JK's Titan615LX's - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 151Likes
Old 03-20-2017, 05:01 AM
brian6751's Avatar
Quoted: 1016 Post(s)
Liked: 950
Originally Posted by Fattykidd View Post
I'd look at the outlaw 7140 and 5000 amps. More power lower distortion. Can't speak to build quality on the above.
Or stick to the xpa series. I started out with a upa700 and the build quality was pretty low. I can't imagine basx being much better.
Just my .02
I looked the 5000. Its not made by ATI like their other amps. I have owned several Emotiva amps in the past. XPA and UPA's. I never had an issue with their quality.
Sent from my ASUS_Z00AD using Tapatalk
That's not science! - Cyborg
Steam ID: The Barbeerian
Rivers Edge Theater
brian6751 is online now
Old 03-20-2017, 05:06 AM
brian6751's Avatar
Liked: 950
Originally Posted by mtg90 View Post
Note to calculate SPL on these using the 99dB/2.83v/1m sensitivity figure use the power into 8 ohm rating of the amplifier. So if say the amp does 100w at 8 ohms you would get 119dB/1m.
So that would be 80wpc from the a700.
Rivers Edge Theater
Old 03-20-2017, 05:32 AM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
that should be good. I'm not shooting for max spl I guess. Just mega clarity at the loudest volume I would ever listen. That should be right around reference. I'll never push it to plus 5 or anything.
brian6751 likes this.
Jk7.2 is online now
Old 03-20-2017, 06:56 AM
dtsdig's Avatar
Quoted: 888 Post(s)
Liked: 992
I heard that the Outlaw 7140 is made by ATI. I have never owned either.
dtsdig is offline
Old 03-20-2017, 07:23 AM
SteveCallas's Avatar
Quoted: 204 Post(s)
Liked: 93
Have you guys checked out the monoprice monolith amps? I'd lean that way before the outlaw.
SteveCallas is online now
Old 03-20-2017, 07:39 AM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
I just looked at it. Looks like a decent option.
Jk7.2 is online now
Old 03-20-2017, 08:24 AM
dtsdig's Avatar
Quoted: 888 Post(s)
Liked: 992
Someone said those are made by ATI as well.
brian6751 and Fattykidd like this.
dtsdig is offline
Old 03-20-2017, 10:41 AM
brian6751's Avatar
Liked: 950
The Monoprice Monolith amps are made by ATI.
I decided I'm just going to use the a700 too.
If you thought the a700 was plenty for your 10 Max's, I would think it would still be fine with these titans.
Rivers Edge Theater
Old 03-20-2017, 10:53 AM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
Yes that makes sense. Especially crossed over around 80hz, I won't be amp limited.
Jk7.2 is online now
Old 03-20-2017, 11:37 AM
Fattykidd's Avatar
Quoted: 561 Post(s)
Liked: 571
Fair enough, I was just very unimpressed with the flimsy rca jacks and $3 binding posts. The single amplifier board seemed pretty entry level too. In comparison to other "budget" amp models.
I just much prefer the more robust components. Completely personal preference.
Fattykidd is offline
Old 03-20-2017, 12:09 PM
brian6751's Avatar
Liked: 950
Ah yes. Now that you mention it, the rca inputs on my XPA-3 were kind of flimsy. I remember some people actually broke them off
Rivers Edge Theater
Old 03-20-2017, 12:16 PM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
I just got FedEx notification that my kits will arrive tomorrow. This is super exciting.
brian6751, JCJetta and eng-399 like this.
Jk7.2 is online now
Old 03-20-2017, 12:25 PM
hd0823's Avatar
Quoted: 180 Post(s)
Liked: 302
I can't wait to see how these sound
Should be quick with the pre-assembled crossovers
Sent from my SM-N920V using Tapatalk
hd0823 is online now
Old 03-20-2017, 01:07 PM
brian6751's Avatar
Liked: 950
Strong call
Jk7.2 likes this.
Rivers Edge Theater
Old 03-20-2017, 01:16 PM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
Strong call
Well I have the other titan build threads to thank for that one. I originally decided to build my own. After seeing the thing in Vic's thread, I knew I was an idiot. I had to contact Erich and he added "oops I changed my mind" on the finalization of the pre order page.
Jk7.2 is online now
Old 03-20-2017, 02:27 PM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
The last box is all glued up. Waiting for my insulation before I glue on the front baffle. Where on the box would you guys put the speakon input? The back, side, or top?
Jk7.2 is online now
Old 03-20-2017, 02:44 PM
VicTorious1's Avatar
Quoted: 485 Post(s)
Liked: 487
I think I'd do the top like QSC. That should still give you room to toe in the HF portion.
Jk7.2 likes this.
VicTorious1 is offline
Old 03-20-2017, 02:46 PM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
I was thinking that would work. It's just ugly up there. And the speakon "pass through" so to speak, will be on the top already as well.
Jk7.2 is online now
Old 03-20-2017, 05:05 PM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
Been staring at this for a while. Lots of work to do on the screen wall yet, so don't judge.
ID:	2039217   Click image for larger version
eng-399 likes this.
Jk7.2 is online now
Old 03-20-2017, 05:23 PM
eng-399's Avatar
Quoted: 1494 Post(s)
Liked: 2342
I put the main speaker connection going to the board in the back of the box on the bottom and put a speakon on top of box for the mid and cd. I like having the speakon on the top behind the waveguide so when you need to move the speaker you just unplug the top portion of the box and move it safely were you want it and plug it back in.
eng-399 is online now
Old 03-21-2017, 07:40 AM
Liked: 4
Just out of curiosity, how do you wire the mid and cd in one speakon connector?
Twedter is offline
Old 03-21-2017, 07:42 AM
dtsdig's Avatar
Quoted: 888 Post(s)
Liked: 992
Most of us use the 4-pole Speakons because they're easily available and don't really cost more than the 2 poles.
https://www.parts-express.com/neutri...mount--092-050
eng-399 and mikeTRON250LM like this.
dtsdig is offline
Old 03-21-2017, 07:44 AM
Liked: 4
Ah, ok. Just started looking into the speakon connectors for building a sub. Wasn't super familiar with them.
Twedter is offline
Old 03-21-2017, 07:51 AM
dtsdig's Avatar
Quoted: 888 Post(s)
Liked: 992
I don't use anything else anymore. They are so easy, secure, high current rated and built with quality that it's a no-brainer for me. I like the simple look and easy connection too.
dtsdig is offline
Old 03-21-2017, 08:11 AM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
I completely agree. There so much better than binding posts or terminal cups.
Jk7.2 is online now
Old 03-21-2017, 12:41 PM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
No words needed
ID:	2040449   Click image for larger version
ID:	2040457   Click image for larger version
ID:	2040465   Click image for larger version
Jk7.2 is online now
Old 03-21-2017, 01:36 PM
Quoted: 485 Post(s)
Liked: 487
No words needed
Just beautiful.
Old 03-21-2017, 02:02 PM
Old 03-21-2017, 02:25 PM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
I'll have them making noise by Saturday.
Jk7.2 is online now
Old 03-21-2017, 04:45 PM - Thread Starter
Jk7.2's Avatar
Quoted: 246 Post(s)
Liked: 381
Here is a pic of the one connector I'll use for the high and mid.
ID:	2041177   Click image for larger version
Jk7.2 is online now
