabricator likes this.
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: 88 Special(V2) , RL/RR: F-3, TF/TR: Volt 6's TM: SLX, FH: F4Q4
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
post #4 of 12 Old 03-14-2017, 02:38 PM - Thread Starter
Quoted: 248 Post(s)
Liked: 164
Got-r-done
post #5 of 12 Old 03-14-2017, 02:42 PM
Cichlid109's Avatar
Quoted: 147 Post(s)
Liked: 89
Must be something against heavy subs and fingers? I had one of my HST's decide to use a finger for a cushion the sub is approx 60-70lbs does not feel all that good.
Integra DTR 40.6 LCR BIC DV84's w/ 2 SX2400 amps, Volt6 front height w/nu3000, Volt6 rear height by AVR, BIC DV64's w/EPX2800
Infinity1262's in Quad Opposed box w/ nu6000,SI DS4's in 2 sealed Marty Cube w/ IT 8000, 2 SI HST18's in Dual Opposed w/ A14K
Cichlid109 is offline
post #6 of 12 Old 03-14-2017, 03:37 PM
neo_2009's Avatar
Quoted: 117 Post(s)
Liked: 83
Troels Gravesen recommends this :
Sometimes it can be a real pain removing a driver from its cabinet, maybe due to lacquer or tight routing and the simple solution is making treads in one the mounting holes in the basket. For 8" drivers usually 6 mm threads work. For 4-5" drivers maybe 5 mm. Measure hole diameter and use the the nearest size. Insert a screw and lift the driver with a plier resting on a piece of wood. Simple as that.
neo_2009 is offline
post #7 of 12 Old 03-14-2017, 05:19 PM
Samps's Avatar
Quoted: 925 Post(s)
Liked: 526
I usually use one of these pick tools in one of the screw holes.
Samps is offline
post #8 of 12 Old 03-15-2017, 09:41 AM
STL D's Avatar
Quoted: 286 Post(s)
Liked: 289
I just put a few layers of pillows down in front of the box and SLOWLY lean the box forward. Works great for the UM18, but I'm not sure I'd try it with the 5400u.
chrapladm likes this.
STL D is online now
post #9 of 12 Old 03-18-2017, 05:30 PM
acras13's Avatar
Quoted: 151 Post(s)
Liked: 147
Stuff dynamite in the port , light the fuse , prepare to catch...
YonathanZ likes this.
It was like that when I got here
acras13 is offline
post #10 of 12 Old 03-19-2017, 01:21 AM
chrapladm's Avatar
Quoted: 938 Post(s)
Liked: 350
Pillow in front of woofer works best for me. Looking at putting my 15HST in a ported cabinet also.
chrapladm is offline
post #11 of 12 Old 03-19-2017, 11:18 AM
Vince_B's Avatar
Quoted: 88 Post(s)
Liked: 53
Lag screw works well too, the coarse threads usually fit the flange thickness pretty well. The 24 I just gave up and surface mounted
Sent from my SM-N910V using Tapatalk
Vince_B is online now
post #12 of 12 Old 03-19-2017, 06:41 PM
derrickdj1's Avatar
Quoted: 984 Post(s)
Liked: 722
I just grab the rubber surround and lift it enough to get my fingers under it. If it is stuck, flip it driver side down on a rug and let gravity do it thing. A little WD 40 can help. On my first couple of sealed subs, I let the paint dry for 2 day. Months later, I discover the driver stuck to the paint surround. For that, I used this:
wlhungdude likes this.
derrickdj1 is offline
